Re: [bolger] Digest Number 1034 - Bottom Paint
When I first decided to keep my boat in the water {Delaware River -
Philadelphia - brackish water - algae scum rather than barnacles} I
followed the accepted practice of asking the marina people what worked
best - HERE. The boat had previously been 'drysailed' and never had the
bottom painted.
They recommended the Interlux VC-17m. Thin film, Teflon-based, almost
instant drying, and able to stand up to trailering. The 'package' came
with 3/4 of a quart of 'paint' and a container of copper powder that the
user mixed in. It amounted to 14 percent CuOx; ". . . to provide some
anti-fouling protection in fresh & low-fouling saltwater areas." Comes
in Red, Blue, and Bronze.
Didn't do squat, as far as I was concerned, about the scum. Although
'they' said it wouldn't come except by heavy sanding, I figured how to
do it with lacquer thinner. I then went to 34 percent 'Hard Modified
Epoxy' product. Somewhat better, but had to sand every year before new
application. You couldn't tell how much of the biocide was left . . . it
leached out while the color remained. I had to have the bottom
sandblasted to remove it.
I'm now using the West Marine CoPolymer Plus Ablative product - CPP. 55
percent CuOx, self-polishing, re-launchable. Harder than the traditional
soft rosin sloughing coatings, it could also stand moderate trailering
('float' on and off rather than dragging across the bunk supports}.
Define what you want to do, and what you want or expect from your
coating, in YOUR AREA. Do your research, then go at it.
Ron Magen
Backyard Boatshop
bottom painted.
Ron Magen
Backyard Boatshop
> Message: 13As for doing the the topsides with the stuff - no way! It is HEAVY! . .
> Date: Tue, 28 May 2002 22:12:38 -0000
> From: "willers32" <mwagner@...>
> Subject: Re: Bottom paint
> Even buying powdered copper isn't cheap these days; and how can you be
> sure of correct proportions? The stuff must have some kind of built in
> UV protection. . . .
