Re: AS19
--- Inbolger@yahoogroups.com, "Howard Stephenson" <stephensonhw@a...>
> I'd have thought 3/8" would be heavy enough for the sides, with
> double that on the bottom.
Sounds good to me.
double that on the bottom. Jessie Cooper, 25' x 7'6" and with three
times the AS19's displacement uses 1/2" ply for the sides, but with
3/4" (finished) timber cross-planks on the bottom. A lot depends of
course on the way the ply is backed with framing. As there is no
keel, the bottom has to be thick to provide the strength that a keel
normally provides, and maybe 3/4" is a bit light.
But that's just my idea. PCB doesn't make a habit of specifying
heavier construction than necessary. There is a page on this design
in Bernie Wolfard's Common Sense Design Book, where it says it's
made from "1/2" ply (alternate 1/3 or 1/4 ply)". Quarter-inch seems
a bit light.
Howard
--- Inbolger@yahoogroups.com, "graeme19121984"
<graeme19121984@y...> wrote:
>Do you recall whether PCB&F did specify all 1/2"
> plywood? Less would be cheaper.
>http://hallman.org/bolger/AS19/as19nav.gif
> shows a 'navigator cabin, cut and paste on an AS19
Thanks for that Bruce, I like it.
Wow, this is a long thread Bruce - from May 2002. Back then you
counted 30 sheets of 1/2" plywood to build AS19.
I've just looked at the Duckworks add for Michalak's JukeBox 3, a
design inspired by AS19. The specs given for JB3 are for 10 x 1/4"
ply and 11 x 1/2" ply, and that includes the extra for water ballast
tank. That is approximately equivalent to 32 sheets of 1/4" plywood,
no? Do you think AS19 would have to be built roughly twice as strong
and heavy as JB3? Do you recall whether PCB&F did specify all 1/2"
Ah, so! No, I never tried that unless I was searching back years to find a
particular post.
It does seem like it ought to be part of the introductory header.
> Roger,
> Have you tried reading the posts off the website? This is what I do
> and I don't see contact info.
> Howard
> --- Inbolger@yahoogroups.com, "Roger Derby" <derbyrm@e...> wrote:
>> What am I missing here? The fourth line of the "Bolger Rules" at
> the bottom
>> of EVERY post on this group does give the contact info.
> (978) 282-1349
Roger,
Howard
the bottom
http://www.emubo.com/e/boote/kueste/kueste.html
Something in the same general aesthetic, but not in rig.
Craig O'Donnell
Sinepuxent Ancestors & Boats
-- Macintosh kinda guy
What am I missing here? The fourth line of the "Bolger Rules" at the bottom
Sent: Wednesday, August 03, 2005 12:43 AM
Subject: [bolger] Re: AS19
> Harry,
> Not knowing whether the person who made the original post received
> emails (where contact details are shown) or read meassages off the
> Group's website (where the details are not given) I gave him a link to
> a page that would show the contact details. I've suggested before that
> it would be a good idea for the moderator to show Bolger's address
> etc. on the Group's home page.
> Howard
> --- Inbolger@yahoogroups.com, Harry James <welshman@p...> wrote:
>> How about at the bottom of this page?
> (978) 282-1349
Hi -
The ballast in mine consisted of a bout 6 bars of lead so that you don't have to handle a
big bunch at once.
While I'm thinking about it, you might want to add a tabernacle of sorts for the mast - it
was all I could do to lift it straight up all the time.
FWIW - the dog house seemed big enough to me from inside - but I'm only 5'7" or so.
There was room to sit on the porta pottie inside the doghouse.
If you really want a roomy house, go straight to the cruising Micro.
Mike
Hi Phil -
Phil & Susanne sell the plans.
I used to have one and it was a lot of fun.
http://mkstocks.tripod.com/boats/as19/
Consider using the updated leeboard (ala Martha Jane upgrade and Jochems) geometry.
Bye.
Mike
Harry,
Howard
Howard Stephenson wrote:
>Perusal of the following pages might help you find the owner of what
>might be the only AS19 built:
>http://www.ace.net.au/schooner/as19.htm
>Phil Boger and Friends would be able to sell you plans. You can find
>contact details at the bottom of this page:
>http://www.hallman.org/bolger/
>For me AS19's sugar-scoop bow looks all wrong, although it seems to
>work. The next size up is Martha Jane, a design I've always admired.
>I see on this page:
>http://www.ace.net.au/schooner/mj.htm#start
>''' that there is a modification that adds sponsons and ballast.
> Look at Jim Michalak's 19-ft boat. Very similar and perhaps simpler to build.
> Craig O'Donnell
AS19 has a mizzen sail, and Jukebox2 does not.
Though the sail rigs are quite different, I agree the
hulls are very similar.
After beating the virtual bushes for the last couple
of weeks, I'm still trying to come up with a source
for AS19 plans. Does anyone know where I can get plans
for this boat? Also, as far as I can tell, only one of
them has ever been built, does anyone know where it
is, or if there are others stashed anyplace.
Best regards,
Phil Ellis
Craig O'Donnell
>Was
> more info on the AS19 published somewhere? The only
> info I seem to be able to find on it are some pics and
> an essay on the net.
> Phil
I forget where I read this. The database shows a writeup in
MAIB; Vol 17#15-16
If you send a fax to Bolger asking about the price for the plans,
they will probably fax you back a copy of this article.
