[bolger] Re: Fibreglassing Chebacco
Dear Brad,
As far as I can tell, everyone is using Epoxy these days. It's a bit more
expensive than polyester, but less brittle, and much more impervious to
water.
I've used both in the past, and epoxy seems better in every way.
Bill
water.
Bill
>From: Brad Hornseth <bhornseth@...>______________________________________________________
>Reply-To:bolger@egroups.com
>To: "bolger@..." <bolger@...>
>Subject: [bolger] Fibreglassing Chebacco
>Date: Thu, 03 Feb 2000 13:24:13 -0700
>I have been looking thru "How to build the New Instant Cat Boat" and
>noticed that Payson uses polyester resin rather than epoxy. When group
>members built their Chebacco's (and other Bolger boats) what did they
>use? What are the pro's and con's of polyester vs. epoxy?
>Brad Hornseth
>Get what you deserve with NextCard Visa! Rates as low as 2.9%
>Intro or 9.9% Fixed APR, online balance transfers, Rewards Points,
>no hidden fees, and much more! Get NextCard today and get the
>credit youdeserve! Apply now! Get your NextCard Visa at:
>http://click.egroups.com/1/929/5/_/3457/_/949609860/
>-- Create a poll/survey for your group!
>--http://www.egroups.com/vote?listname=bolger&m=1
We used to use vinylester with kevlar for white water kayaks (canoes to UK
readers). This was all "glass" construction, so I can't say if it would
stick to wood. However, except for being much more flexible in use (after
curing) the resin appeared to be very like polyester.
Jamie Orr
Sent: Thursday, February 03, 2000 12:48 PM
To:bolger@...
Subject: [bolger] Re: Fibreglassing Chebacco
Does anyone have any experiance or comments on vinyl-ester resins? They
seem to be a comprimise between the epoxy & polyesters.
- Tim B.
"orr, jamie" <jor-@...> wrote:
original article:http://www.egroups.com/group/bolger/?start=2258
GET A NEXTCARD VISA, in 30 seconds! Get rates as low as 2.9%
Intro or 9.9% Fixed APR and no hidden fees. Apply NOW!
http://click.egroups.com/1/932/5/_/3457/_/949610906/
-- 20 megs of disk space in your group's Document Vault
--http://www.egroups.com/docvault/bolger/?m=1
Jamie Orr
To:bolger@...
- Tim B.
> I used epoxy on my Chebacco -- I wouldn't use polyester if it wasfree,
> given the cost and time required to build the boat, as it just won'tstay
> stuck to the wood>I have been looking thru "How to build the New Instant Cat Boat" and
> noticed that Payson uses polyester resin rather than epoxy. Whengroup
> members built their Chebacco's (and other Bolger boats) what did they------------------------------------------------------------------------
> Brad Hornseth
- Tim B.
- Tim B.
> Brad Hornseth
I used epoxy on my Chebacco -- I wouldn't use polyester if it was free,
given the cost and time required to build the boat, as it just won't stay
stuck to the wood. I also have a cedar strip canoe that had to be reglassed
twice -- the second time I used epoxy. The instructions for that also said
to use polyester, but the advice dated from the early 70's, before epoxy
came into such general use.
I've also heard of polyester taped joints letting go -- this was at second
hand, but from a good friend. He built a Gypsy with epoxy at the joints and
polyester for the sheathing, but I would still use all epoxy.
I think even Payson is recommending epoxy these days, although his books do
say polyester.
Jamie Orr
Sent: Thursday, February 03, 2000 12:24 PM
To:bolger@...
Brad Hornseth
say polyester.
Jamie Orr
To:bolger@...
Brad Hornseth
Brad Hornseth
Brad Hornseth
