Re: vacuum bagging and TiteBond II
TightBond's water resistance might be a moot issue if you seal the
mast with either epoxy or paint. The mast won't be subject to
immersion and have to just deal with spray and high humidity.
Has anyone tried the idea of vacuum bagging 3m 5200 or 5300? If you
wet the wood surfaces prior to glue up to provide adequate water for
curing and vacuum bag for pressure and not so high as to boil off the
water, would this work?
I have come to like 5200 and 5300 even though they are a bit pricey
compared to PL premium. The stuff cures tougher than a skateboard
wheel and anytime I had to clean it off of wood after it cured
involved removing wood. The stuff is tenacious and tough with a fair
amount of setup time. Although I wonder about creep/cold flow.
I didn't write the quote it was a WEST engineer.
--- rnlocnil <lincolnr@...> wrote:
<HR>
<html><body>
<tt>
Stiffness, strength, and brittleness aren't the same.
Cast iron and <BR>
steel are about the same stiffness, but most steels
are far less <BR>
brittle than the cast iron a fry pan is made from. (A
fry pan which <BR>
has been used with lead shatters when a brick is
dropped on it from <BR>
sufficient height, or at least ours did. Probably if
not used with <BR>
lead, too, but why bother?) Fiberglass is strong but
not very stiff.<BR>
<BR>
One way to look at brittleness is the crack
propagation. If the <BR>
material in failure goes through a lot of plastic
deformation after <BR>
reaching it's elastic limit (like kinking a wire), it
won't be brittle <BR>
in the usual sense. The end of a crack will open up
into a nice radius <BR>
instead of spreading.<BR>
<BR>
You can say that composites are brittle in that some
tend to fail all <BR>
at once, but in the case of fiberglass, it absorbs a
lot of energy <BR>
first, and if used as fiberglass cloth there is a
ripstop effect.<BR>
--- In bolger@y..., thomas dalzell
<proaconstrictor@y...> wrote:<BR>
snip<BR>
</tt>
<br>
<tr bgcolor=#FFFFCC>
</tr>
<tr bgcolor=#FFFFFF>
<td align=center width=470><form
action="http://rd.yahoo.com/M=194081.2053425.3521449.1829184/D=egroupweb/S=1705065791:HM/A=1046314/R=0/*http://www.ediets.com/start.cfm?code=3225"
method="get" target="_top">
<input type="hidden" name="code" value="3225"><table
border=0 cellpadding=0 cellspacing=0><tr><td
align=center><font face=arial
size=-2>ADVERTISEMENT</font><br>
<TABLE WIDTH=300 height="250" BORDER=0 CELLPADDING=0
CELLSPACING=0 bgcolor="ff6600">
<TR><TD COLSPAN=2 WIDTH=300><a
href="http://rd.yahoo.com/M=194081.2053425.3521449.1829184/D=egroupweb/S=1705065791:HM/A=1046314/R=1/*http://www.ediets.com/start.cfm?code=3225"><IMG
SRC="http://us.a1.yimg.com/us.yimg.com/a/ed/ediets/06042002_300x250_orange_01.gif"
WIDTH=300 HEIGHT=102 border="0"></a></TD>
</TR><TR><TD align="right" valign="top" WIDTH=110><a
href="http://rd.yahoo.com/M=194081.2053425.3521449.1829184/D=egroupweb/S=1705065791:HM/A=1046314/R=2/*http://www.ediets.com/start.cfm?code=3225"><img
src="http://us.a1.yimg.com/us.yimg.com/a/ed/ediets/06042002_300x250_orange_02.gif"
width="109" height="147" alt="" border="0"></a></TD>
<TD align="left" valign="top" WIDTH=190
border="0"><table bgcolor="#FFFFFF" width="189"
height="147" cellspacing="0" cellpadding="0"
border="0">
<tr><td align="right"><font face="arial" size="2"
color="#CC6600"><b>Height:</b></font></td>
<td> <select name="htft">
<option value=4 >4
<option value=5 selected >5
<option value=6 >6
<option value=7 >7
</select> <font face="arial" size="1"
color="#CC6600">ft</font> <select name=htin>
<option value=0 >0
<option value=1 >1
<option value=2 >2
<option value=3 >3
<option value=4 selected>4
<option value=5 >5
<option value=6 >6
<option value=7>7
<option value=8 >8
<option value=9 >9
<option value=10 >10
<option value=11 >11
</select>
color="#CC6600">in</font></td>
</tr><tr>
color="#CC6600"><b>Weight:</b></font></td>
<td> <input type=text name=wt size=7 maxlength =
3></td>
</tr><tr><td align="right"><font face="Arial" size="2"
