[bolger] Re: Brick Pos. Floatation / Mast Location
It has also occurred to me when sailing my Brick "Tetard" that some
flotation would be nice for self-rescuing. That said, I am a lousy
sailor and my wife had never been sailing before, but the boat is so
wide that even on our VERY WINDY maiden voyaage, when we broke the
original rudder in an unintentional jibe, we never came close to
capsizing.
The great thing about a Brick is all that lounging space, as well as
it's simplcity. Once you start making it more complicated, maybe you
ought to go to another boat like Surf which already has flotation
designed in.
Matthew
short-@...wrote:
original article:http://www.egroups.com/group/bolger/?start=2286
> Thinking of building a brick that has 2 simple floatation
compartments,
> one at bow, one at stern.
> How do I calculate the minimuim size of compartments?
> Also, was thinking of moving the mast to the centerline attached to
> forward flotation compartment. What effects would this have on the
> brick?
> Seems that if the mast is on starboard side, running a port tack close
> hauled would be tough because the sprit would be hitting you in the
head
> and preventing you from getting your weight on the starboard side.
> Thanks!
> David Routh
richard spelling <richar-@...> wrote:
snip
> People float. So do wooden boats. Why floatation?
> Anyway, figure 40 or so pounds of floatation for every cubic foot of
> floatation foam.
If it doesn't float high enough to bail or at least sail in a chop, you
can die of hypothermia. I had a close call with this myself once. It
took a long time to stop shivering once I got ashore, on a sunny 80
degree day in the spring. Of course if I'd been a bit more conservative
and stayed in (20 or 25 knots, small boat), I'd have been fine anyway.
Thinking of building a brick that has 2 simple floatation compartments,
Also, was thinking of moving the mast to the centerline attached to the
brick?
hauled would be tough because the sprit would be hitting you in the head
Thanks!
David Routh
oops. 60lb, not 40
> floatation foam.
> I would used airtite chambers though, on a boat that small, the storage
> space would be handy.
> > brick?
> I ran my D4, short wide boat like the Brick, to windward all the time
> without moving from the centerline longitudinal twart.
> Also, you loose "coolness factor" if you put it in the centerline.
> Richard
> Spelling|richard@...|http://www.spellingbusiness.com
> SBE Communications, Business Solutions for the next Millennium and
> Beyond!
> Boat building projects:http://www.spellingbusiness.com/boats/
> GET A NEXTCARD VISA, in 30 seconds! Get rates
> as low as 0.0% Intro APR and no hidden fees.
> Apply NOW!
>http://click.egroups.com/1/975/5/_/3457/_/949682724/
Richard
Beyond!
floatation foam.
> brick?
Richard
Beyond!
David,
Foam is usually given a weight of 2 lbs per cubic foot. Water weighs 62 lbs
per cubic foot. Foam will porvide 60 lbs flotation per cubic foot (62 - 2).
Plywood (yellow pine) is normally assigned a weight of 40 lbs per cubic
foot. If you add up all of the plywood weight and framing weight. What the
skipper, crew and other stuff in the boat weigh, that gives a rough weight
to support. It probably would be difficult to support EVERYTHING out of the
water. I would guess that a reasonable goal would be to have enuff
flatoation to keep the gunwhales out of the eater so it could be bailed
with YOU in it... Hopefully this is a starting point to get you where you
need to go.
>brick?
I have a collection of old Common Sense Newsletter. One (if my memory
serves me) has a picture of a Brick with a centered mast. It would be
fairly easy to put flotation in that area.
>Thanks!
>David Routh
Tim - the one near Houston
