Re: [bolger] Re: Storing Epoxy
Just bought a couple of the pumps a month or so ago. They are identical,
except there is a spacer inside one of them that keeps it from going down
all the way. Mayber Vince is missing the spacer?
Sent: Tuesday, July 09, 2002 10:38 AM
Subject: [bolger] Re: Storing Epoxy
> > think there is practically no blush with the slow hardener. I have
> used
> > the same two Raka pumps (2:1) for over 50 gallons now and the mix is
> > still accurate. I understand that Raka is now shipping only one type
> > pump and you have to count two strokes for the resin and one for the
> > hardener. I don't know why they made this change. Maybe it is more
> accurate.
> > Vince Chew
> Just be sure there isn't any way for moron little people to get
> locked in that box. The more interesting the contents, the greatter
> the risk.
> I don't know what was on Raka's mind in shipping only the single
> squirt pumps. But here are two thought:
> 1) if the pumps were simmilar to those you currently have, to cut one
> down to a 2-1 meatering would require making one of the pumps
> dispense less material, which would slow things down when you want
> fair amounts of epoxy. My own experience is that mistakes are a
> little more likely to happen with their current arrangement, but then
> they happen also when alternating pumps.
> 2) If you want 2-1 pumps, all you have to do is install a
> constrictor (check in the box to see if they are shipping it, a C
> shaped piece of plastic tube that fits over the pump shaft). This a
> is a block of wood, indelible marker line, tightly fitting plastic
> tube that limits the travel of the pump head to 1/2 its normal. You
> could limit it to a third, and the other pump to 2/3. This is a
> recognized technique, and would allow you the flexibility of using 2-
> 1, 1-.5, etc.. amount direct from the pump, depending on the most
> comon amount of material you need. For really large jobs, usualy
> measuring is best. And the best measuring is straight to lines on
> stir sticks, not graduations on cups, unless they are high quality
> markings.
> If you make your own constrictors, be sure they are half the length
> of travel, not half the length of the round shaft on the pump, unless
> that measurement is the same. An easy way might be to cut something
> that blocks any travel of the pump, and fits between the two bearing
> surfaces when the pump is fully compressed, then cut that marker in
> half, and use it to build your constrictor.
> Regardless of what pumping method you use, it is best to test the
> pumps by pumping out equal amounts of liquid into two adjascent cups
> and comparing them. If the amounts are identical, then you pumps are
> safe to go.
used
accurate.
> Vince Chew
the risk.
markings.
safe to go.
I recycled an old refrigerator to store epoxy. I ran a cord up through
the bottom drain hole and wired on a lamp socket w/ a 25w bulb for heat
in cold weather. There were two metal crisper bins which I keep the
epoxy in (to catch the inevitable drips). I store various glues, tints,
and some Raka 10 minute epoxy on the door shelves; and my tongue
depressors, brushes, roller covers, and vinyl gloves are in the top
freezer. I taped an indoor/outdoor thermometer to the door and ran the
sensor inside the fridge. I like my Raka at least 70 degrees for easy
pumping, mixing, and wetting out. I use only the slow hardener because I
hate wasting epoxy that cooks off before I'm done applying it. Also, I
think there is practically no blush with the slow hardener. I have used
hardener. I don't know why they made this change. Maybe it is more accurate.
Vince Chew