color="#CC6600"><b>Sex:</b></font></td>
<td> <input type="radio" name="sex"
value="female" checked>
<font face="Arial" size="1" color="#CC6600">F</font>
<input type="radio" name="sex" value="male">
color="#CC6600">M</font></td>
</tr><tr>
<td colspan="2" align="center"><input type="Submit"
value=" Submit Now "></table></td>
</tr></table></TD></TR></TABLE></form></td>
</tr>
src="http://us.adserver.yahoo.com/l?M=194081.2053425.3521449.1829184/D=egroupmail/S=1705065791:HM/A=1046314/rand=740266900"></td></tr>
</table>
<br>
<tt>
Bolger rules!!!<BR>
dead horses<BR>
topic, and punctuate<BR>
snip all you like<BR>
- Unsubscribe:
<br>
<br>
of Service</a>.</tt>
</br>
</body></html>
Games, Movies, Music & Sports!http://entertainment.yahoo.ca
<HR>
<html><body>
<tt>
Cast iron and <BR>
are far less <BR>
fry pan which <BR>
not used with <BR>
not very stiff.<BR>
<BR>
<BR>
lot of energy <BR>
ripstop effect.<BR>
> <BR>wrote:<BR>
> --- Richard Spelling <richard@c...>
snip<BR>
> You wouldn't use a flexible adhesive to bondtogether<BR>
> parts that will be under a constant heavy load.So too<BR>
> should you think twice about springing a hardwoodrub<BR>
> rail around a hull and bonding it to the surfaceof a<BR>
> flexible epoxy coating. Aside from structural<BR>eventual<BR>
> problems, creep is also a factor in the
> "print through" of an underlyingfabric's texture<BR>
> through the surface of epoxy. <BR>snip<BR>
> <BR>
> <BR>market<BR>
> Frequently, the term flexible is used to
> products that aren't very strong. Some epoxieshave a<BR>
> tensile elongation as high as 23%. Why wouldanyone<BR>
> say that flexibility is a good thing forstructural<BR>
> applications? Because flexible sounds (andsells)<BR>
> better than weak. If you're going to bond astructure<BR>
> together with a product that is not as strong asthe<BR>
> structure, that product had better be flexible!The<BR>
> flip side of the flexible coin is to describestiff<BR>
> products as brittle, a marketing gimmick thattries to<BR>
> associate stiffness with weakness. <BR><BR>
> <BR>
><BR>
</tt>
<br>
</tr>
border="0">
<option value=4 >4
<option value=6 >6
<option value=7 >7
<option value=0 >0
<option value=1 >1
<option value=2 >2
<option value=3 >3
<option value=5 >5
<option value=6 >6
<option value=7>7
<option value=8 >8
<option value=9 >9
</select>
</tr><tr>
3></td>
</tr><tr>
</tr>
</table>
<br>
<tt>
Bolger rules!!!<BR>
dead horses<BR>
- Unsubscribe:
<br>
<br>
</br>
</body></html>
<HR>
<html><body>
<tt>
Cast iron and <BR>
are far less <BR>
fry pan which <BR>
not used with <BR>
not very stiff.<BR>
<BR>
<BR>
lot of energy <BR>
ripstop effect.<BR>
snip<BR>
</tt>
<br>
</tr>
border="0">
<option value=4 >4
<option value=6 >6
<option value=7 >7
<option value=0 >0
<option value=1 >1
<option value=2 >2
<option value=3 >3
<option value=5 >5
<option value=6 >6
<option value=7>7
<option value=8 >8
<option value=9 >9
</select>
</tr><tr>
3></td>
</tr><tr>
</tr>
</table>
<br>
<tt>
Bolger rules!!!<BR>
dead horses<BR>
- Unsubscribe:
<br>
<br>
</br>
</body></html>
<HR>
<html><body>
<tt>
Cast iron and <BR>
are far less <BR>
fry pan which <BR>
not used with <BR>
not very stiff.<BR>
<BR>
<BR>
lot of energy <BR>
ripstop effect.<BR>
> <BR>wrote:<BR>
snip<BR>
> <BR>
> <BR>market<BR>
> <BR>
><BR>
</tt>
<br>
</tr>
border="0">
<option value=4 >4
<option value=6 >6
<option value=7 >7
<option value=0 >0
<option value=1 >1
<option value=2 >2
<option value=3 >3
<option value=5 >5
<option value=6 >6
<option value=7>7
<option value=8 >8
<option value=9 >9
</select>
</tr><tr>
3></td>
</tr><tr>
</tr>
</table>
<br>
<tt>
Bolger rules!!!<BR>
dead horses<BR>
- Unsubscribe:
<br>
<br>
</br>
</body></html>
<HR>
<html><body>
<tt>
Cast iron and <BR>
are far less <BR>
fry pan which <BR>
not used with <BR>
not very stiff.<BR>
<BR>
<BR>
lot of energy <BR>
ripstop effect.<BR>
snip<BR>
</tt>
<br>
</tr>
border="0">
<option value=4 >4
<option value=6 >6
<option value=7 >7
<option value=0 >0
<option value=1 >1
<option value=2 >2
<option value=3 >3
<option value=5 >5
