Re: Transom w/ a double rake
John,
Meditating on this all evening, I finally have my own
amateur's theory to add to yours:
The angle breaks up the suction inherent in a more normal,
flat transom. As the water starts to climb it hits the apex
and is rolled down and back.
Possible?
Possible?
John Bell wrote:
> You know, I've looked at that for years and never thought
> much about it. I
> like the idea since it gives a tiny bit more displacement
> to float that
> heavy motor. Elegant! Thanks for pointing that out!
> JB
> From: "Mark Albanese" <marka@...>
> Sent: Sunday, March 31, 2002 9:24 PM
> Subject: [bolger] Transom w/ a double rake
> | The handsome little outboard motor canoe, chapter 14
> BWAOM,
> | has a transom I've not seen anywhere else.
> | It's in two parts, with a small wedge at the bottom that
> | extends beyond the motor board proper and having a more
> or
> | less reverse angle to the upper part. While as a trim
> tab
> | this wouldn't seem to me to add much, it makes the
> building
> | a lot more tricky and prevents the motor tilting any
> further
> | down than plumb.
> | z
> | z
> | z
> | z
> | z
> | z
> | z
> | zzzzzzzzzzzzzzzzz
> | This is a craft to hit 15 kts w/ 8 hp.
> | No discussion in the text. Any ideas on this?
> | Mark
> | Bolger rules!!!
> | - no cursing, flaming, trolling, spamming, or flogging
> dead horses
> | - pls take "personals" off-list, stay on topic, and
> punctuate
> | - add your comments at the TOP and SIGN your posts, snip
> all you like
> | - To order plans: Mr. Philip C. Bolger, P.O. Box 1209,
> Gloucester, MA,
> 01930, Fax: (978) 282-1349
> | - Unsubscribe:bolger-unsubscribe@yahoogroups.com
> | Your use of Yahoo! Groups is subject to
> Yahoo! Groups Sponsor
> ADVERTISEMENT
> dead horses
> punctuate
> all you like
> Your use of Yahoo! Groups is subject to the Yahoo! Terms
> of Service.
The handsome little outboard motor canoe, chapter 14 BWAOM,
extends beyond the motor board proper and having a more or
less reverse angle to the upper part. While as a trim tab
this wouldn't seem to me to add much, it makes the building
a lot more tricky and prevents the motor tilting any further
down than plumb.
z
z
z
z
z
z
z
zzzzzzzzzzzzzzzzz
down than plumb.
z
z
z
z
z
z
z
zzzzzzzzzzzzzzzzz
You know, I've looked at that for years and never thought much about it. I
like the idea since it gives a tiny bit more displacement to float that
JB
JB
| down than plumb.
| z
| z
| z
| z
| z
| z
| z
| zzzzzzzzzzzzzzzzz
| Mark
| Bolger rules!!!
| - pls take "personals" off-list, stay on topic, and punctuate
