Re: [bolger] Re: A five dollar failure
On Mon, 1 Jul 2002, David Ryan wrote:
> In any event, I'm going back to oil-based urethane paint porch paint.
> Haven't had anything but good luck with that. Just give your
> epoxy/glass a good sanding and then slap it on.
I really recommend a good primer. Primers serve many useful purposes, and
certainly pay for themselves in terms of looks, time, and money. I like to
use Kilz brand latex primer.
If you want to smooth things out a little bit, you can add crushed
limestone to the primer--it's not exactly a high-tech high build primer,
but it does work nicely. Make sure you sand it when dry.
The primer is more tenacious to surfaces, and provide a nice surface for
the next coat of paint. Failure of David's sort are substantially less
likely. In addition, they help build up a system that's more tolerant.
David has concluded that latex is a bad bet, and that oil-based is what he
should use. I feel that this is a hasty conclusion; the judicious use of
primer would've created a good finish, I'll bet.
Primer dries very quickly, at least latex primer does. I can put down a
coat, and sand in 30 minutes, ready for the next coat.
Finally, a good primer just doesn't cost all that much (OK, $10 gallon).
But it keeps you from having to put down too many extra coats of top coat.
The primer has aluminum oxide--an excellent cover for stains, wild grain,
and other visually unwelcome flaws in the wood/epoxy below. It saves
moeny in reducing the number of top coats.
The primer is more forgiving in application than top coats--it's easy to
slather on, compared to final top coats, which can be fussy.
In short, I feel that there is simply no advantage at all to skipping the
primer stage. It's fast, it's easy, it's cheap, and it's tenacious. On
every dimension it improves the final appearance of the boat, at no
ultimate cost to time, money, or effort.
I've built without primer and with it. I'll never again go back to
skipping the primer step.
Had you used the previous places before painting with the oil based?
If you managed to get oil or slime of some sort on the boat during
use, I wouldn't be surprised if the oil paint doesn't stick either
without a detergent wash of some sort. TSP works great for this but is
not environmentally good.
> Yes, it really ran off. Big puddles of paint in the chine of the
boat
> when I went out to look at it this morning. Nope, no detergent. Just
> scrubbed everything with the grinder before painting, then rinses
> dust off and let it dry before painting.
> The biggest culprits were areas that were just bare epoxy. You could
> see the paint just slid off during the night. Other area were
> marginal, while still other came out fine.
paint.
> YIBB,
> David
Yes, it really ran off. Big puddles of paint in the chine of the boat
scrubbed everything with the grinder before painting, then rinses the
>The paint really RAN off? Did you wash the area with detergent of some
>sort first in case it was a little oily? Of course primer is a good
>idea, but I bet there are latex primers that would work. None will
>stick if surface is dirty.
>ANother point, some types of latex take a long time to really dry.
>I try to test any new paint type or surface prep. I was lucky to think
>of it because the first couple of types I tried did NOT stick well. I
>can thank the list for warning me of this potential problem.
>> Well yes, that would be the obvious answer. But because I've been
>> using Benjamin Moore over wood and/or glass without primer and
>> getting excellent results, I didn't think of it.
>> And...
>> For the price of buying the primer and the $5/gallon "oops" paint, I
>> could have just got more of Bennie's paint and skipped the priming
>> altogether.
>> As I said, at least it washes up with water.
>> YIBB,
>> David
>snip
>> >> Yesterday I spend a good two hours scuffing up the cockpits of
>my
>> >> Scooner to ready them to receive their new coat of discount
>paint. By
>> >> the time I was finished my hair looked like a powdered wig. I
>rinsed
>> >> off, then slapped on a coat of nice grey paint. Once I was done
>I
>> >> called my wife out to admire my handy work. "Quite nice," she
>offered
>> >> "the grey looks great."
>- add your comments at the TOP and SIGN your posts and <snip> away
>- To order plans: Mr. Philip C. Bolger, P.O. Box 1209, Gloucester,
C.E.P.
415 W.46th Street
New York, New York 10036
(212) 247-0296
> And...
> altogether.
> YIBB,
> David
snip
my
paint. By
rinsed
I
offered
Sorry, feeling flippant.
You are right, of course.
I've had issues with paint being washed off, even acrylic latex exterior
over Behr porch paint.
The local close out store has "House Beutiful" porch paint for $2.88 a
gallon, already colored, so you have to pick through it. However, it sticks
to unwashed, unsanded, epoxy (as long as the epoxy is fully set). Passed the
dishwasher test.
Sent: Monday, July 01, 2002 12:44 PM
Subject: Re: [bolger] A five dollar failure
> And...
> altogether.
> YIBB,
> David
> >Use primer, silly.
> >From: "David Ryan" <david@...>
> >Sent: Monday, July 01, 2002 10:02 AM
> >Subject: [bolger] A five dollar failure
> >> FBBB --
> >> Having previously asserted "If something's worth doing, it's worth
> >> doing poorly.", it looks like I'm going to have to add "If
> >> something's worth doing, it's worth doing twice."
> >> Last week the wife and I were at the Despot, when I spotted a can of
> >> grey Behr water-based porch paint on the "oops shelf." Five bucks for
> >> the gallon, and the color was inoffensive. I dropped it in my cart
> >> and felt smug at my thrift.
> >> Yesterday I spend a good two hours scuffing up the cockpits of my
> >> Scooner to ready them to receive their new coat of discount paint. By
> >> the time I was finished my hair looked like a powdered wig. I rinsed
> >> off, then slapped on a coat of nice grey paint. Once I was done I
> >> called my wife out to admire my handy work. "Quite nice," she offered
> >> Well it didn't look great when I went out to see how it dried.
> >> Apparently Behr latex porch paint wants more than a scuffing when
> >> being applied over Benjamin Moore oil-based porch paint. It stuck in
> >> some places, but in most places is just ran off (the boat is propped
> >> on it's side) and settled in the port chine. The only saving grace is
> >> it's water-based, so I just turned the hose on full blast and washed
> >> it out.
> >> So now it looks like if I want to paint the cockpits, I'll have to
> >> sand back to the white, oil-based paint at least. I'm just going to
> >> tell myself I got a whole bunch of boat building for five bucks.
> >> YIBB,
> >> David
> >> C.E.P.
> >> 415 W.46th Street
> >> (212) 247-0296
> >> Bolger rules!!!
posts
away
> >> - To order plans: Mr. Philip C. Bolger, P.O. Box 1209, Gloucester, MA,
> >Bolger rules!!!
> C.E.P.
> 415 W.46th Street
> (212) 247-0296
And...
altogether.
>Use primer, silly.
>> FBBB --
>> it out.
>> YIBB,
>> David
>> C.E.P.
>> 415 W.46th Street
>> (212) 247-0296
>> Bolger rules!!!
C.E.P.
415 W.46th Street
(212) 247-0296
Use primer, silly.
> FBBB --
> it out.
> YIBB,
> David
> C.E.P.
> 415 W.46th Street
> (212) 247-0296
FBBB --
it out.
C.E.P.
415 W.46th Street
(212) 247-0296
