[bolger] Re: Micro bottom
Chuck's 100% right - my 1/4" sneakeasy bottom oil-cans like crazy - it
would scare you! The shoes don't do much to stiffen it unless they were
pretty darn stiff themselves.
I am wondering whether you might want complete the keel before glassing the
bottom. You'll be able to fillet and wrap the glass right across the
bottom and along the keel. I might them shoe after all this, I don't
know...
By the way, I encapsulated lead shot in polyester rather tha caste the
keel, then added a steel strap the full length of the bottom of the keel.
Let me know if any of that appeals to you when you get to that stage.
Gregg
know...
Gregg
>Pippo:
>Congratulations on the great buy! I'm jealous.
>Two layers. I put two layers of 3/8" ply on the Tennessee that I built, and
>sometimes I think that is not enough like when the bottom flexes going into
>a chop. In the case of the Micro, the weight will only help the stability.
>You only build a boat once, but you enjoy its good qualities, or suffer its
>short comings for a long time.
>The way I attached the second layer, was as follows: Lay down the first
>course of 3/8 ply. Next cut out the second layer so that the joints are
>staggered in relation to the first layer. Now drill 3/16" holes on 6"
>centers in each piece of the second layer. Spread lots of epoxy on both
>surfaces, position each piece, and put drywall screws all the way through.
>Be careful not to spin them out. When the epoxy starts to set up, remove
>the screws, and fill the holes. I'm sure there is an easier way to do this,
>but at least this way does work. You get the advantage of orienting the
>good sides out.
>I would put the keel batten on top of the glass.
>Chuck
>> Dear all - I'm about to start building Micro (oh yes). Luckily enough I
>> located a supplier with terrific prices on marine okoume (the equivalent
>> of 30 US$ per 4'x8' sheet, 3/8", 5 plies) which will allow me to save
>> more than 50% w.r.t. other suppliers I had contacted before. Now, I'm
>> going to use 3/8" ply and the question is: should the bottom be made
>> with 1 or 2 layers? 10 mm plywood seems strong stuff, but on the other
>> hand I'd like a very strong bottom since the boat is going to be
>> trailered a lot. A few months ago, Bernie Wolfard suggested to use 1
>> layer with the shoes (he said: double thickness would be a waste of
>> plywood). I
>> n the case of 2 thicknesses, how would you suggest to apply the second
>> layer? And what about the keel batten: should it be installed before or
>> after
>> fiberglassing the bottom? Thanks, Pippo
>> MyPoints-Free Rewards When You're Online.
>> Start with up to 150 Points for joining!
>>http://clickhere.egroups.com/click/805
>> eGroups.com home:http://www.egroups.com/group/bolger
>>http://www.egroups.com- Simplifying group communications
Pippo:
good sides out.
good sides out.
> plywood). I
> after
plywood). I
after
plywood). I
after
