Re: stainless screw source
Actualy, the screws I like best are drywall screws, the sharp point
lets you poke it into the wood enough so the screw stays there and
you don't need to hold it to run it it. Haven't seen drywall screws
in stainless...
I don't like regular wood screws, I have issue with them, and don't
like the unthreaded portion on the top. (just being picky I guess)
All in all, Chuck's "sheet metal" screws are a good compromise. Plus,
you can't beat the price.
in stainless...
--- In bolger@y..., "lewisboats" <numbaoneman@b...> wrote:
> Only problem I've found with them is that they are Sooooo coarse,
> about 1/3 less threads per inch than reg wood screws. In thin
stuff,
> this sometimes allows the threads to strip out the holes (less
turns
> in the wood). 1/4" is especially vulnerable, also they like to
split
> pine alot. Because they go in farther per turn, its easier to split
> the wood, hole or no hole. Using hefty screws in hefty stock, they
> are great. They _ARE_ Deck screws, after all.
> --- In bolger@y..., "rlspell2000" <richard@s...> wrote:
> > I use them when I can. Bought a couple of 1lb boxes on sale
awhile
> > back for $7 each.
> > The only length I've found them in 1-5/8". A bit long for what I
> need
> > them for.
> > --- In bolger@y..., David Ryan <david@c...> wrote:
> > > Suddenly everywhere I look I'm seeing square drive stainless
> steel
> > > deck screws. In particular, the Despot has them cheap. Seems
like
> > > they'd be great for clamping/fastening, then leaving in.
> > > Am I overlooking something?
> > > YIBB,
> > > David
> > > >Don't know if you guys know about this, but Chuck is selling
> > > >stainless steel screws on his website for about HALF of the
best
> > > >price I've seen them for....
> > > >Just bought 1000 for $25
> > > >http://www.duckworksmagazine.com/store/store.htm
> > > >Bolger rules!!!
> > > >- no cursing, flaming, trolling, spamming, or flogging dead
> horses
> > > >- pls take "personals" off-list, stay on topic, and punctuate
> > > >- add your comments at the TOP and SIGN your posts, snip all
you
> > like
> > > >- To order plans: Mr. Philip C. Bolger, P.O. Box 1209,
> Gloucester,
> > > >MA, 01930, Fax: (978) 282-1349
> > > >- Unsubscribe: bolger-unsubscribe@y...
> > > >Your use of Yahoo! Groups is subject to
> >http://docs.yahoo.com/info/terms/
> > > C.E.P.
> > > 134 West 26th St. 12th Floor
> > > New York, New York 10001
> > >http://www.crumblingempire.com
> > > (212) 247-0296
about 1/3 less threads per inch than reg wood screws. In thin stuff,
this sometimes allows the threads to strip out the holes (less turns
in the wood). 1/4" is especially vulnerable, also they like to split
> I use them when I can. Bought a couple of 1lb boxes on sale awhile
> back for $7 each.
need
> them for.
steel
> > deck screws. In particular, the Despot has them cheap. Seems like
> > YIBB,
> > David
> > >stainless steel screws on his website for about HALF of the best
> > >Bolger rules!!!
horses
> > >- add your comments at the TOP and SIGN your posts, snip all you
> like
Gloucester,
> > C.E.P.
> > (212) 247-0296
back for $7 each.
The only length I've found them in 1-5/8". A bit long for what I need
them for.
back for $7 each.
them for.
> Suddenly everywhere I look I'm seeing square drive stainless steel
> YIBB,
> David
> >Bolger rules!!!
> >- no cursing, flaming, trolling, spamming, or flogging dead horses
like
> >- To order plans: Mr. Philip C. Bolger, P.O. Box 1209, Gloucester,
> C.E.P.
> (212) 247-0296
(212) 247-0296
>Don't know if you guys know about this, but Chuck is sellingC.E.P.
>- add your comments at the TOP and SIGN your posts, snip all you like
(212) 247-0296