<option value=6 >6
<option value=7>7
<option value=8 >8
<option value=9 >9
</select>
</tr><tr>
3></td>
</tr><tr>
</tr>
</table>
<br>
<tt>
Bolger rules!!!<BR>
dead horses<BR>
- Unsubscribe:
<br>
<br>
</br>
</body></html>
<HR>
<html><body>
<tt>
Cast iron and <BR>
are far less <BR>
fry pan which <BR>
not used with <BR>
not very stiff.<BR>
<BR>
<BR>
lot of energy <BR>
ripstop effect.<BR>
> <BR>wrote:<BR>
snip<BR>
> <BR>
> <BR>market<BR>
> <BR>
><BR>
</tt>
<br>
</tr>
border="0">
<option value=4 >4
<option value=6 >6
<option value=7 >7
<option value=0 >0
<option value=1 >1
<option value=2 >2
<option value=3 >3
<option value=5 >5
<option value=6 >6
<option value=7>7
<option value=8 >8
<option value=9 >9
</select>
</tr><tr>
3></td>
</tr><tr>
</tr>
</table>
<br>
<tt>
Bolger rules!!!<BR>
dead horses<BR>
- Unsubscribe:
<br>
<br>
</br>
</body></html>
Stiffness, strength, and brittleness aren't the same. Cast iron and
steel are about the same stiffness, but most steels are far less
brittle than the cast iron a fry pan is made from. (A fry pan which
has been used with lead shatters when a brick is dropped on it from
sufficient height, or at least ours did. Probably if not used with
lead, too, but why bother?) Fiberglass is strong but not very stiff.
One way to look at brittleness is the crack propagation. If the
material in failure goes through a lot of plastic deformation after
reaching it's elastic limit (like kinking a wire), it won't be brittle
in the usual sense. The end of a crack will open up into a nice radius
You can say that composites are brittle in that some tend to fail all
at once, but in the case of fiberglass, it absorbs a lot of energy
first, and if used as fiberglass cloth there is a ripstop effect.
> --- Richard Spelling <richard@c...> wrote:
snip
> You wouldn't use a flexible adhesive to bond together
> parts that will be under a constant heavy load. So too
> should you think twice about springing a hardwood rub
> rail around a hull and bonding it to the surface of a
> problems, creep is also a factor in the eventual
> "print through" of an underlying fabric's texture
snip
> Frequently, the term flexible is used to market
> products that aren't very strong. Some epoxies have a
> tensile elongation as high as 23%. Why would anyone
> say that flexibility is a good thing for structural
> applications? Because flexible sounds (and sells)
> better than weak. If you're going to bond a structure
> together with a product that is not as strong as the
> structure, that product had better be flexible! The
> flip side of the flexible coin is to describe stiff
> products as brittle, a marketing gimmick that tries to
My Dad ( a real genuine old school shipwright) always used weldwood glue
for his masts. This was long before modern glues. He always maintained
that he had 0 failures, and I know of a couple that were still going
strong after 40 years of hard driving on SF Bay. The down side is the
need for perfect close tolerance joints and good clamping pressure, easy
for him, not so easy for me and others that haven't spent their adult
life with wood working tools in their hand.
> Where are you getting your data on creep resistance of glues? Do you have a
> URL?
> TiteBond is hard when cured.
> Plastic resin (weldwood et al) glues aren't weatherproof, rain will
> eventualy wash them away.
> Doesn't resourcenol require great pressure and heat to work?
Sent: Friday, May 10, 2002 12:44 PM
Subject: Re: [bolger] vacuum bagging and TiteBond II
> The plastic resin glue I had in mind is that stuff
> that comes in powder form in a paint can, and you mix
> with water, it is hard, and totally waterproof. I
> used to use it a lot until I developed a brital
> allergy to it (though this wasn't one of the warnings
> associated with it, like epoxy). I think it was
> called Weldwood plastic resin cement, and lepages also
> had a brand. It used to be quite popular for stripper
> canoes, though eventualy easier to sand glues came
> into the forefront.
