Re: hull fairing
I used 410 microlight compound from WEST on my Micro. It works like
David R. reported. I am quite happy with the results. Can't wait to
paint! It is ridiculously expensive, but nothing in relationship to
sails and blocks!
sails and blocks!
Diatomatious earth is way cheap at pool supply places, 11 bucks for
25 lbs which is a lot of the stuff.
It is much like white flour and flies all over the place, not toxic
at all but is not good to breathe. Masks, respirators should be worn.
--- In bolger@y..., "proaconstrictor" <proaconstrictor@y...> wrote:
> --- In bolger@y..., "lulalake_1999" <lulalake_1999@y...> wrote:
> > And speaking of fairing fillers, Has anybody used diatomatious
> earth
> > as a fairing compound filler?
> > It has much the same feel as talc, is cheaper and way more
> available
> > ( Known as "DE" in pool maintenance supplies, gardening supply
> > houses, pet supply houses) . I'm going to pick up some today and
> > experiment with it.
> > Jules
> > , DE
> Here is a quote from one of the Sneakeasy builders:
> Sneakeasy
> 26 feet long with a 4 foot beam
> This is a design by Phil Bolger of Gloucester, MA.
> Constuction is straight forward plywood, 1/2" bottom, 1/4" sides.
I
> tried to bend 1/4" fir plywood to the specified radius for the deck
> but
> substituted two layers of 1/8" mahogany doorskins instead. All
> exterior
> surfaces were covered with 9 oz. fiberglass cloth using System
Three
> epoxy resin. Where a thickener was required for fillets and
filling
> the
> weave of the sheathing, diatomite and milled fiberglass was used.
> Diatomite is swimming pool filter media. The basic hull and deck ,
> glassed and painted, weighed 475 lbs.
> My only comment is to consider not just what the powder costs, but
> what yield you get. I get enourmous yield from 410, in the 3-5
times
> epoxy volume range. It costs a lot, but epoxy wise it robably
works
> out even, depending on what grade of epox you are using.
> One thing I would like to know about diatomite is whether it flies
> all over the place, or is it orderly like 410? I don't know what
> they use as a binder in 410, if I did, and could mix my own, I can
> think of a number of uses.
Sneakeasy
Constuction is straight forward plywood, 1/2" bottom, 1/4" sides. I
but
exterior
surfaces were covered with 9 oz. fiberglass cloth using System Three
epoxy resin. Where a thickener was required for fillets and filling
what yield you get. I get enourmous yield from 410, in the 3-5 times
epoxy volume range. It costs a lot, but epoxy wise it robably works
> And speaking of fairing fillers, Has anybody used diatomatiousearth
> as a fairing compound filler?available
> ( Known as "DE" in pool maintenance supplies, gardening supplyHere is a quote from one of the Sneakeasy builders:
> experiment with it.
> Jules
> , DE
Sneakeasy
but
exterior
Thanks for the tips,
I think I'll just keep using DE in the garden and on the pets and use
for filleting.
J.
for filleting.
J.
--- In bolger@y..., "Richard Spelling" <richard@c...> wrote:
> Bitch to sand. Used it for the armor coating on the last boat.
Also, runs
> unless you add fumed silica, which is also a bitch to sand.
> Use talk or wheat flour for fairing.
> From: "lulalake_1999" <lulalake_1999@y...>
> To: <bolger@y...>
> Sent: Monday, June 17, 2002 12:48 PM
> Subject: [bolger] Re: hull fairing
earth
available
> > experiment with it.
> > Jules
> > --- In bolger@y..., "sanmi" <sanmi@y...> wrote:
> > > When I built my 15' sharpie (Michalak AF-3), I figured fairing
> > > hull was for sissies. After all, I wanted workboat finish and
who
> > > would care if there were some rough spots. I sheathed bottom
but
> > not
> > > the sides. Filling the weave with a third or fourth coat of
epoxy
> > > seemed purely optional.
> > > All those articles and chapters in the books and magazines about
> > > fairing are merely the result of some misplaced 19th century
> > yachting
> > > aesthetic that places a disproportionate value on form over
> > function -
> > > right?
> > > Wrong.
> > > After spending the weekend upside down sanding off poisonous
bottom
> > > paint from an un-filled, un-faired bottom in order to effect
some
> > > repairs to the sheathing, I've realized there is a very
practical
> > > reason for fairing and filling - repairs!
> > > Frank
> > > Wilmington, DE
posts
> > - add your comments at the TOP and SIGN your posts and
<snip> away
Gloucester, MA,
> 01930, Fax: (978) 282-1349
> > - Open discussion: bolger_coffee_lounge-subscribe@y...
for filleting.
J.
for filleting.
J.
Also, runs
> To: <bolger@y...>
earth
available
> > experiment with it.
> > Jules
who
but
> > not
epoxy
> > yachting
> > function -
> > > right?
> > > Wrong.
bottom
some
practical
> > > Frank
> > > Wilmington, DE
posts
<snip> away
Gloucester, MA,
Bitch to sand. Used it for the armor coating on the last boat. Also, runs
> And speaking of fairing fillers, Has anybody used diatomatious earth
> It has much the same feel as talc, is cheaper and way more available
> experiment with it.
> Jules
> > When I built my 15' sharpie (Michalak AF-3), I figured fairing the
> > hull was for sissies. After all, I wanted workboat finish and who
> > would care if there were some rough spots. I sheathed bottom but
> not
> > the sides. Filling the weave with a third or fourth coat of epoxy
> yachting
> function -
> > right?
> > Wrong.
> > After spending the weekend upside down sanding off poisonous bottom
> > paint from an un-filled, un-faired bottom in order to effect some
> > repairs to the sheathing, I've realized there is a very practical
> > Frank
> > Wilmington, DE
WestSystem's "Mircolight Fairing Compound" is a joy to use, but
wicked expensive. Used with slow resin, you get a drywall compound
type mud with a long open time. Sands very easily, yet seems to hold
up nicely. If I could find a cheaper substitute, I could learn to
love fairing.
-D
415 W.46th Street
New York, New York 10036
(212) 247-0296
love fairing.
-D
>My understand is it is harder to sand then the other finish fillers likeC.E.P.
>micro balloons. I believe it gets used more for fillets and as a
>thickener for gluing.
>HJ
>> experiment with it.
>> Jules
415 W.46th Street
(212) 247-0296
> experiment with it.
> Jules
experiment with it.
Jules
experiment with it.
Jules
not
yachting
function -
> right?
> Wrong.
> Frank
> Wilmington, DE
> After spending the weekend upside down sanding off poisonous bottomI agree. Also workboats if you look at them aren't necesarily
> Frank
> Wilmington, DE
scruffy. They don't waste a lot of time on nonsense, but a smooth
fair surface isn't nonsense. I try to get everything looking nice,
but I won't waste time, for instance, trying to make a wood/epoxy
boat look like it was built in a mirror polished female mold. There
are, after all, advantages to wood construction over fiberglass, so
why make one look like the other?
would care if there were some rough spots. I sheathed bottom but not
fairing are merely the result of some misplaced 19th century yachting
aesthetic that places a disproportionate value on form over function -
right?
Wrong.
Frank
Wilmington, DE
right?
Wrong.
Frank
Wilmington, DE
