RE: [bolger] scarfing birdsmouth strips
Thanks, Derek; but I can't see the image - it gives me the little box with
red 'x' inside. Anybody know what's up with this? I can see the other images
in that folder....
Paul
> -----Original Message-----
> From: Dawn and Derek [mailto:dgw@...]
> Subject: [bolger] scarfing birdsmouth strips
> Hi Paul
> In the building tips folder in Bolger 2 I've placed a small image
> of the jig
> I knocked together for scarfing out knots from the Doug.Fir for our Micro
> mast.
> The unholy offspring of the scrap lumber pile, it is easy and
> accurate. One
> clamp holds the strip (usually a longer bit than the example in
> the picture)
> and the red wedge keeps the other end from moving until after the
> blade has
> passed.
> Although I use the table saw to rip birdsmouth strips, taper them and cut
> the birdsmouths (much less sawdust than using router bits, IMO) I find it
> easier to cut the scarfs with the strip stationary.
> Cheers
> Derek
Hi Paul
In the building tips folder in Bolger 2 I've placed a small image of the jig
mast.
The unholy offspring of the scrap lumber pile, it is easy and accurate. One
clamp holds the strip (usually a longer bit than the example in the picture)
and the red wedge keeps the other end from moving until after the blade has
passed.
Cheers
Derek
