[bolger] Re: Density of lead
giuseppe 'pippo' bianco <pippobianc-@...> wrote:
original article:http://www.egroups.com/group/bolger/?start=2095
Crudely estimated slab volume from plans as 0.0166 m^3. This would
give a density of about 11 g/cm3.
Do you have any info on the aluminum tubing/pipe used in the Navigator
version of Micro?
Doug
> Just curious... lead's density is about 11. However, if you considerthe
> volume of Micro's ballast slab (0.023 m^3) and its specified weight(187
> kg), one obtains a density of about 8.2. Where's the trick? Is thePippo,
> commercially available lead doped with other materials that make it
> lighter?
> Best, Pippo
version of Micro?
Doug
Just curious... lead's density is about 11. However, if you consider the
volume of Micro's ballast slab (0.023 m^3) and its specified weight (187
lighter?
Best, Pippo
lighter?
Best, Pippo
