Wooden Trailer
I built one wooden trailer from plans that John Marples sold me. I
wish I had had some of the information on these rather slow loading
pages:
http://airbikesrus.homestead.com/Trailer1.html
"Uncle Bob's $50 trailer" on page five looks as though it might be
usueful.
Ford, et al --
I can't believe how well this worked. The resulting fit was no more
than a 1/16" out, probably less!
See photos at:
http://www.crumblingempire.com/gullapalooza/skegscribe01.jpg
http://www.crumblingempire.com/gullapalooza/skegscribe02.jpg
Hooray!
>David,
>With the hull upside down:
>1. Set the oak on edge in the proper position for the skeg. Tape or hold
>it so it won't shift.
>2. Hold a pencil on top of a 1 in. thick piece of wood. Put the wood on
>the hull with the pencil point touching the oak.
>3. Slide the wood and pencil along the hull so the pencil draws a line
>on the oak a little more than an inch from the hull. The line will be
>parallel to the hull's curve.
>Adjust the thickness of the piece of wood if you need a line closer to
>or farther from the hull.
>Good luck,
>Ford Walton
>David Ryan wrote:
>> FBBB --
>> I got a hunk of oak to make a skeg for my Gull, but I'm a little lost
>> on how to draw the curve of the bottom on the plank. Anyone got an
>> online step by step for scribing?
>> YIBB,
>> DAvid
>> C.E.P.
>> 415 W.46th Street
>> New York, New York 10036
>> (212) 247-0296
>> Bolger rules!!!
>> - no cursing, flaming, trolling, spamming, or flogging dead horses
>> - stay on topic, stay on thread, punctuate, no 'Ed, thanks, Fred' posts
>> - add your comments at the TOP and SIGN your posts and <snip> away
>> - To order plans: Mr. Philip C. Bolger, P.O. Box 1209, Gloucester,
>>MA, 01930, Fax: (978) 282-1349
>> - Unsubscribe:bolger-unsubscribe@yahoogroups.com
>> - Open discussion:bolger_coffee_lounge-subscribe@yahoogroups.com
>> Your use of Yahoo! Groups is subject tohttp://docs.yahoo.com/info/terms/
C.E.P.
415 W.46th Street
(212) 247-0296
> Anyone got an
1) Find the compass you used for drawing circles in High School plane
geometry. If you can't find one, you can get one at CVS or Walgreens.
2) Prop the board in approximately the right position, as best you
can without it being shaped.
3) Set compass to a likely width and drag it with the point on the
line where you want the board to sit and pencil drawing a line on the
board, holding the compass vertical all the while.
PHV
David,
Good luck,
Ford Walton
David Ryan wrote:
> FBBB --
> YIBB,
> DAvid
> C.E.P.
> 415 W.46th Street
> (212) 247-0296
FBBB --
DAvid
C.E.P.
415 W.46th Street
(212) 247-0296
