Re: UHMWPE
Thanks Jeff,
Found it right away
http://www.crownplastics.com/specs.htm
I saw scads of sites describing the powder and its applications.
BTW, that the same site that I found the tape/rolls with adhesive on
one side.
Evidently there's a range of types of adhesives available also. I
don't know if any of the adhesives are suitable for marine
application but I'm a-gonna find out!
Thanks again
Jules
Found it right away
one side.
Thanks again
Jules
--- In bolger@y..., <boatbuilding@g...> wrote:
> > Hi Jeff,
> > Could you give the URL of where you saw the powder form? I'd
> > like to experiment with that
> I'm at home for the next week and I saved the link on my PC at
> work. Just do a search for "UHMW-PE powder". I used Google
> and found a lot of links but only a few mentioned mixing it
> with a "resin". Sounds like the powder is used in pressure
> forming.
> Jeff
> Hi Jeff,I'm at home for the next week and I saved the link on my PC at
forming.
I also found UMHW in rolled "tape" form with one side glue.
--- In bolger@y..., "rnlocnil" <lincolnr@m...> wrote:
> The problem with polyethylene is that nothing sticks to it. I
suspect
> it would weaken the epoxy, but of course you can try.
> --- In bolger@y..., "jeff" <boatbuilding@g...> wrote:
> > There was a thread recently about the UHMW-PE products. I did a
> search and
> > found this stuff is available in powder form.
> > Could it be mixed with epoxy?
> > Just a thought that maybe this stuff in powder form mixed with
epoxy
> and
> > fumed silica to make a "bullet proof" hull coating? Probably
not as
> good as
> > solid sheets but much better than straight epoxy.
> > Just curious.
> > Jeff
Hi Jeff,
Could you give the URL of where you saw the powder form? I'd like to
Jules
Jules
search and
epoxy and
> fumed silica to make a "bullet proof" hull coating? Probably not
as good as
> Just curious.
> Jeff
Hi,
Speaking of UMHWPE, I ran across a good source
for cut-offs of it. He has rods, tubes, squares, flat
sheets etc. All at pretty good pricing.
check them out at:
http://www.machinist-materials.com/default.htm
I bought some flat stock for laying up fiberglass butt
joints. Works great and cheap.
james Fuller
check them out at:
james Fuller
The problem with polyethylene is that nothing sticks to it. I suspect
search and
> Just a thought that maybe this stuff in powder form mixed with epoxy
> fumed silica to make a "bullet proof" hull coating? Probably not as
good as
> Just curious.
> Jeff
There was a thread recently about the UHMW-PE products. I did a search and
Just a thought that maybe this stuff in powder form mixed with epoxy and
fumed silica to make a "bullet proof" hull coating? Probably not as good as
Just curious.
Just curious.
