Re: gluing MDO
I have pictures on www.chebacco.com/new articles/building the clc,
where I broke a test but joint of MDO.
The papaer is at least as strong as the wood.
If I was building a small boat, I would only glass the joints when
using MDO. If it will live in the water, or you are building anything
over about 16ft, I would at least glass the outside.
--- In bolger@y..., Fritz Funk <fritzf@a...> wrote:
> Yes, you can glue MDO just fine without sanding off the paper -
where I
> sanded the paper off I was gouging out a "hole" so the layers of
glass
> cloth would be fair with the surface.
> --Fritz
> At 02:39 AM 2/28/2002 +0000, you wrote:
> >Can you glue MDO without sanding off the paper? Epoxy or PL? What
> >about fiberglass butt splices? Fritz Funk sanded off the paper.
Also
> >does the paper laminate mean I do not need to fiberglass the whole
> >hull, just the seams? Does anyone have any experience with this?
It
> >should hold paint well.
> >Charles
> >Bolger rules!!!
> >- no cursing, flaming, trolling, spamming, or flogging dead horses
> >- pls take "personals" off-list, stay on topic, and punctuate
> >- add your comments at the TOP and SIGN your posts, snip all you
like
> >- To order plans: Mr. Philip C. Bolger, P.O. Box 1209, Gloucester,
MA,
> 01930, Fax: (978) 282-1349
> >- Unsubscribe: bolger-unsubscribe@y...
> >Your use of Yahoo! Groups is subject to
> Fritz Funk
> Phone: (H): (907)780-4261 (W):(907)465-6113
> My Boat Page:http://www.alaska.net/~fritzf/Boats/Boats.htm
> (Bolger power sharpie "Sneakeasy" and other projects)
> B-24 Aircrew "Roger the Lodger":http://www.alaska.net/~fritzf/B24/
> Joe's HomeSchool Project - Blending Aviation and Computer
Technologies in
> an Elementary Setting:
http://www.alaska.net/~fritzf/Aviation/FlightSchool/
Yes, you can glue MDO just fine without sanding off the paper - where I
sanded the paper off I was gouging out a "hole" so the layers of glass
--Fritz
Fritz Funk
Joe's HomeSchool Project - Blending Aviation and Computer Technologies in
an Elementary Setting:http://www.alaska.net/~fritzf/Aviation/FlightSchool/
--Fritz
>Can you glue MDO without sanding off the paper? Epoxy or PL? What01930, Fax: (978) 282-1349
>about fiberglass butt splices? Fritz Funk sanded off the paper. Also
>hull, just the seams? Does anyone have any experience with this? It
>Charles
>- add your comments at the TOP and SIGN your posts, snip all you like
>- To order plans: Mr. Philip C. Bolger, P.O. Box 1209, Gloucester, MA,
>- Unsubscribe:bolger-unsubscribe@yahoogroups.com----------------
Fritz Funk
Charles
Charles
