Re: finishing Micro
It is safe and sane advice like this that can turn an all day
painting job into a few fun hours. Prep work should be tedious, paint
should be fun with a spray gun.
John Chiloquin, Oregon.
--- In bolger@y..., Dean Pacetti <gpacetti@y...> wrote:
> David,
> Parden me for giving unasked for advice but the
> way to get a crisp line with masking tape is after you
> put it on, you first paint the edge with the same
> color that is under the tape. This will seal the tape
> and not allow the different color to creep under.
> Dean Auburndale, Fla.
David,
--- dnjost <djost@...> wrote:
> Lincoln,
> thank you for the tip. In my line of work, I
> have found that
> every person has a special need, my special need
> happens to be with a
> paint brush. I just really stink at fine work with
> a brush. The
> masking tape has been really helpful for myself with
> poor motor
> control. It did creep in under the tape in spots,
> but I was able to
> clean it up with mineral spirits.
> The finish I wound up with is acceptable. The
> semi-gloss paint
> shows real well. I used a roller and tipped with a
> brush, this made
> for a real smooth job after just two coats. The
> cockpit needs a
> second coat, and the varnishing is not finished; but
> I am going to go
> ahead and paint the bottom so we can give her a try
> next weekend.
> Lake Cochituate? I want a safe launch, and retrieve
> place close to
> home so that any glitches won't involve a long drive
> for tools or
> help.
> I will let you know what the prognosis is later on
> in the week.
> David Jost
> "celebrating the purchase of anchors, flares,
> horn, etc..."
> --- In bolger@y..., "rnlocnil" <lincolnr@m...>
> wrote:
> > I have found that in the time it takes me to apply
> masking tape, I
> can
> > in most cases achieve acceptable results doing the
> edge with a
> small,
> > high quality brush instead.
Do You Yahoo!?
Sign up for SBC Yahoo! Dial - First Month Free
http://sbc.yahoo.com
Lincoln,
thank you for the tip. In my line of work, I have found that
every person has a special need, my special need happens to be with a
paint brush. I just really stink at fine work with a brush. The
masking tape has been really helpful for myself with poor motor
control. It did creep in under the tape in spots, but I was able to
The finish I wound up with is acceptable. The semi-gloss paint
shows real well. I used a roller and tipped with a brush, this made
for a real smooth job after just two coats. The cockpit needs a
second coat, and the varnishing is not finished; but I am going to go
ahead and paint the bottom so we can give her a try next weekend.
Lake Cochituate? I want a safe launch, and retrieve place close to
home so that any glitches won't involve a long drive for tools or
help.
I will let you know what the prognosis is later on in the week.
"celebrating the purchase of anchors, flares, horn, etc..."
--- In bolger@y..., "rnlocnil" <lincolnr@m...> wrote:
> I have found that in the time it takes me to apply masking tape, I
can
> in most cases achieve acceptable results doing the edge with a
small,
I have found that in the time it takes me to apply masking tape, I can
in most cases achieve acceptable results doing the edge with a small,
high quality brush instead. That way I don't have to find dried out
splotches that creep under the tape, either. I can clean up any
mistakes while still wet. Or are you spray painting?
--- In bolger@y..., "dnjost" <djost@m...> wrote:
snip
> Today, I painted the second coat on the deck, painted the bow well,
> cockpit, and masked off the hull to do a second coat on that. This
> took over 6 hours. Sanding the crud and applying tape is what takes
> the time.
snip
Whoa! This is a big job. Yes, many of the group warned me of this.
This boat is a snap to build, but it takes hours and hours of
finishing due to its volume. I must have spent close to 40 hours
just sanding fairing and applying masking tape. I guess it depends
on whether or not you want an upclose boat, or a twenty foot boat. I
figure that if I have to stare at that bulkhead to the cabin for
hours upon hours, then it really should be first rate.
the time.
One of the advantages of being a Fine Arts Director is that you get
free painting advise from art teachers. Let me tell you, they know
what they are doing. Recommended tools: 1/4" brush, 3M Blue masking
tape, penetrol, oil based paint (Kirby's, its local)good brushes 1",
2", 4" and a roller. I roll and tip the paint after thinning it with
the appropriate amount of Penetrol. I have to say, "This boat is
starting to look great!" I still forgot to paint the cockpit hatch,
Oh well, I will finish it bright.
Will we be sailing by Friday?
Oh, yes: the gin and tonic for afterwards is a necessary supply.
pardon the typos.
Hippy Boting ;-o
