Re: Queen Mab!!!
She's a real beaut alright! What are Queen Mab's dimensions and
capacity? She'd look great behind any boat.
Phil Bolger's design # 638, Queen Mab, specifies full frames and
lapstrake planking. The Queen Mab I built was strip built for minimum
weight and to keep the inside easier to clean. My boat, Just Ducky,
wieghed 28 pounds. The Queen Mab pictured in the files section was
built by Al Straub using frames and lapstrake planking, I think it
weighs about 45 punds but I am not sure, perhaps if Al is viewing the
forum he could give us an update.
Dave Thibodeau
Dave Thibodeau
--- In bolger@y..., "porcupinefysh" <porcupine@d...> wrote:
> Queen Mab uses six frames and a curved transom. The plywood
lapstrake
> version requires about three sheets of 4mm plywood and one each of
6mm
> and 12mm. I suspect that a lot of the plywood winds up as scrap.
Not
> much more lumber goes into her, and that is mostly for the spars.
PCB
> designed the single bilgeboard to get the box out from between the
> legs of the sailor without spoiling the lines of the boat. The
> bilgeboard is to be gotten out of a sheet of 6mm thick aluminum,
btw.
> For (relative) construction ease one can do as Paul did with the
> prototype and strip plank the hull. This would probably be the less
> expensive option, as well. I plan on doing the lapstrake version.
With
> either method, the design begs for good materials and a high
quality
> finish. Queen Mab is royalty, after all. Besides, at thirty-five
> pounds dry weight, there isn't a whole lot to buy, anyway. I figure
> that with plywood from Noah's, a Sailrite kit and locally purchased
> dimensional lumber, she should run me about US$600, total--plus the
> US$100 I've already put out for the plans.
> QM is definitely a cute little thing. I have the pieces all lofted
out
> on vellum, awaiting the return of lousy weather, when I can turn my
> attention to boatbuilding once again,
> porky
> --- In bolger@y..., "Harry W. James" <welshman@p...> wrote:
> > I don't believe there are frames. The boat is built on molds and
> then
> > pulled off. According to the MAIB article in Vol. 19 #20 1 March
02
> the
> > final hull weight should be between 35-45 Lbs.
> > HJ
> > proaconstrictor wrote:
> > > A beautiful job! Looks very fair. I am not familiar with the
> plans
> > > of this boat, where do the people go, there seem a lot of
frames?
> > > Did you use the Tom Hill (his mentor really) way of lofting and
> > > beveling the planks? Whose idea was the off-center trunk? We
> were
> > > just talking about that.
> > > Bolger rules!!!
> > > - no cursing, flaming, trolling, spamming, or flogging dead
horses
> > > - stay on topic, stay on thread, punctuate, no 'Ed, thanks,
Fred'
> posts
> > > - add your comments at the TOP and SIGN your posts and
> <snip> away
> > > - To order plans: Mr. Philip C. Bolger, P.O. Box 1209,
Gloucester,
> MA, 01930, Fax: (978) 282-1349
> > > - Unsubscribe: bolger-unsubscribe@y...
> > > - Open discussion: bolger_coffee_lounge-subscribe@y...
> > > Your use of Yahoo! Groups is subject to
Queen Mab uses six frames and a curved transom. The plywood lapstrake
version requires about three sheets of 4mm plywood and one each of 6mm
and 12mm. I suspect that a lot of the plywood winds up as scrap. Not
much more lumber goes into her, and that is mostly for the spars. PCB
bilgeboard is to be gotten out of a sheet of 6mm thick aluminum, btw.
expensive option, as well. I plan on doing the lapstrake version. With
either method, the design begs for good materials and a high quality
QM is definitely a cute little thing. I have the pieces all lofted out
porky
porky
then
> pulled off. According to the MAIB article in Vol. 19 #20 1 March 02
> HJ
plans
> > of this boat, where do the people go, there seem a lot of frames?
were
posts
<snip> away
> > - To order plans: Mr. Philip C. Bolger, P.O. Box 1209, Gloucester,
Sorry Dave, I had already looked at the building pictures in the
file about a month ago. I saw the 3003 and I couldn't resist, knowing
that I probably won't even make 2033.
I sent away a subscription to MAIB about a month ago but haven't
received a copy yet. The boat was beautiful before it was completely
finished. Having a boat like that would make it difficult for myself
to put it in water very often. Just the thought of dings and nicks on
such a great looking boat seems criminal.
John
John
--- In bolger@y..., "davejthib" <davejthib@y...> wrote:
> I made a typo, the picture is in MAIB July 15, 2002
> There are pictures of a Queen Mab in the files ection of this site--
> Dave Thibodeau
> In bolger@y..., "announcer97624" <announcer97624@y...> wrote:
> > Dave could you post a picture that will be availble sooner in
> > files? At least a picture that will be availible this month?
> > John
I don't believe there are frames. The boat is built on molds and then
pulled off. According to the MAIB article in Vol. 19 #20 1 March 02 the
> A beautiful job! Looks very fair. I am not familiar with the plans
> beveling the planks? Whose idea was the off-center trunk? We were
There are pictures of a Queen Mab in the files ection of this site---
Dave Thibodeau
Dave Thibodeau
> Dave could you post a picture that will be availble sooner in themada
> John
> > Dave,
> > I built the first Queen Mab and wrote an article about it which
> was
> > published in Messing About in Boats. Also, Bolger and Friends
> a
> > 30 minuite video of me and Phil Bolger saining the boat in rhe
> > Annisquam River at Gloucester Mass. The video is available from
> > Bolger and Friends. The Queen Mab picture in the July 15, 3003
> issue
> > of MAIB is the boat i built.
> > Dave thibodeau
> > --- In bolger@y..., David Ryan <david@c...> wrote:
> > > FBBB --
> > > I just saw my first photo of Queen Mab. I must build one! Input
> > from
> > > anyone who's built one or has one in process welcome!
> > > YIBB,
> > > David
> > > C.E.P.
> > > 415 W.46th Street
> > > New York, New York 10036
> > >http://www.crumblingempire.com
> > > Mobile (646) 325-8325
> > > Office (212) 247-0296
John
John
> Dave,
was
> published in Messing About in Boats. Also, Bolger and Friends mada
issue
> Dave thibodeau
> > FBBB --
> from
> > YIBB,
> > David
> > C.E.P.
> > 415 W.46th Street
Dave,
I built the first Queen Mab and wrote an article about it which was
published in Messing About in Boats. Also, Bolger and Friends mada a
Bolger and Friends. The Queen Mab picture in the July 15, 3003 issue
Dave thibodeau
Dave thibodeau
> FBBB --
from
> YIBB,
> David
> C.E.P.
> 415 W.46th Street
Naw - put it on one of the bunks inside - it is small enough....
> On stern davits or side davits of the I60?
Queen Mab would look more plausible on side davits of I30, stern ok as
planned.
planned.
> I just saw my first photo of Queen Mab.On stern davits or side davits of the I60?
FBBB --
I just saw my first photo of Queen Mab. I must build one! Input from
C.E.P.
415 W.46th Street
C.E.P.
415 W.46th Street
