Re: Gypsy, Preparing to start firt boat
I think I will do just that. I have been waiting a long time to build
her and I am ready to start. Being a novice and not educated in the
subject this is a great place to throw out ideas for good solid
opinions and knowledge. I'm learning things already. Thanks much
> This is your firt boat. Build it fast and learn things and get intothe water. Then start on your pretty ceder strip and take your time
> and make it look good.
> I apreciate the insight, The last thing I want to do is change theThis is your firt boat. Build it fast and learn things and get into the water. Then start on your pretty ceder strip and take your time
> hull, just like the looks of ceder strip and natural wood.
--- In bolger@y..., "Roger S" <roger99a@h...> wrote:
> I have found that withBut without an equal-weight partner leaning back swamps the boat.
> an equal weight partner you rarely have to move around, just lean to
> windward.
> I have also used the far side seat as the hiking strap.I used to until a month ago. Try the strap, it's easy and a big improvement.
I installed the seats on my Gypsy and I like them. I have found that with
windward. I have also used the far side seat as the hiking strap.
Roger S
Also, I would advise NOT installing the two seats on the side. You're
better off keeping your weight centered and low
Roger S
> (much of the time you'll sail it sitting on the rail- install a hikingstrap).
hull, just like the looks of ceder strip and natural wood. I was
thinking of buying the full sized pattern and making the hull pieces
off that using ceder strips instead of plywood. No dimentions would
change at all, But might not be strong as plywood though. I think I
will live without the jib, it was just an idea and that is why I
posted it so I could glean some wisdom :-) I don't want to move the
mast or add one, I have been waiting several years with plans in hand
and love the gypsy's look the way it is. Thanks for the tips on the
constructing flotation chambers, great idea. I will definately do
that.
that.
> A Gypsy goes like hell when the wind blows with its one sail. Inlight winds I have found myself wishing for more canvas, but rowing
> is good for you anyway. The Gypsy is not a forgiving boat. It isnarrow and has a very low freeboard and will make you swim if you
> are aren't paying sufficient attention. Even in a moderate wind youhave your hands full with that one sail.
> Putting a jib on a Gypsy would unbalance the rig without moving themast to the rear. If this is done, the boat will be unbalanced
> with the mainsail alone, which is all that you'll need except forthe lightest of winds. You could add a jib to the mast where it is and
> second mast to make a yawl, but it's probably not worth the trouble.from. Why not find one that is exactly what you want rather
> As for changing the hull-there are many many many designs to choose
> than trying to make a Gypsy something that its not?back to the mast. Otherwise, you will not be able to self-
> Two suggestions. Deck the rear compartment and the front all the way
> rescue. Also, I would advise NOT installing the two seats on theside. You're better off keeping your weight centered and low
> (much of the time you'll sail it sitting on the rail- install ahiking strap).
is good for you anyway. The Gypsy is not a forgiving boat. It is narrow and has a very low freeboard and will make you swim if you
are aren't paying sufficient attention. Even in a moderate wind you have your hands full with that one sail.
Putting a jib on a Gypsy would unbalance the rig without moving the mast to the rear. If this is done, the boat will be unbalanced
with the mainsail alone, which is all that you'll need except for the lightest of winds. You could add a jib to the mast where it is and a
As for changing the hull-there are many many many designs to choose from. Why not find one that is exactly what you want rather
Two suggestions. Deck the rear compartment and the front all the way back to the mast. Otherwise, you will not be able to self-
rescue. Also, I would advise NOT installing the two seats on the side. You're better off keeping your weight centered and low
(much of the time you'll sail it sitting on the rail- install a hiking strap).
> Any hints would be appreciated on starting this project. Also hasA Gypsy goes like hell when the wind blows with its one sail. In light winds I have found myself wishing for more canvas, but rowing
> anyone rigged thsi boat with a jib and main sail setup? I like to play
> around with the 2 sail setup and want it to work on the Gypsy. Also is
> the full size templates still sold for this boat? I did not see them
> on Bolger's websight. I want to ceder strip this boat, I think it
> would be very beautiful, but not quite sure on the first time around.
> I will ceder strip the pieces if I can find the Templates for it.
there would be one for a tack and tape boat, at least not one with
closely enough spaced stations.
If it were me, I would save cedar strip for a design of Bolger's or
whomevers that had round sections where the strips could be put to
good use:http://www.gartsideboats.com/cat.php
> Any hints would be appreciated on starting this project. Also hasplay
> around with the 2 sail setup and want it to work on the Gypsy. Alsois
> the full size templates still sold for this boat? I did not seethem
> on Bolger's websight. I want to ceder strip this boat, I think itaround.
> I will ceder strip the pieces if I can find the Templates for it.If by template you mean lines drawing, I would not have thought that
