Re: [bolger] Digest Number 936
> Message: 8
> Date: Sun, 24 Mar 2002 22:21:01 -0000
> From: "rnlocnil" <lincolnr@...>
> Subject: Re: table saw issues
> If the blade seems to bog down when you cut, maybe you need a sharper
> blade or to feed straighter. Another clue if the blade is dull is
> sawdust instead of shavings. If the teeth on the blade are reasonably
> large, you shouldn't be getting fine dust. Another clue is burn marks
> on blade and wood.
could also be a warped blade, which is more likely I think, given what
you describe and the fact that it is a very soft wood.
