[bolger] Re: wooden spoke type steering wheel
"matthew long" <owlnmol-@...> wrote:
original article:http://www.egroups.com/group/bolger/?start=2295
using plywood, but that would keep the cost and construction time down
and the strength would certainly be there.
Thanks again,
George
> I imagine that you are looking for a spoked wheel, but if not there isThanks very much, I will look for that publication. I never thought of
> a neat one in Robert Firth Jones's BOATS TO GO (aka LOW-RESISTANCE
> BOATS). He says:
> "The wheel is copied from one we saw in a Dutch boat, cut out of
> plywood 1 and 1/8 inch thick and 21 plies, made by laminating up three
> pieces of 3/8 inch ply. The end grain is gorgeous." p. 189
> The photo shows an elegantly simple wheel consisting of a circle with
> three large ellipses cut out of it, like some car alloy wheels. With
> the edges routed outside the circle and inside the ellipses, clear
> varnished, and with a large brass or bronze center plate, it's very
> stylish. If I build a powerboat, it will have a wheel like this one.
> Good luck,
> Matthew
> "george shannon" <gjs30-@...> wrote:
> original article:http://www.egroups.com/group/bolger/?start=2261
> > I am looking for a set of plans for a traditional wooden helm. I
> would
> > like to build one for Bolger's Micro Trawler. I have a standard 15"
> > wheel now, but could use one from 15-17" in diameter. Also some
> advice
> > on setting the center keyed metal bushing into the wood to fit over
> the
> > steering shaft. I am assuming that a laminated wood base would be
> > better than solid wood. Am thinking of some kind of hardwood.
> > George Shannon
> Matthew,
Thanks again,
George
robert w norris <bob-norri-@...> wrote:
original article:http://www.egroups.com/group/bolger/?start=2294
expense involved. Thanks for your reply.
George
> It's <www.stevproj.com>Yes, I would like very much to see it. Let me know if there is any
> BoB-)
> S/V "High Hopes"
> On Thu, 03 Feb 2000 21:16:42 -0600 T Webber <tbertw@...> writes:
> > >would
> > George,
> > I recently purchased the plans for the "Weekender" by Stevenson. It
> > has a
> > very nice small wheel and looks very easy to build and use. If you
> > would
> > like, I can fish out the links of the Weekender photos.
> > Tim - the one in Houston
> >Tim,
George
BOATS). He says:
Good luck,
Matthew
BOATS). He says:
Good luck,
Matthew
> I am looking for a set of plans for a traditional wooden helm. Iwould
> like to build one for Bolger's Micro Trawler. I have a standard 15"advice
> on setting the center keyed metal bushing into the wood to fit overthe
> George Shannon
BoB-)
S/V "High Hopes"
S/V "High Hopes"
BoB-)
S/V "High Hopes"
> At 06:49 PM 02/03/2000 -0800, you wrote:------------------------------------------------------------------------
> >would
> George,
> has a
> would
> -- Create a poll/survey for your group!BoB-)
> --http://www.egroups.com/vote?listname=bolger&m=1
S/V "High Hopes"
The Gougeon Brothers book on boatbuilding has a lot of recommendations for
setting hardware in woodwork and laminates, using epoxy.
Don Hodges
Don Hodges
To: <bolger@...>
Sent: Thursday, February 03, 2000 3:07 PM
Subject: [bolger] wooden spoke type steering wheel
> I am looking for a set of plans for a traditional wooden helm. I would
> wheel now, but could use one from 15-17" in diameter. Also some advice
> on setting the center keyed metal bushing into the wood to fit over the
> George Shannon
> GET A NEXTCARD VISA, in 30 seconds! Get rates
> as low as 0.0% Intro APR and no hidden fees.
> Apply NOW!
>http://click.egroups.com/1/975/5/_/3457/_/949612055/
I recently purchased the plans for the "Weekender" by Stevenson. It has a
very nice small wheel and looks very easy to build and use. If you would
>"george shannon" <gjs30-@...> wrote:George,
>would
Check "Wooden Boat" magazine issue #107.
John
> George ShannonGeorge,
John
George Shannon
George Shannon