Ala Weldwood. Rain will wash it way, personal experiance and the experiance
of Michalak.
A quick perusal of some bamboo rod sites shows
interesting and somewhat contraditory results.
Titbond II breaks in scarph tests where URAC (epoxy)
does not; TII comes apart in water when wet planed.
Titebond can be easily straightened (a good thing for
rod makers, though it is creep at work bigtime) with
the application of heat, though this result is
contradicted elsewhere were it is claimed that 190 F
is required to seperate the joint, which is a low
heat anyway. Some of the fialures, it is suggested,
may be due to the user subjecting the rod/component to
actions without letting them dry for 2-3 weeks first.
The Franklin people recomend it for birdhouses, so you
gotta know its good:
http://www.titebond.com/default.asp
I don't have a URL. Do you have one for T II data?
It is based on my experience of things flying appart
and that of others, but as I say it isn't specific to
T II. I wouldn't be as concerned with plywood, but in
your use the glue joints emerge on the surface, which
means they have to be as good as the wood, if they are
highly stressed, and again, I don't know your
application in detail. I don't think R, requires
great heat etc... They use it in bamboo rods, another
interest of mine, and they just clamp those up with
string tighly wound string. I don't have Resourcenol
experience either, it always semed too expensive
compared to the size of project I had in mind, but it
holds up. Bamboo rods are not a bad correlary to your
situation since they are glued up in hexagons etc...
With joints running out to the surface. They are also
loaded reasonably hard. I don't know whether pros.
are using TII for that or not. I would be surprised if
there aren't amateurs using T II, but those rods
aren't subject to replacement if returned.
into the forefront.
--- Richard Spelling <richard@...> wrote:
<HR>
<html><body>
<tt>
glues? Do you have a<BR>
URL?<BR>
<BR>
TiteBond is hard when cured.<BR>
<BR>
weatherproof, rain will<BR>
eventualy wash them away.<BR>
<BR>
work?<BR>
<BR>
<BR>
<BR>
into the forefront.
<HR>
<html><body>
<tt>
URL?<BR>
<BR>
<BR>
<BR>
work?<BR>
<BR>
<BR>
<BR>
----- Original Message -----<BR>
<proaconstrictor@...><BR>
To: <bolger@yahoogroups.com><BR>
Sent: Friday, May 10, 2002 11:54 AM<BR>
II<BR>
<BR>
<BR>
> I can't say it will be a problem. Is it
going to be<BR>
> rigged to take bending loads? If so there
are more<BR>
> creep resistant glues, also more waterproof
glues.<BR>
> Seems as though since you are already going to a
lot<BR>
> of trouble to make this nicely, a hard epoxy,<BR>
> resourcenol glue, or plastic resin glues etc...
might<BR>
> be better. Some yellow/white glues are hard
when<BR>
> dried, and some are soft. With guitars
luthiers<BR>
> usualy choose their brand carefuly and only use
fresh<BR>
> glue on bridges (that experience modest
rigging<BR>
> loads). Some won't use this class of glue
at all.<BR>
> Having experienced gluebond failures from
well<BR>
> assembled parts, I have learned to be cautious,
the<BR>
> hard way.<BR>
><BR>
><BR>
><BR>
><BR>
><BR>
><BR>
><BR>
><BR>
><BR>
wrote:<BR>
><BR>
> <HR><BR>
> <html><body><BR>
><BR>
><BR>
> <tt><BR>
> I understand what creep is.<BR><BR>
> <BR><BR>
> What I don't understand is where creep will
become a<BR>
> problem with a birds<BR><BR>
> mouth gaff that is glued with TiteBond
II.<BR><BR>
> <BR><BR>
> ----- Original Message -----<BR><BR>
> From: "thomas dalzell"<BR>
<proaconstrictor@...><BR><BR>
> To:
<bolger@yahoogroups.com><BR><BR>
> Sent: Friday, May 10, 2002 11:13 AM<BR><BR>
TiteBond<BR>
> II<BR><BR>
> <BR><BR>
> <BR><BR>
> ><BR><BR>
<richard@...><BR>
> wrote:<BR><BR>
> ><BR><BR>
> > <HR><BR><BR>
<html><body><BR><BR>
> ><BR><BR>
> ><BR><BR>
> > <tt><BR><BR>
> > Explain. Creep
problems?<BR><BR><BR>
> ><BR><BR>
> > Let WESTies explain:<BR><BR>
> ><BR><BR>
> ><BR><BR>
> > Now you're thinking.It's not that
simple!!<BR><BR>
> ><BR><BR>
> > Well, of course not. There is a penalty
for too<BR>
> much<BR><BR>
> > flexibility. Strength and creep
resistance must<BR>
> be<BR><BR>
> > considered. In the grand scheme of
things, if<BR>
> the<BR><BR>
> > adhesive or coating is very stretchy,
creep<BR>
> (the<BR><BR>
> > movement under a constant load) can
become a<BR>
> big<BR><BR>
> > problem, and all materials will creep.
