Re: Small Boat Journal Cartoon #9
In his write-up, Phil qualifies the potential of this boat less than he often does. There
is enough info in the article to build it. Cut up some cardboard to get the bow angle
approximately right.
rnlocnil wrote:
>snip
> THis leaves two obvious questions:
> 1. Did he say why he said no? Is there something wrong with the
> design?
Why not add a similar cabin to a Sneakeasy hull? A proven hull, cheap
plans (from Payson) and a sleeker, silkier look to boot. Ya' can't
lose.
Bruce Hector
lose.
Bruce Hector
design?
2. What are you building instead?
design?
--- In bolger@y..., Chris Crandall <crandall@u...> wrote:
> > For a purely summer boat, the shelter could also be left off
entirely.
> > You'd have a decent, 23' boat squeezed out from just six sheets of
> > plywood.
> I tried to get Bolger to finish the design for this boat, as it was
just
> what I wanted. He said no--in no uncertain terms, although
politely.
> I could build almost exactly this boat with the cartoon alone, with
just a
> couple of dimensions from him (stem angle, angle of transom, etc.).
He
> wouldn't provide it.
> I'm building something else (very slowly), for the same purpose.
> Chris Crandall crandall@u... (785) 864-4131
> Department of Psychology University of Kansas Lawrence, KS
66045
> I have data convincingly disconfirming the Duhem-Quine hypothesis.
> For a purely summer boat, the shelter could also be left off entirely.I tried to get Bolger to finish the design for this boat, as it was just
> plywood.
what I wanted. He said no--in no uncertain terms, although politely.
I could build almost exactly this boat with the cartoon alone, with just a
couple of dimensions from him (stem angle, angle of transom, etc.). He
That's a nice proposal.
For a purely summer boat, the shelter could also be left off entirely. You'd have a
decent, 23' boat squeezed out from just six sheets of plywood.
jeff wrote:
> I like the looks too. I wonder if you could put a "slot top" on it like the
> Birdwatcher. You could then walk her length with out stooping down but
> still close it off to weather.
Sent: Wednesday, September 04, 2002 11:26 AM
Subject: [bolger] Re: Small Boat Journal Cartoon #9
> --- In bolger@y..., "saltyboat" <bruceh@t...> wrote:
> > I just was re-reading the PCB Cartoon #9,
> > _A Flat-Bottomed Outboard Cruiser_
> > from SBJ#33 in 1983. An enjoyable read, for
> > the rambling 'wear-your-thought-process-
> > on-your-sleeve' PCB stream-of-conscience
> > writing style.
> > The PCB commentary on this boat,
> > a 23'9" sharpie, seems to reveal
> > a lot of his thinking that went
> > into Tennesee, Sneakeasy et.al.
> > Here is a scan:
> >http://www.hallman.org/bolger/SBJ_9/
> That is a very interesting boat. Would be great around here with a
> bunch of inland lakes and canals.
> I just was re-reading the PCB Cartoon #9,That is a very interesting boat. Would be great around here with a
> writing style.
> Here is a scan:
writing style.
Here is a scan:
writing style.
Here is a scan:
