[bolger] Re: Double Eagle, e-mail , but joints
Lincoln Ross wrote:
Any reason one couldn't bevel the edges of a butt strap with a plane?
If your plane is really sharp this is pretty easy to do. I shaped a
plywood rudder this way. Ought to reduce the stress concentration. Also
ought to make easier to clean, etc. Those with fancy table saw jigs
could probably do it even easier.
david jost <djos-@...> wrote:
snip The internal
> butt straps also work fine, but have tendency to collect dirt and
hold water
> where I don't want it.
>snip
GET A NEXTCARD VISA, in 30 seconds! Get rates
as low as 0.0% Intro APR and no hidden fees.
Apply NOW!
http://click.egroups.com/1/975/5/_/3457/_/949160344/
-- Create a poll/survey for your group!
--http://www.egroups.com/vote?listname=bolger&m=1
aversion to scarfs. I rough cut mine with an electic plane and finish them
with a low angle block plane. Before the electric plane I did the whole job
with a block plane. Takes about 30 minutes. I've never had on fail and I'm
no artist ! :)
Rennie
>From: "Lincoln Ross" <lincolnr@...>______________________________________________________
>Reply-To:bolger@egroups.com
>To:bolger@...
>Subject: [bolger] Re: Double Eagle, e-mail , but joints
>Date: Sat, 29 Jan 2000 07:38:46 -0800
>snip The internal
>hold water
> >snip
>Apply NOW!
snip The internal
hold water
>snip
Apply NOW!
snip The internal
> butt straps also work fine, but have tendency to collect dirt andhold water
>snip
I have built two boats a 10.5 pointy skiff out of Payson's book, and a Diablo from plans. I used the taped scarfs in the Diablo and butt straps in the Pointy Skiff. and they are absolutely as strong as the rest for the boat. I hollowed out the inside slightly with a disk grinder then put on three layers of varying widths on the inside and one on the outside. After I faired the outside and applied a layer of cloth over the entire boat, there is no bump on the outside at all. Very strong and very light. The internal butt straps also work fine, but have tendency to collect dirt and hold water where I don't want it.
Giuseppe 'Pippo' Bianco wrote:
Phil,
I made a test fiberglass/epoxy butt joint with 10 mm (3/8") plywood for
my Micro. I used biaxial cloth: 400 g/m^2 (12 oz) outside and 300 g/m^2
(9 oz) inside. In such an arrangement, the biaxial tape is stronger with
respect to normal cloth by a factor of 1.4. Actually there is no glass
thread that runs at 0 degress nor ar 90 degrees, except a light
longitudinal stitching to avoid unraveling. This cloth though is a
little bulkier that an equal weight normal cloth. I don't expect this to
be a problem though and imagine a bit of light putty and sanding would
make the joint invisible.
By the way, such a joint resulted to me both stronger and more flexible
than the plywood butt block. I used the Carnell/Payson method, i.e. I
did both sides in one time.
Best, Pippo
Phillip Lea ha scritto:
> Justin Pipkorn of Thousand Oaks, California uses a biaxial glass
tape
> for strength at butt joints. The tape is made with heavier
threads
> that go across the width of the tape and the joint for tensile
> strength. There are only very light threads that run the length
of the
> tape, which once on the boat provide only useless bulk. One could
use
> glass cloth cut in diagonal strips so that each of the fibers would
> contribute to the strength of the joint while minimizing bulk.
I have
> done this with 4 oz. cloth and it makes a very low buildup.
Total
> strength of the joint will also depend on location of skids, etc.