Sagging<BR>
> rafters<BR><BR>
> > have crept into that position slowly
over a long<BR>
> time.<BR><BR>
> > A bar of taffy lying on an uneven
surface would<BR>
> soon<BR><BR>
> > creep into the uneven contours of the
surface.<BR>
> What<BR><BR>
> > degree of creep or flexibility is
acceptable?<BR><BR>
> ><BR><BR>
bond<BR>
> together<BR><BR>
heavy load.<BR>
> So too<BR><BR>
hardwood<BR>
> rub<BR><BR>
surface<BR>
> of a<BR><BR>
structural<BR><BR>
the<BR>
> eventual<BR><BR>
underlying<BR>
> fabric's texture<BR><BR>
epoxy.<BR><BR>
> ><BR><BR>
> > There is a balance between allowing
more<BR>
> elongation at<BR><BR>
> > the expense of creep resistance, or
limiting<BR>
> creep and<BR><BR>
> > accepting lower elongation. It is well
known in<BR>
> the<BR><BR>
> > adhesives and coatings industry that you
give<BR>
> up<BR><BR>
> > strength and creep resistance to
increase<BR>
> elongation<BR><BR>
> > in a plastic material. This tradeoff is
important<BR>
> to<BR><BR>
> > understand.<BR><BR>
> ><BR><BR>
to<BR>
> market<BR><BR>
epoxies<BR>
> have a<BR><BR>
would<BR>
> anyone<BR><BR>
for<BR>
> structural<BR><BR>
(and<BR>
> sells)<BR><BR>
bond a<BR>
> structure<BR><BR>
strong as<BR>
> the<BR><BR>
flexible!<BR>
> The<BR><BR>
describe<BR>
> stiff<BR><BR>
that<BR>
> tries to<BR><BR>
weakness.<BR><BR>
> ><BR><BR>
> ><BR><BR>
> ><BR><BR>
> ><BR>
______________________________________________________________________<BR><BR>
<a<BR>
> href="<a
href="http://entertainment.yahoo.ca">http://entertainment.yahoo.ca</a>"><a
href="http://entertainment.yahoo.ca">http://entertainment.yahoo.ca</a></a><BR><BR>
> ><BR><BR>
> ><BR><BR>
> > Bolger rules!!!<BR><BR>
spamming, or<BR>
> flogging dead horses<BR><BR>
off-list, stay<BR>
> on topic, and punctuate<BR><BR>
your<BR>
> posts, snip all you like<BR><BR>
P.O. Box<BR>
> 1209, Gloucester, MA,<BR><BR>
> 01930, Fax: (978) 282-1349<BR><BR>
> > - Unsubscribe: <BR>
> bolger-unsubscribe@yahoogroups.com<BR><BR>
> ><BR><BR>
<a<BR>
><BR>
href="<a
href="http://docs.yahoo.com/info/terms/">http://docs.yahoo.com/info/terms/</a>"><a
href="http://docs.yahoo.com/info/terms/">http://docs.yahoo.com/info/terms/</a></<BR>
a><BR><BR>
> ><BR><BR>
> ><BR><BR>
> ><BR><BR>
> <BR><BR>
> </tt><BR>
><BR>
> <br><BR>
><BR>
> <!-- |**|begin egp html banner|**| --><BR>
><BR>
cellpadding=2><BR>
> <tr bgcolor=#FFFFCC><BR>
size="-1"<BR>
Sponsor</b></font></td><BR>
> </tr><BR>
> <tr bgcolor=#FFFFFF><BR>
> <td align=center width=470><table
border=0<BR>
align=center><font<BR>
> face=arial
size=-2>ADVERTISEMENT</font><br><a<BR>
><BR>
href="<a
href="http://rd.yahoo.com/M=194081.2053425.3521449.1829184/D=egroupweb/S=170">http://rd.yahoo.com/M=194081.2053425.3521449.1829184/D=egroupweb/S=170</a><BR>
5065791:HM/A=1036975/R=0/*<a
href="http://www.ediets.com/start.cfm?code=3225">http://www.ediets.com/start.cfm?code=3225</a>"target=_<BR>
top><img<BR>
><BR>
src="<a
href="http://us.a1.yimg.com/us.yimg.com/a/ed/ediets/stat_300x250_05.gif">http://us.a1.yimg.com/us.yimg.com/a/ed/ediets/stat_300x250_05.gif</a>"alt="<BR>
Click<BR>
> Here!" width="300"
height="250"<BR>
border="0"></a></td></tr></table></td><BR>
> </tr><BR>
> <tr><td><img alt=""
width=1 height=1<BR>
><BR>
src="<a
