Re: Color of hull/Temperature/Epoxy
Thanks to both of you. Clarification: Off white in this case is
called "Oyster" by Epiphanes. I don't know if that makes it better,
though... Any way, it is already purchased.
--- In bolger@y..., "Harry W. James" <welshman@p...> wrote:
> You have to get pretty hot temperatures before it matters. Homebuilt
> aircraft tend to live at airports in temperate climes and are
subject to
> much higher solar heating. I wouldn't worry about a solar gain in
> Norway.
> HJ
> rnlocnil wrote:
> > I think you're partly right about color, but most of the time we
are
> > not using the glass structurally, so we get away with it. I think
> > sun is only a heat threat when it's high overhead, and in that
case
> > the topsides won't get the full effect, though the deck will.
When the
> > seams are in the water, they will cool off and be strong, too. I
think
> > light colors are probably safer, though, as you say. Certainly the
> > airplane people are very careful about this, except when they use
hi
> > temp resins. THere are hi temperature resins available to us as
well.
> > Please don't pick the usual offwhite, there's too much of that in
our
> > world already. You could always use aluminum paint or battleship
grey.
> > Sick green? Pale blue? Pink!(ugh!), Manilla! Then you can find
your
> > boat in the anchorage, tho I suppose with WDG that won't be a
problem
> > anyway. I am being forced to go sailing in an offwhite Chlorox
bottle
> > tommorrow. If you HAVE to use offwhite, put some light grey polka
dots
> > on it.
> > --- In bolger@y..., "bjharbo" <bharbo@o...> wrote:
> > > Dear Group,
> > > Due to heavy rains all summer I still have not painted the now
> > > complete WDJ (i.e. I have to round the masts and oil all the
spars).
> > > I have always wondered why you guys so often choose rather dark
> > > colors for the hull sides. I guess that temperatures in your
> > > lattitudes must be a lot higher than in my near arctic play
ground.
> > > Doesn't the epoxy get weak?
> > > I'd like to paint the hullsides green but feel it would be
safer to
> > > go for off white. Comments and advice, please!
> > > Bjørn in Oslo,
> > > Itching to go sailing
posts
> > - add your comments at the TOP and SIGN your posts and
<snip> away
Gloucester, MA, 01930, Fax: (978) 282-1349
> > - Open discussion: bolger_coffee_lounge-subscribe@y...
aircraft tend to live at airports in temperate climes and are subject to
Norway.
rnlocnil wrote:
> I think you're partly right about color, but most of the time we are
> not using the glass structurally, so we get away with it. I think the
> sun is only a heat threat when it's high overhead, and in that case
> the topsides won't get the full effect, though the deck will. When the
> seams are in the water, they will cool off and be strong, too. I think
> airplane people are very careful about this, except when they use hi
> temp resins. THere are hi temperature resins available to us as well.
> Please don't pick the usual offwhite, there's too much of that in our
> world already. You could always use aluminum paint or battleship grey.
> Sick green? Pale blue? Pink!(ugh!), Manilla! Then you can find your
> boat in the anchorage, tho I suppose with WDG that won't be a problem
> anyway. I am being forced to go sailing in an offwhite Chlorox bottle
> tommorrow. If you HAVE to use offwhite, put some light grey polka dots
> on it.
> > Dear Group,
> > complete WDJ (i.e. I have to round the masts and oil all the spars).
> > lattitudes must be a lot higher than in my near arctic play ground.
> > I'd like to paint the hullsides green but feel it would be safer to
> > Bjørn in Oslo,
on it.
> Dear Group,
> Bjørn in Oslo,
Dear Group,
Bjørn in Oslo,