Bruce,
I wasn't aware of the ballast, but am not surprised,
considering its reputed capability. I think I'll at
least go the next step and order up some plans. Was
Phil
--- Bruce Hallman <bruce@...> wrote:
> On 8/2/05, Phil Ellis
> > Does anyone know where I can get plans for this
> boat?
> I have long wanted to build an AS19 too, facinating
> boat.
> You are aware that it has a pretty big chunk of lead
> as ballast, right?
> Manhandling a 500 pound slug of lead up and over the
> sides and down into the bilge and down into the hull
> seems tricky to me.
> I quess with some kind of winch it would be easy.
> I also have thought that the doghouse could be
> enlarged a bit and would
> turn the AS19 into a nice pocket cruiser.
Do You Yahoo!?
http://mail.yahoo.com
I see on this page:
Howard
--- Inbolger@yahoogroups.com, Phil Ellis <pcoellis@y...> wrote:
> Hi All,
> sails. Went through a similar process regarding
> whether I want to build something beautiful the first
> time out, or build simple, efficient and inexpensive,
> and settled on the latter, in paticular, the Bolger
> AS19.
> Does anyone know where I can get plans for this boat?
I have long wanted to build an AS19 too, facinating boat.
You are aware that it has a pretty big chunk of lead as ballast, right?
sides and down into the bilge and down into the hull seems tricky to me.
I also have thought that the doghouse could be enlarged a bit and would
Hi All,
I've built a bunch of kayaks, but am now ready to take
the leap to something that I can't lift onto the roof
rack by myself. After dithering over whether I want to
put up with the expense and aggravation of sails or
the expense and aggravation of sails, I've settled on
AS19.
Best regards,
Phil Ellis
Yahoo! Mail
Stay connected, organized, and protected. Take the tour:
http://tour.mail.yahoo.com/mailtour.html
> --- In bolger@y..., thomas dalzell <proaconstrictor@y...> wrote:
> > 30 sheets? that seems like an awful lot.
> Perhaps a few less if you get creative using 'cut offs'. The bottom
> uses 10 sheets; the deck five; the sides five; bulkheads four or
> five; the cabin floors, two or three; doghouse one or two; leeboards
> 3 or 4; and the footwell one.
<snip>
Wow. That's not much at all. :)
I haven't the materials list yet, but based on spec'd thickness (2
inches) of the bottom of the tandem that Im eagerly awaiting...
50' long boat
8' wide at bottom (dont you love it?)
assuming a perfectly square bottom (which it is not) you would be
using 12-13 sheets per layer (1/2" sheets) times 4 = 48 - 52 sheets
just for the bottom.
of course.. it is a 50 foot design, rather than a 19 foot design. You
really get the sense of proportion as things get bigger when you look
at materials lists. Thats something like $4500 US in ply just for the
bottom. Woo.
Then again, looking through cruising magazines, and seeing the prices
being charged for 50' boats, I am comforted. Especially since most of
them have a 4-6 foot draft. :)
Does it all have to be in one piece? What about ten fifty pound
pieces clamped down in the bilge?
--- In bolger@y..., "Derek Waters" <dgw@d...> wrote:
> >>Not sure how to handle a 500 lb piece of lead...<<
> A dolly made from construction lumber and heavy castors allowed me
to slide
> 400+ lbs of lead around. The arms holding the lead were adjustable
for
> height, and lifting power was a couple of auto jacks. Don't sweat
it.
> Cheers
> Derek
A dolly made from construction lumber and heavy castors allowed me to slide
400+ lbs of lead around. The arms holding the lead were adjustable for
height, and lifting power was a couple of auto jacks. Don't sweat it.
Cheers
Derek
Rent fork lift silly.
Sent: Sunday, May 26, 2002 10:36 PM
| I was measuring my side yard, just enough room to build an AS19.
| [pending my wife's permission.]
| Not sure how to handle a 500 lb piece of lead. The plans call for
| the boat to build upside down, after the sides and bottom go on, you
| flip it over and then somehow maneuver a heavy piece of lead into the
| bottom. I guess I would need to build some sort of gantry, and hoist
| the lead ballast with a come-a-long or some such tool.
| Bolger rules!!!
| - pls take "personals" off-list, stay on topic, and punctuate
--- brucehallman <brucehallman@...> wrote:
<HR>
<html><body>
I count that <BR>
it takes 30 sheets of 1/2" plywood.  What an
intriguing boat!  I <BR>
Find, Connect, Date!http://personals.yahoo.ca
> AS19, like Pointer needs to heel
> over very far to sail fast I think, as if the boxy scoop bow isn't
> offensive enough :).
The "point of maximum power", as PCB has called it, for a flat bottom
boat is usually near where the weather chine comes out of the water.
That would be the heel angle for fastest sailing.
As always, I am engaged in serial boat building dreams. Most
recently, I detailed and built a crude model of AS19. I count that
it takes 30 sheets of 1/2" plywood. What an intriguing boat! I
wonder just how fast it sails? I imagine painting the topside in
normal 'nautical' color scheme, and bottom in some wild 'graffiti
art' visible only when heeled over. AS19, like Pointer needs to heel
offensive enough :). I wonder if the 500 pound cast lead keel could
be switched with a scrap steel cast in place concrete slab ballast, I
think yes. I bet the whole boat could be had for less than $1,000.
[using CDX plywood, poly tarp sails and house paint.]
