[bolger] Re: Desert river canoe design recommendations?
Jeff:
I'm with Richard on this one. You have to have some lumber (1x2's) for the
chines and gunwales. This is really no big deal, most lumber yards will
carry this size, so you shouldn't have to do any ripping. I wouldn't insist
on epoxy, though. Try the polyurethane in a tube.
Take a look at Fritz Funk's Wacky Lassie:
http://www.alaska.net/~fritzf/Boats/Wacky_Lassie/Wacky_Lassie.htm
If you read to the bottom, you will see that he has gone to external chine
logs for this boat because of the ease of construction.
Are you still planning on building that Idaho?
Chuck Leinweber
http://www.hilconet.com/~dworksmg
To: <bolger@egroups.com>
Sent: Sunday, January 16, 2000 10:12 PM
Subject: [bolger] Re: Desert river canoe design recommendations?
> Jeff West wrote:
> > Is it possible to create such a beast out of just ACX and WeldWood with
> > no lumber at all?
> Not really, use lumber for chine logs.
> > Is no epoxy and glass, even on chines possible?
> exterior chine logs, you could get away with it. Best to use epoxy
> though, you wouldn't need that much and it's much more forgiving.
> > Is painting even neccessary?
> Not realy, no exposed epoxy to deteriorate in the sun, no paint needed.
> Be sure to use but blocks.
> > So I guess what I need are suggestions for the design of a
> > controllable, cartopable, one man and gear mini Ark design!
> Lots of potential designs, I'm partial to the pirogue, out of 3/8
> exterior fir, but blocks, exterior chine logs, epoxy glue, no paint.
> Bang it up for a season, then give it away.
> Make it as long as is reasonable.
> Richard
> Spelling|richard@...|http://www.spellingbusiness.com
> SBE Communications, Business Solutions for the next Millennium and
> Beyond!
> Boat building projects:http://www.spellingbusiness.com/boats/
> For the fastest and easiest way to backup your files and, access them from
> anywhere. Try @backup Free for 30 days. Click here for a chance to win a
> digital camera.
>http://click.egroups.com/1/337/5/_/3457/_/948089794/
> no lumber at all?
Richard
Beyond!
oops,
http://www.friend.ly.net/~dadadata/short/sci_am/scow_1876.html
>From: "Jeff West" <jeffwest@...>
>To:bolger@...
>Subject: [bolger] Desert river canoe design recommendations?
>Date: Sun, Jan 16, 2000, 10:43 PM
> Hi all,
> Here in Arizona we have some rivers that flow year round, flowing more
> during some months than others. Most of the time, like following March
> after the snow melt-off in the high country, one would drag bottom and
> bang around rocks between pools at 75-150 fps. None-the-less, I would
> like to throw something together for camping and such during those
> shallow times. Plastic is awsome stuff but "I don't want to".
> My thoughts gravitate towards a double paddle six-hour cajun canoe type
> of thing, but that seems too fragile, time consuming and expensive for
> this level of rough duty. What about a 2' wide plywood version of a
> scow like athttp://www.friend.ly.net/~dadadata/short/sci_am/scow_1876.
> html or a beefed up version of the pirogue athttp://www.unclejohns.com
> ? I could handle a single season of use out of a design, to be
> replaced with a new one each spring. Thus, the less expense the better.
> no lumber at all?
> Any ideas, ye creative problem solvers?
> Thanks,
> Jeff
> digital camera.
>http://click.egroups.com/1/337/5/_/3457/_/948087842/
> -- Talk to your group with your own voice!
> --http://www.egroups.com/VoiceChatPage?listName=bolger&m=1
Hi all,
no lumber at all?
