Re: Bolger's power mitihulls
Kristine,
you have probably already seen this. But it comes as close to being
economical, fast to build, resaleable, and seriously useful as one is
likely to find, short of a personal design. One issue that I would ask
about first is that amas are not necesarily good models for powercat
hulls. The deal is for a few thou you buy pre-molded epoxy
glass "pans" that are just glued to whatever square box superstructure
you want to use. Or build the kit, or buy the boat.
http://www.yachtworld.com/core/listing/pl_boat_detail.jsp?
&units=Feet&checked_boats=1547873&lang=en&slim=broker&&hosturl=multimari
ne&&ywo=multimarine&
for Yulloh testing therefore displacement hull stuff. After that
interest passed, it was used for the kind of thing in the picture, and
then it was passed on, and then it rotted out.
>Good idea, I recall the article in MAIB, and it was a Phil project but
> Yes I had seen that one but was not sure if it was
> PCB&Fs design or an idea someone had and used ideas
> of PCB. But it's along the idea I have for a powercat.
> I should send Phil a letter and see what he has to
> say.
> Blessings All Kristine
say.
--- proaconstrictor <proaconstrictor@...> wrote:
Cheap Talk? Check out Yahoo! Messenger's low PC-to-Phone call rates
(http://voice.yahoo.com)
say.
> Here is the little power cat St Jan:http://www.duckworksmagazine.com/01/articles/champlain/index.htm
>____________________________________________________________________________________
I'm partial to this design since I quite aside made a similar boat to
my own design, as a prototype for a charter cat, since kids have
enjoyed it. Bolger's was originally designed as a Yulloh testing
platform, if I remember correctly, so the hull shape may not be ideal
for power. Good concept though.
> > > OK here is a question the group, how many diffrent4 or 5. How to count? Designed for straight power, or auxiliary
> > > power catamarans and trimarans had PCB designed that
> > > are under 30 feet?
power? Those that reasonably could have auxiliary power, though not
shown as such?
The designs index lists about 9 to 10, or so, depending how you
count them. A few are studies/earlier plans that became somewhat
different plans.
There's Bolger indications there are more than have been published,
or are in the index, eg the Bolger vee-bottom, inboard, stay
sail "Cruising Cat(-amaran)" in Derek Harvey's "Multihulls for
Cruising and Racing". It had moderate beam as reportedly Bolger
reasoned that gave a less jagged stability curve and compact
berthing.
There used to be earlier this year, current photos of a Bolger 24'
aquaculture power catamaran built at the Old Wharf Dory yard that
was still a goer:http://www.oldwharf.com/history.htmlIt had
moderate twin ob power, vee-bottoms deeper at the bow and flattening
astern, kinda beamy hulls with lowish freeboard, sheltered helm, and
good speed on the plane I would think. I think there's a pic in one
of the bolgergroups.
Seems to be only 5 straight power multis: Bantam, Fishcat, Trashcat;
and the two Power Cats, #480, and #598, the first of which the Old
Wharf Dory yard example is likely to be, and the second may be a PCB
supplied version of the CSD Fishcat #469... making it 4 in all that
are known.
> > OK here is a question the group, how many diffrentAlso, Singlehander Catamaran aka "A Fast and Light Singlehander",
> > are under 30 feet?
SBJ#27(Cartoon 3) and BWAOM Chapter 52-pg269.
Also, the queen of them all, Double Eagle, longer at 42 ft.
houseboat, and the Saint somethingorother small cat with the outboard.
______________
>I didn't know about the Bantam or Trashcat. There is the trimaran
> OK here is a question the group, how many diffrent______________________________________________________________________
> are under 30 feet?
> I know of the Trashcat, the Fishcat and the Bantam.
> Now many others are there?
> Blessings to All
> Kristine
______________
> Access over 1 million songs - Yahoo! Music Unlimited
> (http://music.yahoo.com/unlimited)
are under 30 feet?
Blessings to All
Kristine
are under 30 feet?
Blessings to All
Kristine
There are at least 4 Bantams done. The first one was built to the original plans in Nantucket and was written up in M.A.I.B., with a cover photo, a few back. He has since made considerable changes, including the double bottom update. The second one finished was the one Kristine mentions as having be stretched to 31 feet. That one is in Indian River Florida. He first built it the original size, but did not build the folding cabin, and built the cabin top in one layer of 3/8" ply instead of the foam ply laminate. He latter stretched it, but did not build the updated double bottom as he runs only in protected waters. The third one was built, also modified from the plans, and is somewhere in the Pacific Northwest. Bellingham seems to ring a bell in my memory :) I was last in contact with him Last fall when he had launched it without the cabin, anxious to try it out. I assume he finished the cabin during winter, spring?
The fourth one is mine, in Duluth, MN. It is the updated double bottom version, stretched to 22'. It does have the folding cabin, but I did not make the bow detachable as I never plan to be storing it in a garage. I have not been on the Bolger site since last Dec. when I went to Panama for the winter. When I got back I went right to work on the boat, launched in July and have been too busy boating and making some changes to report on it. I just folded the cabin this afternoon for the winter, which is coming tomorrow, according to the forecast. Anyway, now that boating here is done for the year I will try to figure out how to post some photos next week.
