Re: [bolger] A New Shoe
I have always thought of the exterior stringers as expendable wear
strips. I made the mistake of permanently attaching them on one boat,
and repairing them was a lot harder than removing and installing new
ones would have been if I had planned it that way originally. If you do
choose to protect them, than you might consider some high density
plastic from McMaster. Back in my dog mushing days I put three thousand
miles on one sled in a winter, and the plastic runners were still good
to go at the end of the season.
David Ryan wrote:
> FBBB --
> Well I finally got my septic system flowing again and rewarded myself
> by getting out the grinder and prepping the LSME for a new paint
> job.She had a bunch of barnacle feet that needed to be ground off and
> the paint needed to be scuffed up to prepare it for a fresh coat.
> The glass and epoxy did a fair job of protecting the wooden
> stringer/shoe that run up the middle of the boat, but I suspect
> there's someone on this list who's come up with something better.
> Any tips?
> YIBB,
> David
How about Trex for the shoe? Won't rot. Doesn't need paint or glass
but will take either.
hal, where the ground is beginning to show in Northern Utah.
I put a shoe on the bottom of my glassed over keel using 1/4 x 2 inch oak,
glued with thickened epoxy. This has survived two years of trailer use, and
the occasional beaching. I used oak because I had the strips in the scrap
pile, another hard wood would probably do. I used epoxy since I was still
building when I added the shoe, if I was adding it later I'd use 5200 or
another polyurethane adhesive.
Congrats on fixing the septic system -- been there, done that, threw away
the T shirt!
Jamie Orr
Sent: March 14, 2002 5:55 PM
Subject: [bolger] A New Shoe
FBBB --
Any tips?
C.E.P.
415 W.46th Street
New York, New York 10036
(212) 247-0296
Try adding a bottle (an once or two) of powdered Cayenne Pepper to
your final colour paint and have the store shake it up. Up here it
keeps zebra mussels off, might work on barnacles too.
Bruce Hector
www.brucesboats.com
I've seen shoes clad with metal or protected by rubber strips. These
need to be fastened by some sort of tabs or flanges to the sides of
the shoe, not directly into the face, since the fastener heads would
wear off and let the strip separate. Don't remember where, but I saw
one case where a guy used a dock bumper.
Tom Pannell
> FBBB --
myself
> Any tips?
> YIBB,
> David
> C.E.P.
> 415 W.46th Street
> (212) 247-0296
Hey, David:
One idea would be to use a sacrificial shoe. Glass the bottom flat (with no shoe) and paint it, then use 3m 5200 to attach an unfinished 2x4 shoe to the bottom. Leave the shoe unfinished. (Don't use epoxy to so this, as it won't hold wood that gets wet) You can replace the shoe periodically.
I'm not sure if this answers your question or not - it's been a long day.
chuck
FBBB --
Any tips?
C.E.P.
415 W.46th Street
(212) 247-0296
FBBB --
Any tips?
C.E.P.
415 W.46th Street
(212) 247-0296
