Re: Single handed liveaboards, Jessie Cooper, and ?
> What other designs of PB&F are intended for single-handed livingI believe we have a list member who's currently commissioning PCB
> aboard?
for just such a design, for all-weather use. I'm not sure how "out"
he is about this fact, though, so I'll let him speak up or not as
he sees fit.
IIRC, _Saghali_ (the original Breakdown Schooner) was purchased
by a single man who promptly moved aboard her, though that wasn't
her original design intent.
And, closer to home, PCB thinks that the Insolent 60 would be a
fairly spartan choice for full-time living aboard... but I'm
planning to spend a good deal of my summers aboard _Gadfly_, and
to use her as stopgap housing if I ever need to move somewhere
where I can't afford housing, until I can finish building (or
buy secondhand) a design that's better suited for the task.
-- Sue --
(and I suppose there's the Jochems, too)
Susan Davis <futabachan@...>
> I'd rather sail the AS-29 alone, it was designed forNo, the AS-29 is not the OSTAR boat. That design features a deep keel
> the OSTAR wasn't it, than step JC's mast at 100#.
and higher-aspect-ratio gaff cat rig. The hull shape is similar
though.
The idea of the A-frame tabernacle was to get the mast on-center as
much as to make it easily lowered.
As for an improved Jessie, I guess PCB thinks that the AS-29 fills
the bill, and it has been a popular design. I'm not sure how many
29's have been built, but it must be over a dozen and a couple times
the number of JC's.
--- In bolger@y..., "willers32" <mwagner@f...> wrote:
feet in length amounts to what seems like 8 more feet in usable cabin
length due to the chopped off AS-29 bow, where Jessie Cooper has a
pointy bow. I just re-read PCB critism of Jessie Cooper in Ch.69 of
MAIB "...weaknesses...not easily corrected..." no wonder he has not
updated that design, he doesn't like it.
I am curious at the relative differences in cost between these two
boats... perhaps 10 extra sheets of plywood, tabernacles, a little
more sail area.
> I am presently building an AS-29. I'll be positing some picsThe AS-29 seems like twice the boat as the Jessie Cooper. 4 more
more sail area.
boat size. I once heard of an AS-29 that was single handed from New
York to Spain and back.
For several years, I was the skipper of a classic 45' Chappelle
cutter-ketch. I single-handed her quite often. After that, an AS-29
would be a snap.
(BTW, I am presently building an AS-29. I'll be positing some pics in
a few weeks.)
>I don't know about that. Ability to singlehand has little to do with
> The AS-29 seems too big to sail comfortably alone,
would be a snap.
a few weeks.)
the OSTAR wasn't it, than step JC's mast at 100#. I
can lift 100#, but pivoting it off a nub at the end is
a fantasy for me. On the other hand, I don't much
like tabernacles. I haven't really solved this
dillemna in my own boats.
--- brucehallman <brucehallman@...> wrote:
<HR>
<html><body>
, I can imagine <BR>
lifting a 100 pound mast.<BR>
<; The AS-29 seems too big to sail comfortably <BR>
alone, and the AS-19 is too small for living
aboard.<BR>
Find, Connect, Date!http://personals.yahoo.ca
<HR>
<html><body>
aboard.<BR>
FYI Chuck Merrel, who has built a Jesse Cooper, has a proposal on his
website for a modified version he calls "Tomboy Two" and can be seen
at:
http://www.boatdesign.com/tomboy/pages/junkboy.htm
His modifications include a junk rig and a shallow fixed keel. All it
needs is a bigger doghouse and it would be a liveaboard version of
the micro navigator! Also it might be worth the effort to add the
rounded bow section that cuts out the wave slap at anchor. I would
love to stay in touch with anyone who is interested in this concept
as I too am interested in a single liveaboard. One must take into
consideration the following factors:
1. The ammount of actual sailing one is contemplating - perhaps the
marina cruiser or Fast motor Sailor may be the ticket and have a
cartopper or other daysailer tied alongside.
2. The climate one is going to live in and how much shelter one
requires.
3. the requirement to trailer it vs: live in it.
4. How far offshore one plans to goes vs: perhaps gunkholing or canal
cruising.
Of the current designs, I expect The Jochens is also a prime
candidate, particularly if one is planning to do some river or canal
cruising. I am sure Mr. Bolger might have a junk rigged version in
his files. But before bothering him perhaps Jamie Orr could give us
some information about a sailer on the west coast who built the
original Jesse Cooper - I can't recall his name off hand. Bill?
Seems to me he is in the process of building a new boat right now?
at:
requires.
cruising.
> A "sub-catagory" of Bolger sailboat designs are intended for single-
> handed live aboards. Three designs come to mind immediately,
Jessie
> Cooper, "Leeboard Catboat" of Ch.67 of BWAOM, and of course
> Resolution.
> aboard?
> ...be possible to get an on-center mast tablernacle by usingAssuming 32 lbs per CF, I calculate the Jessie Cooper's main mast
> an A-frame sort of construction at bulkhead #2.
would weigh less than 100 pound, probably less than 90 pounds.
Although a tabernacle might be possible, I don't think it would be
worth the trouble, and loss of space for the head. With a little
planning, perhaps with a temporary "A frame" device , I can imagine
The Jessie Cooper dagger board seems more ripe for modification into
pivoting leeboards, like the ones on the re-designed Fast Motor
Sailer. Also the 980 pounds of inside steel ballast bars seem to
make sense to be revised to be 98 square feet of 1/4" steel plate on
the bottom. And/or, some industrial lead acid batteries doubling as
ballast.
Wasn't Jessie Cooper [AS-25] the first of the "boxy" sharpie
sailboats. Yet, the following designs [AS-19/29/39] all seem to have
been improved by PB&F, while the Jessie Cooper has not been updated.
While [AS-25] seems be perhaps the "just right" size for single
handed live aboard uses. The AS-29 seems too big to sail comfortably
alone, and the AS-19 is too small for living aboard.
aboard?
I intend to live aboard the Chebacco that I am building, for at least
several months. However, I am sure that was not Mr. Bolger's intent.
I am modifying the cabin to make the space a bit more "liveable".
Paul
aboard?
Paul
> As an aside: Jessie Cooper, in essence, is the AS25 edition of histhis
> advanced sharpie line. Still, I am unaware of a PB&F update to
> design to include pivoting leeboards and dual rudders with bottomappears
> plates, as seems to be his tendency of late. Such an update
> obvious, but when?I was wondering whether it would be possible to get an on-center mast
tablernacle by using an A-frame sort of construction at bulkhead #2.
Access to the head would be under the "A". I can't decide if it's
possible without the "A" displacing the boom.
I think Shady Lady is a home for one. She's a far cry from Jessie.
Solution 48 was for a single man, I think. There was a Small Boat
Journal cartoon for a Singlehanded liveaboard that was very similar
to Merlin, ex-Marina Cruiser; the interior was very different.
SuperBrick? Of course, Alert, ex-Manatee, has been the home of a
single sailor.
handed live aboards. Three designs come to mind immediately, Jessie
Resolution.
aboard?
advanced sharpie line. Still, I am unaware of a PB&F update to this
plates, as seems to be his tendency of late. Such an update appears
obvious, but when?
Resolution.
aboard?
obvious, but when?