Get what you deserve with NextCard Visa! ZERO! Rates as low as 0.0%
Intro or 9.9% Fixed APR, online balance transfers, Rewards Points,
no hidden fees, and much more! Get NextCard today and get the credit
you deserve! Apply now! Get your NextCard Visa at:
http://click.egroups.com/1/931/5/_/3457/_/949101561/
Best, Pippo
> Justin Pipkorn of Thousand Oaks, California uses a biaxial glass tape
> for strength at butt joints. The tape is made with heavier threads
> strength. There are only very light threads that run the length of the
> tape, which once on the boat provide only useless bulk. One could use
> contribute to the strength of the joint while minimizing bulk. I have
> done this with 4 oz. cloth and it makes a very low buildup. Total
6" of snow outside -- first snow in three years. Nothing like mountain
biking in fresh snow! A little snow on the ground (6" is a little
deep) lets a mountain bike climb these Ozark hills better than the
4-wheel drives.
Phil Lea, Russellville, Arkansas
"fritz koschmann" <fritzdf-@...> wrote:
original article:http://www.egroups.com/group/bolger/?start=2070
> Yes there is a "lump" and it is approximately .025 inch at the highestThe
> point, with 6 oz cloth, and nicely tapered to zero at each edge of the
> joint because of the increasingly wider cloth strip in each layer.
> first layer is 2-3" the second 4-5" and the third 6-7". On the outside
> of the hull at least one more layer is applied overall. Regular tape
> does not work because of the selvage edge. This joint is basically
> invisible especially if you want to extend the taper a little further
> with an epoxy fairing compound but I don't think it is necessary.I
> might also mention that I saturate the end grain with resin and use
> well thickened epoxy between the butting edges when assembling the
> joint.
technical project at school, testing the various ways of joining sheets of
ply - Your method was WAY stronger than scarfing or butt blocks.
Regarding the lump - It's safe to say that after you've faired and sanded
everything, the best 'lump test' is to run your fingertips along the
surface. If you can't feel any lump, then it won't show even with gloss
paint. A French polisher showed me this trick - the fingertips are very
sensitive to the smallest irregularities.
Bill
>From: "Fritz Koschmann" <fritzdfk@...>______________________________________________________
>To:bolger@...
>Date: Thu, 27 Jan 2000 23:28:40 -0800
>joint because of the increasingly wider cloth strip in each layer. The
>joint.
>GET A NEXTCARD VISA, in 30 seconds! Get rates as low as 0.0%
>Intro or 9.9% Fixed APR and no hidden fees. Apply NOW!
>http://click.egroups.com/1/933/5/_/3457/_/949044528/
>eGroups.com Home:http://www.egroups.com/group/bolger/
joint.
> Doesn't that leave a lump on the hull?Seems to me it would. Last time around, I used an angle grinder with a
sanding disk and sanded a shallow cove about 1/8" deep and 5" wide. Cover
with a couple of layers of glass tape and resin, belt sand flush, turn
over, and repeat. I'm happy.
original article:http://www.egroups.com/group/bolger/?start=2062
> Robert Norris requested my correct e-mail address, it is:might
>fritzdfk@.... I would be glad to answer any questions anyone
> have.is
> There was a scarfing thread a while ago and I thought I might add my
> two cents.
> I started with Payson joints as described in my building guide. That
> basically butting the plywood together, running a power planer downthe
> joint and filling the "valley" with three layers of tape and epoxy.three
> This worked fairly well but the planer always left a very ragged
> surface in the 1/2" fir ply I am using. The added time fairing the
> surface before tapeing was annoying and I noticed that when breaking
> test joints they usually broke along the edge of the planed valley.
> When my planer died while shapeing the second outside bow stem I
> decided to do away with the valleys and lay up the butjoints with
> layers of cut strips (not tape) of cloth all at once starting with theDoesn't that leave a lump on the hull?
> narrowest first. This is basically the method described by David
> Carnell. The joints when finished are very hard or impossible to tell
> from the others and though I have not tested them I feel better not
> removing wood and I think the stresses are more spread out. I do one
> side at a time and then flip the panel for the other side, even on the
> fourty foot panels this isn't a problem if you have some help. PS, I
> got a new Dewalt planer for Christmas.
fritzdfk@.... I would be glad to answer any questions anyone might
have.
two cents.
I started with Payson joints as described in my building guide. That is
basically butting the plywood together, running a power planer down the
decided to do away with the valleys and lay up the butjoints with three
