Re: Sneakeasy Launch Day
Thanks Paul
It's good to know someone on the group is from the Portland area!
Perhaps we can connect out in the bay sometime!
Steve Bosquette
--- In bolger@y..., "prthober" <prthober@p...> wrote:
> What a nice looking boat! I wish I had seen you out there on the
> harbor - I was slaving away inside on my own boat over at Portland
> Yacht Services. I hope you enjoy Katie.
> All the best,
> Paul
> --- In bolger@y..., "sneakeasy2000" <sbosquette@c...> wrote:
> > Hi Group
> > Today was launch day for my Sneakeasy "Katie" All went well I
> > motored about Portland, Me Harbor for about 3 hours. What A
Hoot!!
> > my website is updated with launch photos:
> >http://www.geocities.com/sneakeasy2000/index.html
> > I also added photos to Bolger2,Files,Sneakeasy.
> > Steve Bosquette
All the best,
Paul
> Hi Group
> motored about Portland, Me Harbor for about 3 hours. What A Hoot!!
> Steve Bosquette
Sounds superb!
Thanks Tom,<BR>
I was very pleased with the handling.  When I
first put her in the <BR>
water and went across the harbor her bow seemed to
plow a little.  I <BR>
Find, Connect Date!http://personals.yahoo.ca
Steve,
Congratulations!!! Your boat is a beauty!!!
About your outboard, if it coughs and dies it could be that the idle
mix is too lean at idle. Outboard carbs do not have an accelerator
pump and if the idle mixture is too lean they will not accelerate.
Try opening(richening) the idle mixture knob a small amount.
Hope this helps,
Larry
> Thanks Tom,
> I was very pleased with the handling. When I first put her in the
> water and went across the harbor her bow seemed to plow a little.
I
> needed to set the tilt on the motor with the propeller in the aft
> most position and it made all the difference. The transom on the
> Sneakeasy is at quite an angle. Other than that she makes no wake
> speak of, it seemed to be 2 or 3 inches high. It left me with a
> dilema in that the inner harbor is a "No Wake" zone. I was doing
12
> knots but making no appreciable wake!! What is a guy to do??? Slow
> Down???? I just couldn't!!! She was very smooth even crossing
wakes
> of other boats, just as PCB said she is so long that she traverses
> waves and hits the next one before she slams down. I poked along
at
> 6 or 8 knots and she was very smooth. She accelerates smoothly and
> seems to plane immediately!! I was very pleased. The only minor
> problem was when I opened the throttle wide open she choked,
coughed,
> and stalled! I assume that it is a carbuerator(sp) adjustment but
I
> don't know for sure. Any outboard mechanics out there with an
> answer? Max maybe? She corners quite nicely. I was concerned
based
> on what I have read of this type that she might slide in tight
turns
> but I didn't find that so. I slowed done and made a 360 maximum
turn
> and she turned in about 75 feet or so. I thought that was great!
> All in all I am thrilled with her and look forward to many days of
> fun!
> Steve Bosquette
> --- In bolger@y..., thomas dalzell <proaconstrictor@y...> wrote:
> > Looks really nice. How is the ride?
> > --- sneakeasy2000 <sbosquette@c...> wrote:
Thanks Tom,
water and went across the harbor her bow seemed to plow a little. I
Sneakeasy is at quite an angle. Other than that she makes no wake to
dilema in that the inner harbor is a "No Wake" zone. I was doing 12
Down???? I just couldn't!!! She was very smooth even crossing wakes
waves and hits the next one before she slams down. I poked along at
problem was when I opened the throttle wide open she choked, coughed,
and stalled! I assume that it is a carbuerator(sp) adjustment but I
answer? Max maybe? She corners quite nicely. I was concerned based
on what I have read of this type that she might slide in tight turns
but I didn't find that so. I slowed done and made a 360 maximum turn
fun!
Steve Bosquette
--- sneakeasy2000 <sbosquette@...> wrote:
<HR>
<html><body>
<tt>
Hi Group<BR>
"Katie"  All went well I <BR>
hours.  What A Hoot!!<BR>
my website is updated with launch photos:<BR>
<a
Hi Group
Steve Bosquette
