RE: [bolger]
How does diameter of blade affect cut on a
curve?  Seems that a smaller<BR>
diameter would follow curve better.  How about
using smaller diameter blade,<BR>
say a 5" blade on saw designed for 7" blade
I don't think a small blade "follows" the line better,
it may allow cutting a tighter radius. We started out
here talking about tear-out. You can withdraw a 7"
blade so it only bears the same amount as a 5", and it
may or may not have more set, for freedom of movement
in the cut. The shallower running 7" blade should
cause less tear-out.
Overall the cutting of plywood is the easiest part of
building a boat, and any of the excellent tools
suggested will work. I still say cut just outside the
line with a sharp knife. It will stop tear-out, and
preserve any layout lines from TO erosion.
Find, Connect, Date!http://personals.yahoo.ca
How does diameter of blade affect cut on a curve? Seems that a smaller
diameter would follow curve better. How about using smaller diameter blade,
say a 5" blade on saw designed for 7" blade?
Sent: Thursday, May 16, 2002 11:50 PM
Subject: Re: [bolger]
I use both, but find the skilsaw is easier to follow a line with. When
we were cutting out the panels for three Cartoppers at once, the skil
saw was the only way to go.
Hj
Jacky Depotter wrote:
> One should always lift the blade of your skillsaw
> so that the teeth are bearly visible from below.
> This will give you not only a nicer cut, but will also
> make it easier to follow a curved line.
> But, why not use a jigsaw?
> Jacky
Yahoo! Groups Sponsor
<http://rd.yahoo.com/M=226014.2032696.3508022.1829184/D=egroupweb/S=17050657
91:HM/A=1000239/R=0/*http://ads.x10.com/?bHlhaG9vaG0xLmRhd=1021611001%3eM=22
6014.2032696.3508022.1829184/D=egroupweb/S=1705065791:HM/A=1000239/R=1>
<http://us.adserver.yahoo.com/l?M=226014.2032696.3508022.1829184/D=egroupmai
l/S=1705065791:HM/A=1000239/rand=805890986>
