RE: [bolger] Wire connections
I am told that GE Silicone II is neutral chemistry - good for electrical
connections. Also, two-part silicone formulations do not have acidic
by-products.
-Bill
_______________________
Bill Kreamer, President
Sol-Air Company
129 Miller St.
Belfast, Maine, U.S.A. 04915
Tel 207-338-9513
Fax 208-978-7839
Emailkreamer@...
Sent: Saturday, March 09, 2002 10:48 AM
Subject: RE: [bolger] Wire connections
There is a "neutral chemistry" silicone, suitable for electronics. Can
anyone tell us the name & source?
-Bill
Sent: Saturday, March 09, 2002 4:02 AM
Subject: [bolger] Wire connections
I have been following the posts about lighting and would like to pass
on an incident about sealing connections. While in the Navy working
on jet aircraft I had an idea to replace the compound used to seal
electrical connections with silicone sealant. I was sent to North
Island rework facility to see what the engineers thought about it as
my Chief thought it was workable. The engineers and a chemist showed
me how one of the agents used in the cureing process actually
disintegrated the soldered connections. That is acetic acid. It has
an affinity for soldered connections.
Thought I might pass this on before someone has a problem with
connections down the road.
Yahoo! Groups Sponsor
<http://rd.yahoo.com/M=215002.1818248.3328688.1261774/D=egroupweb/S=1705
065791:HM/A=847665/R=0/*http://ads.x10.com/?bHlhaG9vbW9uc3RlcjcuZGF0=101
5665096%3eM=215002.1818248.3328688.1261774/D=egroupweb/S=1705065791:HM/A
=847665/R=1>
A shot of a fluid film corrosion inhibitor at every connection
couldn't hurt. Rust Check available in CTC stores in Canada, ACF 50
from Lear Chemical Research, or Corrosion Block avail. from West
Marine will both prevent verdigris (the coppery green corroison) in
all your electrics.
I'll put a film on the full length of Riff-Raff's mast wires before I
slide em in and I always apply a little at every electrical fitting
on any boat I own. Works great.
Bruce Hector
There is a �neutral chemistry� silicone, suitable for electronics. Can
-Bill
=847665/R=1>