Bob
Low, Low, Low Rates! Check out Yahoo! Messenger's cheap PC-to-Phone call rates.
Bob
I've seen photos of two of them and one was built and
then pushed to 31 or 32 feet as I recall. The builder
didn't like the small aft deck. I think you will find
that one on Duckworks.
I think it's a great little boat.
Blessings Krissie
---echo172@...wrote:
Check out the New Yahoo! Mail - Fire up a more powerful email and get things done faster.
(http://advision.webevents.yahoo.com/mailbeta)
Blessings Krissie
> Anyone know if Bantam has been built?__________________________________________________________________________________________
> It can be found in Bolger cartoons, FYI
> removed]
There are some nice pontton boats, and I can't think of a reasonable
reason against them. they can be designed as extreme low resistence
boats. See my BassAckwards over at Duckworth, which is smaller than
what you sound to be after, and have a look at Bolger Saint
something, which is very simmilar, though mine was designed first.
Also his is a sharpies type, so would plane a lower energy input than
mine, which was designed as displacement only.
I wish I had copied his motor mount, since mine turned out to be too
high.
high.
> Hey, Let's build three hulls instead of two and make it just asugly!
Granted the Bantam is "utilitarian" in appearance (at least without
its glass house), it is hydrodynamically a pretty reasonable craft.
> You might check out the Bantam 16/20.Hey, Let's build three hulls instead of two and make it just as ugly!
> Peter
Could be building shed or storage limitations.
jmbell1 wrote:
jmbell1 wrote:
>I'm not sure why
> you'd want the bow to fold though. c
I'd be interested in hearing what was in that letter...
Sent: Monday, July 01, 2002 9:33 PM
Subject: Re: [bolger] Why no pontoons?
| In a message dated 7/1/02 9:55:09 AM Central Daylight Time,
|richard@...writes:
| > Maybe they are to ugly for even Bolger to design!
| > (JUST KIDDING!)
| You may have hit the mark. I ordered plans for "Hawkeye" from Bolger last
| year, thinking that I could contrive a center-console deck-boat out of it
| that would perform the functions of a poontoon boat, desired by my mother,
| without the exciting my father's violent anti-pontoon attitude.
| I mentioned this in my order to Bolger and received a nice handwritten
letter
| back from him which emphatically endorsed my father's anti-pontoon
aesthetic.
| (Bolger did give qualified approval the notion of building "Hawkeye" as a
| deck-boat, with the proviso that seating be placed on the centerline.)
(Mind
| you, I don't think that "Hawkeye" deserves many more points on aesthetics
| than a pontoon boat.)
| Apart from aesthetic issues, I can't imagine that there is much of an
| intellectual challenge in designing a pontoon floats. I believe Glen-L has
| plans for plywood pontoon floats, useful for someone who wished to have
| skin-thickness, plywood lay-out and scantlings prepared for them. As far
as
| shape and dimensions are concerned, I think it would take a great deal of
| imagination to come up with a shape that wouldn't work.
| Ciao for Niao,
| Bill in MN
| Bolger rules!!!
| - add your comments at the TOP and SIGN your posts and <snip> away
richard@...writes:
I mentioned this in my order to Bolger and received a nice handwritten letter
back from him which emphatically endorsed my father's anti-pontoon aesthetic.
deck-boat, with the proviso that seating be placed on the centerline.) (Mind
skin-thickness, plywood lay-out and scantlings prepared for them. As far as
Ciao for Niao,
Bill in MN
richard@...writes:
> Maybe they are to ugly for even Bolger to design!You may have hit the mark. I ordered plans for "Hawkeye" from Bolger last
> (JUST KIDDING!)
Ciao for Niao,
Bill in MN
> A reduction of 4' from theI agree. The original was for a Dutch couple. I think I remember that
> trailering length doesn't seem to warrant the structrual trade-offs.
they had a length limit based on either storage or trailering.
I had forgotten about this one... What a cool boat! I'm not sure why
you'd want the bow to fold though. A reduction of 4' from the
I'd think seriously about adding 2-4' more length to the middle for
some added deck space.
JB
JB
--- In bolger@y..., "pvanderwaart" <pvanderw@o...> wrote:
> You might check out the Bantam 16/20. She's a trimaran, and would
be
> very much better than a typical pontoon boat under power, but has
> pontoonboat-like deck space.
> As "Common Sense Boats" go, the pontoon is one of the morepractical. How come Bolger hasn't designed any?
You might check out the Bantam 16/20. She's a trimaran, and would be
There are pictures in the files of the Bolger2 group.
(JUST KIDDING!)
(JUST KIDDING!)
Sent: Monday, July 01, 2002 9:15 AM
> For 'pontoon' read 'twin hulled'. For 'twin hulled' read 'catamaran'. He
has done those. I have one. St. Jan is
> 15ft long and has a beam of 8ft. He has done others.
> Jim
> danbollinger wrote:
> > As "Common Sense Boats" go, the pontoon is one of the more practical.
For 'pontoon' read 'twin hulled'. For 'twin hulled' read 'catamaran'. He has done those. I have one. St. Jan is
Jim
Jim
danbollinger wrote:
> As "Common Sense Boats" go, the pontoon is one of the more practical. How come Bolger hasn't designed any?
