Re: motor mounting board rake, why?
Incidentaly, this guy LIED.
The motor bracket DOES NOT go "negative" as described. At the lowest
setting there is still "positive" rake. I.E., if mounted on a
vertical transom, the bottom of the motor would be aft of the mount
point.
Glad I bought from the OTHER guys!
Means I need to make an angled mount. Will cast a couple of wedges
out of Al...
--- In bolger@y..., "rlspell2000" <richard@s...> wrote:
> reply from www.outboardsonline.com
> Hello,
> Thanks for your email. To answer your question, no the drive shaft
> would NOT be parallel with the transom mounting bracket. Tohatsu
> Nissan motors are designed with slight "negative trim" which allows
> them to tuck under just a bit. However, there is a mounting
> positioning pin which you could adjust to have the shaft positioned
> straight up and down with no variation either way. Please let me
know
> if you have any other questions.
> Thank you,
> Chris Collins
> National Sales Manager
> www.onlineoutboards.com
> --- In bolger@y..., <boatbuilding@g...> wrote:
> > > The motor mount cross board in the motor well on the Chebacco is
> > > offset on a bracket so the board is not vertical but raked aft.
> > > Why?
> > Most sterns for outboards have at least a 10 degree rake back.
> Outboards
> > are built with this in mind. I was told once that it's to allow
> the motor
> > help lift a boat on to a plane or at least keep her nose from
> digging in.
> > My Tanaka worked okay on the Frolic with a vertical motor board
> because the
> > boat with it's rocker, would force the nose up. You may have the
> same
> > thing with the yours. Probably would not hurt a bit to build it
> verticle
> > especially on a sailboat with lot's of rocker.
> > On flat skiff, I believe I would put it at the angle designed.
The
> Wyo
> > wants a 10 degree angle back on the transom. I wouldn't want to
> make it
> > less on that long of a flat bottom boat, maybe more!.
> > Jeff
--- In bolger@y..., "roue20ca" <amoore@h...> wrote:
> Nothing wrong with sloops, they provide a nice clean leading edge
> help improove air flow around the main mast. Oh yes; if you have a
> self tacking jib, which can be a club footed jib or a more modern
> version like the soling class uses tacking can be a simple easy
thing.
> I have a question for someone though; why do you not see jibs on
> luggers very often, if ever. Is it the obvious conflict with the
part
> of the boom and gaff extending forward of the mast.
> Andy Moore
> Nova Scotia
> Canada
> > What's wrong with sloops? Some are beautiful in both looks and
> > performance. I prefer a cat ketch for a knockabout boat with
> > minimum rigging and ease of handling but sloops are fine in their
> > element.
No jib because you need the standing rigging to keep the headsail
luff tight. Right.
I prefer the gaff myself. More strings to play with, and you don't
have a "bad tack".
part
> Andy Moore
> Nova Scotia
> Canada
> Andy: I'd say it is mainly because lugsails are the ideal sail
for short unstayed masts. No stay, no jib.
> Chuck
luggers very often, if ever. Is it the obvious conflict with the part
Andy Moore
Nova Scotia
Canada
Andy: I'd say it is mainly because lugsails are the ideal sail for short unstayed masts. No stay, no jib.
Nothing wrong with sloops, they provide a nice clean leading edge and
version like the soling class uses tacking can be a simple easy thing.
Andy Moore
Nova Scotia
Canada
> element.
I'm not a snob, I'm a slob!
Obviously, you haven't had the same experiences I've had, such as a
consistent preference on the part of the glass and steel icons of
conspicuous consumption to anchor directly off the one tiny private
dock on a half mile stretch of shoreline, or the need to jam a cove
with boats even though the wind was 3 knots all night. Or my friend
who was always sneered at when he wanted to race against these guys
(they really had to up the handicap when they realised he was faster
than he looked to them).
Anyway, it is my belief that people with too much money shouldn't wave
it in other people's faces, and if they do, it should be on
unique objects of beauty instead of ugly mass-produced products from
industrial designers. Besides, stories I've heard from inside a
boatshop would make me nervous to take one of these things beyond
quick reach of the Coast Guard without a thorough inspection and
refit.
When I look at a boat with all this stuff, it seems to me that it's
all selected to be the most expensive method possible, except where
it's important but won't show.
--- In bolger@y..., "tom28571" <harbinger@c...> wrote:
snip
minimum
> rigging and ease of handling but sloops are fine in their element.
> If what you have will not stand on it's own, knocking the other
guy's
> boat is not going to improve your position. A snob is a snob, no
> matter which direction the snobbery is directed.
> snip
the real reason is that the motor can be trimmed in to compensate for
all the beer and pretzels us skiff types put in our bows.
> Outboard engines are designed to operate mounted on a board or
> transom raked 11 degrees. It gives a range of propeller thrust
angle
> above and below horizontal to allow for triming the boat out for
> various reasons. Mounting the motor on a vertical transom will
> likely make the propeller ventilate or push the bow up although
small
> engines may get away with it.
minimum
guy's
> > Why?
> > Would'nt it be much easier to make it vertical?
> > Instant poll, people with boats with motor/slop wells. Motor
> mounting
> > board, vertical, or raked backwards in plans? How did you make
it?
> > What do you think the reasoning was?
> > I'm thinking, raked back, motor business end would be lower when
> > motor was tilted up. Also, motors are designed for verticle
transom
> > planing boats, so they tilt up 90 degrees.
> > I'm thinking just attach mounting board to reinforced corners on
> > transom, making it bolt upright, and forget about it.
> > Thoughts anyone?
transom raked 11 degrees. It gives a range of propeller thrust angle
likely make the propeller ventilate or push the bow up although small
performance. I prefer a cat ketch for a knockabout boat with minimum
If what you have will not stand on it's own, knocking the other guy's
> Why?
mounting
> board, vertical, or raked backwards in plans? How did you make it?
> motor was tilted up. Also, motors are designed for verticle transom
> Thoughts anyone?
I think if you check you will find that outboard motors are built for
angled transoms. 17 degrees sticks in my mind?!
hal, who saw water in liquid form on a street today at last.
Hello,
would NOT be parallel with the transom mounting bracket. Tohatsu and
straight up and down with no variation either way. Please let me know
Thank you,
Chris Collins
> > Why?
Outboards
the motor
digging in.
because the
same
verticle
> On flat skiff, I believe I would put it at the angle designed. The
Wyo
make it
> Jeff
Maybe so. Have to ask the motor sellers.
Still, it would seam a wedge shaped board (with a 10 degree bevel
would be easier than brackets.
Or, even, two wedges to fit under the board where it mounts.
> > Why?
Outboards
the motor
digging in.
because the
same
verticle
Wyo
make it
> Jeff
> Why?
Most sterns for outboards have at least a 10 degree rake back. Outboards
are built with this in mind. I was told once that it's to allow the motor
help lift a boat on to a plane or at least keep her nose from digging in.
My Tanaka worked okay on the Frolic with a vertical motor board because the
boat with it's rocker, would force the nose up. You may have the same
thing with the yours. Probably would not hurt a bit to build it verticle
On flat skiff, I believe I would put it at the angle designed. The Wyo
wants a 10 degree angle back on the transom. I wouldn't want to make it
Why?
Instant poll, people with boats with motor/slop wells. Motor mounting
Thoughts anyone?
