Re: [bolger] screwed
WD-40. Dump 'em in an old butter tub and spray all at one time. Works
surprisingly well. I've heard that cooking spray isn't too bad either.
JB
JB
Sent: Thursday, June 20, 2002 4:40 PM
Subject: Re: [bolger] screwed
| On Thu, 20 Jun 2002, timk_smith wrote:
| > Anybody else had this problem and solved it? Is there a fail-safe
| > fastener for this kind of application?
| All it takes is rubbing the screw in wax or bar soap. Make sure the
| coating is not excessive. Both work like a champ.
In a message dated 22-06-02 12:00:13 AM E. Australia Standard Time,
richard@...writes:
resin: you can remove resin dribbles from plywood by heating them with a
heatgun and then scraping them off with a paint scraper.
Howard
richard@...writes:
>Just in case there are some who don't know another similar trick with epoxy
> I heat a screwdriver up nice and hot and do the same thing. Screwdriver
> works to clear epoxy out of the slots too, even under glass!
Howard
Hi
I started to reply to this then was interrupted, I have no idea of
where my first reply might be.
Anyway, the solution is not to use dry wall screws. Try some
flooring screws instead. They come in bulk, like drywall screws, and
are equally inexpensive. They have a yellow colour, with good sharp
threads all the way to the head, which wants a Robertson (square)
screwdrive so it never slips. I believe they are also rust resistant
for use on decks (on houses not boats) but I haven't left any in the
boat to find out how resistant.
So save the drywall screws for your next drywall job, and buy
flooring screws for the rest. They come in various lengths and can
be re-used indefinitely. I've bent them but never broken one.
Jamie Orr
Jamie Orr
--- In bolger@y..., "timk_smith" <timk_smith@f...> wrote:
> Assembling a bulkhead for Topaz, I epoxied a couple of
> one-inch-thick beams to half-inch plywood faces. Grabbed a
> handful of drywall screws and drove them in to hold the parts till
> the glue dried.
> Last night I went to back out the screws, and every one of them
> snapped--head came off, shank stayed in the wood. Because
> this is an interior bulkhead I'm not concerned; i'll just seal
them
> up and leave them in. But when it comes time to laminate the
> one-inch bottom, I really don't want this to happen.
> I haven't had this problem before, but then, my previous Bolgers
> have been smaller, and I've rarely dealt with tacking
> inch-and-a-half thick assemblies. (This is also the first time
I've
> used the hollow joint technique as described in the files, so
> there was an unusually thick layer of epoxy in there).
> The screws were generic, one-and-a-half-inch, hardware-store
> drywall screws with a silvery finish (don't know if they are
> galvanized, and I don't have the box with me).
> --tim.
Sent: Friday, June 21, 2002 6:57 AM
Subject: Re: [bolger] Re: screwed
> Just a thought. Try touching the head of the screw with the tip of a
heated soldering iron. Hold it
> there for a bit, and then back the screw right out. It has worked for me.
> Jim
> bjharbo wrote:
> > Yes, I experienced the same while laminating the one inch bottom AND
> > the 1,5 inch shoe of my William D Jochems. Abt. 20% of the screws
> > broke and I had to leave them in. I haven't thought of it as a
> > problem until I read your posting. Everything will be covered by
> > fiberglass and epoxy. Don't worry, be happy!
> > My WDJ will be launched in some weeks. I will tell if cathastrophies
> > occur...
> > Bjørn
> > - add your comments at the TOP and SIGN your posts and <snip> away
> > - To order plans: Mr. Philip C. Bolger, P.O. Box 1209, Gloucester, MA,
Just a thought. Try touching the head of the screw with the tip of a heated soldering iron. Hold it
Jim
Jim
> occur...
> Bjørn
occur...
Bjørn
occur...
Bjørn
On Friday 21 June 2002 00:15, timk_smith wrote:
starts to set up, but failing that I have had good luck heating the
screw first. Hold a soldering iron to the head for a couple of
minutes.
Half inch ply is pretty thick. Maybe you should use something
a bit more rugged than the standard drywall screw.
Bruce Fountain (fountainb@...)
Senior Software Engineer
Union Switch and Signal Pty Ltd
Perth Western Australia
tel: +618 9256 0083
> Last night I went to back out the screws, and every one of themOf course, the key is to give the screw a turn after the epoxy
> this is an interior bulkhead I'm not concerned; i'll just seal them
minutes.
tel: +618 9256 0083
Further evidence the hollow joint is a solution in search of a
problem, well.. now in search of the right problem.
> Anybody else had this problem and solved it? Is there a fail-safeAll it takes is rubbing the screw in wax or bar soap. Make sure the
Coat the screws with wax prior to driving them. Loosen them up a turn
when the epoxy is about 90% cured, but still soft.
--- In bolger@y..., "mikestockstill" <mkstocks@b...> wrote:
> Unless there is a specific reason to remove them, I just leave them
> in there. They hurt nothing, and add support.
> Mike
till
> > the glue dried.
> them
> I've
fail-safe
> > --tim.
Mike
Mike
> the glue dried.
them
I've
> --tim.
If stuck, heat up to soften epoxy.
Sometimes I have this problem, the trick is to pull them before the epoxy
gets rock hard.
gets rock hard.
Sent: Thursday, June 20, 2002 11:15 AM
Subject: [bolger] screwed
> the glue dried.
> inch-and-a-half thick assemblies. (This is also the first time I've
> --tim.
the glue dried.
--tim.
the glue dried.
--tim.
