[bolger] Re: cutting bulkhead openings?
You might want to try a special blade in your sabre saw. I got some at
Sears a long time ago. I have one left, and it has the number 28761 on it.
I don't know if they still sell them. It makes the cleanest cuts in plywood
you can imagine.
Regards, Kevin Fitz-Gerald
To:bolger@egroups.com<bolger@egroups.com>
Date: Tuesday, August 31, 1999 1:15 PM
Subject: [bolger] Re: cutting bulkhead openings?
>I might as well jump into this: Coat the ply with epoxy before cutting,
>then cut with jug saw with fine blade about 1/16" away, sand to line.
>Chuck
>----- Original Message -----
>From: <harding2@...>
>To: <bolger@egroups.com>
>Sent: Monday, August 30, 1999 5:56 PM
>Subject: [bolger] cutting bulkhead openings?
>> Plans for the folding schooner call for round cut outs for the
>> bulkheads about9" in radius. Noticed the absolutely clean cut outs on
>> GHC's Light Schooner. I have an old Sears sabre saw and have been able
>> to do a relatively neat job on the bilge cut outs with a nice new
>> makita blade but I am daunted by these big holes. I figure I can lay
>> them out with a string but am worried about how to get a clean cut. Any
>> advice would be appreciated.
>> Leander
>> eGroups.com home:http://www.egroups.com/group/bolger
>>http://www.egroups.com- Simplifying group communications
Leander - I forgot, are you building a schooner? If so, instead of cutting
the holes to plan, you ought to think about cutting them for sealing deck
plates for the extra flotation. It might make the difference between
bailing on the water and dragging to the beach to bail (see my site).
Gregg
At 03:05 PM 8/31/1999 -0700, you wrote:
>Hi Leander - I've cut a 8" radius "hole" in a 10 mm (3/8") thick ply
>bulkhead using a string, a nail and a pencil to draw the circle, a
>saber saw to do the cut and a Surform (the small one with the pulling
>action) to fair the edges. Finally, quick pass with sand paper. Took 5
>minutes total, very easy. Best, Pippo
pippobianc-@...wrote:
original article:http://www.egroups.com/group/bolger/?start=187
Any
Ok, I'll jump in too. I vote for the router approach, but you can also
use a smaller disk as your guide. Take the distance from the edge of
your router base to the router bit cutter, subtract that from the radius
of the hole you want to cut. The remainder is the radius of the circle
you want as your guide. You can make this out of wood (hole saw or
whatever) or find a round lid, metal or plastic, that is close enough.
Screw it to the center of the hole you want to cut, drill a starter hole
for the router bit, then keep the router presed against your pattern
while you cut the circle. (Whew, I got tired just describing it, maybe
the swing arm would be easier.)
djb
> Leander
> [Real Guide - MP3 of the day]
Simplicity Boats (mirror sites - if one doesn't work...)
http://members.tripod.com/simplicityboats/
http://members.xoom.com/simpleboats/
Here's my latest boat:
unicornstrings.com
> Leander
A good, fine blade with some tooth set is a start. You can also score
around your line first with a knife, cutting through masking tape is second
choice.
Gregg
>Leander
mant-@...wrote: Leander... cut you openings about 1/8 of an
inch from you line then rasp and file up to you line... then put a drum
sander in a drill and finish smooth...(or hand sand with paper wrapped
around a round piece of PVC or closet rod) it is a lot more work this
way but ... you can finish to you line ( making sure that you line is
just the way you want it first) ... chris
Any
> Leander
Leander
Make a radius arm, circle cutting jig for your router. Use a thin strait
cutting
bit.
> Leander
Richard
Spelling|richard@...|http://www.spellingbusiness.com
SBE Communications, Business Solutions for the next Millennium and
Beyond!
Boat building projects:http://www.sbecommunications.com/boats/index.htm