href="http://us.adserver.yahoo.com/l?M=194081.2053425.3521449.1829184/D=egrou">http://us.adserver.yahoo.com/l?M=194081.2053425.3521449.1829184/D=egrou</a><BR>
pmail/S=1705065791:HM/A=1036975/rand=931229179"></td></tr><BR>
> </table><BR>
><BR>
> <!-- |**|end egp html banner|**| --><BR>
><BR>
><BR>
> <br><BR>
> <tt><BR>
flogging<BR>
> dead horses<BR><BR>
off-list, stay on<BR>
posts,<BR>
1209,<BR>
282-1349<BR><BR>
> - Unsubscribe: <BR>
> bolger-unsubscribe@yahoogroups.com</tt><BR>
> <br><BR>
><BR>
> <br><BR>
the <a<BR>
> href="<a
href="http://docs.yahoo.com/info/terms/">http://docs.yahoo.com/info/terms/</a>">Yahoo!
Terms<BR>
> of Service</a>.</tt><BR>
> </br><BR>
><BR>
> </body></html><BR>
><BR>
><BR>
><BR>
> Games, Movies, Music & Sports! <a
href="http://entertainment.yahoo.ca">http://entertainment.yahoo.ca</a><BR>
><BR>
><BR>
> Bolger rules!!!<BR>
> - Unsubscribe:
><BR>
> Your use of Yahoo! Groups is subject to <a
href="http://docs.yahoo.com/info/terms/">http://docs.yahoo.com/info/terms/</a><BR>
><BR>
><BR>
><BR>
<BR>
</tt>
<br>
</tr>
border="0">
<option value=4 >4
<option value=6 >6
<option value=7 >7
<option value=0 >0
<option value=1 >1
<option value=2 >2
<option value=3 >3
<option value=5 >5
<option value=6 >6
<option value=7>7
<option value=8 >8
<option value=9 >9
</select>
</tr><tr>
3></td>
</tr><tr>
</tr>
src="http://us.adserver.yahoo.com/l?M=194081.2053425.3521449.1829184/D=egroupmail/S=1705065791:HM/A=1046314/rand=920144738"></td></tr>
</table>
<br>
<tt>
Bolger rules!!!<BR>
dead horses<BR>
- Unsubscribe:
<br>
<br>
</br>
</body></html>
Games, Movies, Music & Sports! http://entertainment.yahoo.ca
URL?
URL?
> I can't say it will be a problem. Is it going to be
> rigged to take bending loads? If so there are more
> creep resistant glues, also more waterproof glues.
> Seems as though since you are already going to a lot
> resourcenol glue, or plastic resin glues etc... might
> be better. Some yellow/white glues are hard when
> dried, and some are soft. With guitars luthiers
> usualy choose their brand carefuly and only use fresh
> glue on bridges (that experience modest rigging
> loads). Some won't use this class of glue at all.
> Having experienced gluebond failures from well
> assembled parts, I have learned to be cautious, the
> hard way.
> <HR>
> <html><body>
> <tt>
> <BR>
> What I don't understand is where creep will become a
> mouth gaff that is glued with TiteBond II.<BR>
> <BR>
> II<BR>
> <BR>
> <BR>
> ><BR>
> wrote:<BR>
> ><BR>
> > <HR><BR>
> > <html><body><BR>
> ><BR>
> ><BR>
> > <tt><BR>
> > Explain. Creep problems?<BR><BR>
> ><BR>
> ><BR>
> ><BR>
> > Now you're thinking.It's not that simple!!<BR>
> ><BR>
> > Well, of course not. There is a penalty for too
> much<BR>
> > flexibility. Strength and creep resistance must
> be<BR>
> > considered. In the grand scheme of things, if
> the<BR>
> > adhesive or coating is very stretchy, creep
> (the<BR>
> > movement under a constant load) can become a
> big<BR>
> > problem, and all materials will creep. Sagging
> rafters<BR>
> > have crept into that position slowly over a long
> time.<BR>
> > A bar of taffy lying on an uneven surface would
> soon<BR>
> > creep into the uneven contours of the surface.
