Re: [bolger] Re: sailing report on Micro
You can't get much cheaper or simpler than a loop snugly fitted over the end
of the boom. <g>
http://www.boat-links.com/images/ClewBecket.jpg
On Fri, 02 Aug 2002 02:25:16 -0000, David Jost wrote:
> As for the rig, I just read in Herreshoff's The Compleat Cruiser, of
> a neat arrangement for securing the clew using a block of wood with a
> hole in it screwed to one side, and a wooden thumb cleat opposite.
> One ties a stopper knot in a line and passes it through a hole in the
> block (similar to the snotter blocks that are drawn on my plans) and
> then through the clew grommet and the around the thumb cleat, back
> through the clew and then around the boom behind the cleat, secure
> with a couple of half hitches. Seems pretty simple! and cheap.
John <jkohnen@...>
People say that life is the thing, but I prefer reading.
<Logan Pearsall Smith>
I will amend this message a little:
today we had 7 kt SE. I discovered that the lee helm I was
experiencing before was easily corrected by trimming the boat so that
the lee chine is just immersed. What a difference.
> Well, I have now had Micro out in a host of differing conditions.
> Here is a brief synopsis of how she handles.
> light air: Southwest/west 3-5kts, variable + boat chop:
> infuriating. loosen up the snotter and mizzen and hope for the
> best. My boat had a real lee helm that was quite bothersome. I
think
> that a larger mizzen or a sail with more roach could be very
> beneficial here. More sail area is definately needed.
> Northwest: gusty 15-18kts, Northwest, smooth water: boat develops
> just the right amount of weather helm to be comfortable without
> overpowering. Micro handles the gusts with ease and just heads up
> with a little heeling. Easily handled by easing the sheet or
heading
> up, whichever comes first. Very enjoyable...too bad we had to go
> home! This boat could go like this for hours upon hours.
> We did experiment with the first set of reef points, but it did not
> deem necessary. Micro will go 4.5kts tops, after that she just
digs
> a deeper hole in the water. Reefing would be beneficial in those
> conditions.
> I still hate the pegs on the sprits. I will be installing cheek
> blocks and jam cleats like I have had on other boats. Safe,
secure,
> and simple. This will also make reefing a brainless process.
> regards, I need to get back on the water.
> David Jost
best. My boat had a real lee helm that was quite bothersome. I think
with a little heeling. Easily handled by easing the sheet or heading
deem necessary. Micro will go 4.5kts tops, after that she just digs
conditions.
blocks and jam cleats like I have had on other boats. Safe, secure,
