Re: [bolger] Re: electrical panel
In a message dated 7/8/02 12:10:55 AM Central Daylight Time,
bobzonk@...writes:
> Though the connnections from the battery to the motor/charger should be
> separate, and heavy, but I'm sure you know that.
It would be imprudent to assume any knowledge of things electrical on my
part. In this case the motor/battery connections are as Mr. Kiekhaefer
intended, so there's no prospect of my screwing that up.
Ciao for Niao,
Bill in MN
Bill,
I'm glad I could help. It was just serendipity that I had just removed that
panel a day or two before.
There is no reason not to take all the negative (or common) leads to the
battery to connect them together. If it is more convenient, they can be
connected together at any point and a single wire run the rest of the way to
the battery.
You can run a single ground (negative) from bow to stern, and just tap into it
wherever it is convenient.
Bob