> What<BR>
> > degree of creep or flexibility is acceptable?<BR>
> ><BR>
> together<BR>
> So too<BR>
> rub<BR>
> of a<BR>
> eventual<BR>
> > through the surface of epoxy.<BR>
> ><BR>
> > There is a balance between allowing more
> elongation at<BR>
> > the expense of creep resistance, or limiting
> creep and<BR>
> > accepting lower elongation. It is well known in
> the<BR>
> > adhesives and coatings industry that you give
> up<BR>
> > strength and creep resistance to increase
> elongation<BR>
> > in a plastic material. This tradeoff is important
> to<BR>
> > understand.<BR>
> ><BR>
> market<BR>
> have a<BR>
> anyone<BR>
> structural<BR>
> sells)<BR>
> structure<BR>
> the<BR>
> The<BR>
> stiff<BR>
> tries to<BR>
> > associate stiffness with weakness.<BR>
> ><BR>
> ><BR>
> ><BR>
> ><BR>
> ><BR>
> > Bolger rules!!!<BR>
> > - Unsubscribe:
> ><BR>
a><BR>
> ><BR>
> ><BR>
> ><BR>
> <BR>
> </tt>
> <br>
> </tr>
> <td align=center width=470><table border=0
> cellpadding=0 cellspacing=0><tr><td align=center><font
> face=arial size=-2>ADVERTISEMENT</font><br><a
5065791:HM/A=1036975/R=0/*http://www.ediets.com/start.cfm?code=3225"target=_
top><img
src="http://us.a1.yimg.com/us.yimg.com/a/ed/ediets/stat_300x250_05.gif"alt="
Click
> Here!" width="300" height="250"
> </tr>
> </table>
> <br>
> <tt>
> Bolger rules!!!<BR>
> dead horses<BR>
> - Unsubscribe:
> <br>
> <br>
> </br>
> </body></html>
> - Unsubscribe: bolger-unsubscribe@yahoogroups.com
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
hard way.
<HR>
<html><body>
<tt>
<BR>
<BR>
hard way.
<HR>
<html><body>
<tt>
<BR>
<BR>
II<BR>
<BR>
<BR>
><BR>
wrote:<BR>
><BR>
> <HR><BR>
> <html><body><BR>
><BR>
><BR>
> <tt><BR>
><BR>
><BR>
><BR>
><BR>
much<BR>
be<BR>
the<BR>
(the<BR>
big<BR>
rafters<BR>
time.<BR>
soon<BR>
What<BR>
><BR>
together<BR>
So too<BR>
rub<BR>
of a<BR>
eventual<BR>
><BR>
elongation at<BR>
creep and<BR>
the<BR>
up<BR>
elongation<BR>
to<BR>
> understand.<BR>
><BR>
market<BR>
have a<BR>
anyone<BR>
structural<BR>
sells)<BR>
structure<BR>
the<BR>
The<BR>
stiff<BR>
tries to<BR>
><BR>
><BR>
><BR>
><BR>
><BR>
> Bolger rules!!!<BR>
> - Unsubscribe:
><BR>
><BR>
><BR>
><BR>
<BR>
</tt>
<br>
</tr>
href="http://rd.yahoo.com/M=194081.2053425.3521449.1829184/D=egroupweb/S=1705065791:HM/A=1036975/R=0/*http://www.ediets.com/start.cfm?code=3225"target=_top><img
src="http://us.a1.yimg.com/us.yimg.com/a/ed/ediets/stat_300x250_05.gif"alt="Click
</tr>
src="http://us.adserver.yahoo.com/l?M=194081.2053425.3521449.1829184/D=egroupmail/S=1705065791:HM/A=1036975/rand=931229179"></td></tr>
</table>
<br>
<tt>
Bolger rules!!!<BR>
dead horses<BR>
- Unsubscribe:
<br>
<br>
</br>
</body></html>
What I don't understand is where creep will become a problem with a birds
> <HR>
> <html><body>
> <tt>
> Well, of course not. There is a penalty for too much
> flexibility. Strength and creep resistance must be
> considered. In the grand scheme of things, if the
> adhesive or coating is very stretchy, creep (the
> movement under a constant load) can become a big
> problem, and all materials will creep. Sagging rafters
> have crept into that position slowly over a long time.
> A bar of taffy lying on an uneven surface would soon
> creep into the uneven contours of the surface. What
> There is a balance between allowing more elongation at
> the expense of creep resistance, or limiting creep and
> accepting lower elongation. It is well known in the
> adhesives and coatings industry that you give up
> strength and creep resistance to increase elongation
> in a plastic material. This tradeoff is important to
> understand.
<HR>
<html><body>
<tt>
Now you�re thinking�It�s not that simple!!
You wouldn�t use a flexible adhesive to bond together
�print through� of an underlying fabric�s texture
understand.
products that aren�t very strong. Some epoxies have a
better than weak. If you�re going to bond a structure
<HR>
<html><body>
<tt>
understand.
Sent: Thursday, May 09, 2002 11:48 PM
| I would have thought you might get creep problems in
| that setting.
| Was thinking the birdsmouth for the gaff. Could spread
| it on all of them<BR>
| with a 3" brush in about 30 seconds.<BR>
| Bolger rules!!!
Sent: Thursday, May 09, 2002 11:46 PM
| > epoxies where I buy them.<BR>
| ><BR>
| I'm pretty sure you can thin with water.<BR>
| <BR>
| I get my T II at HD, for $15 a gallon. You get your
| epoxy cheaper than that?<BR>
| No, but its Canada here nothing is the same. Can't
| you guy get epoxy in the low 20s? In general it would
| be worth the extra bucks.
Low twenties would be worth it. Best price I've seen is low 30's, from
Fiberglass Coatings. Don't like the way it spreads, smells too, suspect it's
full of fillers.
that setting.
that setting.
epoxy you need to run the pump for 6-8 hours,
usualy,<BR>
completly set, but was<BR>
tacky enough to keep things from going anywhere. I was
just vaccing down<BR>
glass though, not laminating.<BR>
There are certainly wood jobs that are under heavy
springback pressure, like tortured deck elements. I
want the stuff hard before I turn off the presure.
With flat panels less might be fine. When I did the
largest part of my vac work I was in a shop where I
payed rent, utilities comped. I didn't want to waste
it, but I didn't worry about an hour here or there.
Since then whenever I think of the dream shop I thik
of one by a river with a natural venturi, or something
simmilar
<BR>
usualy,<BR>
> depending on temp.<BR>I've unvacced after an hour with epoxy, it wasn't
><BR>
simmilar
> epoxies where I buy them.<BR>I'm pretty sure you can thin with water.<BR>
><BR>
<BR>
Sent: Thursday, May 09, 2002 1:36 PM
> You can use it in a V bag, but it takes more pressure
> than an epoxy, generaly you need a rotary vane, or
Have an old fridge pump, if I can get it to work consistantly.
> The big advantage to yellow/white glues is that they
> only require 30 minutes or so vac pressure. With
> epoxy you need to run the pump for 6-8 hours, usualy,
> depending on temp.
I've unvacced after an hour with epoxy, it wasn't completly set, but was
tacky enough to keep things from going anywhere. I was just vaccing down
> I agree with the coment on open time issues. Does
> anyone know what you can thin T II with? That would
> take care of it, I think. The other issue with large
> pieces is that T II is more expensive than the cheaper
I get my T II at HD, for $15 a gallon. You get your epoxy cheaper than that?
Was thinking the birdsmouth for the gaff. Could spread it on all of them
Sent: Thursday, May 09, 2002 12:59 PM
> At 12:42 PM 5/9/2002 -0500, you wrote:
> >Anybody have any idea if TiteBond II will cure in a vacuum bag?
> Not sure about curing in the vac environment, but I think you'd have to be
> very quick in spreading it for a lamination job, as it gets tacky pretty
> quickly. Not much work time. -- Fritz
other simmilar high pressure pump. This part weirds
me out a bit. I build guitars too, and there,
components that come under serious pressure are oftn
assembled with glue using no clamping pressure
whatever. It opesns your eyes a bit. But as I say,
you are probably best sticking with the advice
relating to high pressure pumps. These can be old
refrigerator motors, milking machines etc... And
ventury systems.
If you want to use try a sample using a shop vac, just
take a couple of pieces of ply a foot or two square,
put them in a bag, and apply radical suck down. See
what happens. Don't be surprised if the edges of your
ply are not glue perfectly. that is normal, but
everything .5-1" in should be perfect, if indeed the
sample wored.
depending on temp.
ventury systems.
sample wored.
depending on temp.
>Anybody have any idea if TiteBond II will cure in a vacuum bag?Not sure about curing in the vac environment, but I think you'd have to be
