Re: Moanhogany - Just don't build the chair out of it too.
Thanks for the suggestion. THis is a job for PL Premium, I think, so I
will probably just wipe with water a bit ahead of time.
--- In bolger@y..., Chance Curtis <sneakeasy2002@y...> wrote:
> Its OK ! before installing dip - not soak- it in water and let it
dry.
> This will raise the grain and give epoxy more "tooth"
> CCG
> Lincoln Ross
snip
Its OK ! before installing dip - not soak- it in water and let it dry.
CCG
Lincoln Ross
wrote:Thanks for the suggestion, but it's too late unless I have another
disaster, as I've already purchased the wood.
> Both maple and ash are strong, ash is used for baseball bats. But
Sept issue of Wood magazine says they both rot. look for cypress.
> CCG
> Lincoln Ross
> wrote:Want to suggest woods to try? I am thinking of maple or ash.
Must be
> hard to stand up to dragging, strong, tolerant of water and glue
well.
> Is maple supposed to glue well? I've had good luck with it on
> furniture.
snip
var lrec_target="_top";var lrec_URL = new Array();lrec_URL[1] = "http://rd.yahoo.com/M=234081.2377872.3805271.2225242/D=egroupweb/S=1705065791:HM/A=1223727/R=0/id=flashurl/*http://ad.doubleclick.net/clk;4547223;7007303;y?http://www.ameriquestmortgage.com/welcome.html?ad=Yahoo01";varlink="javascript:LRECopenWindow(1)";var lrec_flashfile = 'http://us.a1.yimg.com/us.yimg.com/a/1-/flash/ameriquest/yahoo_lower_lrec.swf?clickTAG='+link+'';varlrec_altURL = "http://rd.yahoo.com/M=234081.2377872.3805271.2225242/D=egroupweb/S=1705065791:HM/A=1223727/R=1/id=altimgurl/*http://ad.doubleclick.net/clk;4547223;7007303;y?http://www.ameriquestmortgage.com/welcome.html?ad=Yahoo01";varlrec_altimg = "http://us.a1.yimg.com/us.yimg.com/a/1-/flash/ameriquest/yahoo_lower_300x250.gif";varlrec_width = 300;var lrec_height = 250;
Do you Yahoo!?
Yahoo! News - Today's headlines
> CCG
> Lincoln Ross
Must be
well.
> furniture.
snip
Both maple and ash are strong, ash is used for baseball bats. But Sept issue of Wood magazine says they both rot. look for cypress.
CCG
Lincoln Ross
wrote:Want to suggest woods to try? I am thinking of maple or ash. Must be
hard to stand up to dragging, strong, tolerant of water and glue well.
furniture.
--- In bolger@y..., "proaconstrictor" <proaconstrictor@y...> wrote:
> --- In bolger@y..., "Lincoln Ross" <lincolnr@r...> wrote:
> > I need Chapelle's moaning chair!
> > The mahogany strips I'd added to the soft bottom stringers on my
> > dinghy project were cleaning up nicely with a plane when I started
> to
> I have been bedevilled with bad mahogany. You can't tell whatthe
> grain looks like always, since there isn't any early and late wood.
> Once I bned it on, its often a nasty surprise. I can get good
> alternative woods, but have to go to a speacialty shop. Moanhogany
> is in every lumberyard, whether it should be or not. I have used
> great stuff for the necks of guitars, but its a little pricy, and
> likely to be listed, anytime.
Do you Yahoo!?
I've used Ash with good success. It's hard enough to stand up to abuse,
shock resistant enough to make baseball bats. Thin you epoxy a bit when
gluing as it doesn't absorb epoxy well but I've not had any problems with
not sticking. Plus, price wise, it's better than other hardwoods.
Sent: Monday, September 16, 2002 8:46 PM
Subject: [bolger] Re: Moanhogany - Just don't build the chair out of it too.
> furniture.
> > to
furniture.
> to
It all seems very clear now! I hope your problem can be cured easily.
At moments like that an old friend who had built thousands of boats
in his life and is now departed used to say, "If that is the worst
thing that happens in one hundred years to you you'll be very lucky".
Not very comforting in your situation now but a good thing to think
of to put things in prospective. I hope the rest of your project and
problems become insignificant to the enjoyment you receive from your
boat.
John
> Really seems like you don't get it. Chapelle prescribed a
designated
> chair for sitting and moaning in in the shop when you make a big
> mistake when building a boat. Haven't read the original passage yet
> but I understand the necessity.
> Your rowing seat sounds like a good idea, tho. S.O. is getting sick
> the padded plastic bucket that we use, and I think I'm getting
close.
> --- In bolger@y..., "John Cupp" <caj@k...> wrote:
> > Maybe I'm not getting a correct impression of what you want but
out
> > here in the northwest we use a rowing seat that has rope for a
> > cushion. Before you poo-poo the idea I can assure you it is the
most
> > comfortable rowing seat I have ever been on.
> > http://groups.yahoo.com/group/bolger/files/COMFORTABLE%20ROWING%
> snip
> > John
> > > The mahogany strips snip 20 or 30 degrees of grain runout in
> places!snip
> > > tomorrow I'm going to have to plane them off and replace snip
> > > my profits are awfully slim as it is. Mostly feels like a loss
> > > already.
Really seems like you don't get it. Chapelle prescribed a designated
Your rowing seat sounds like a good idea, tho. S.O. is getting sick of
the padded plastic bucket that we use, and I think I'm getting close.
> Maybe I'm not getting a correct impression of what you want but out
> cushion. Before you poo-poo the idea I can assure you it is the most
snip
> John
places!snip
> > already.
The rope is threaded back and forth across the top of the seat dowels
and around the bottom dowels so it can be retied for your preference
in firmness. As you see this seat can be made very inexpensively and
I haven't seen anything like it on the forum yet. I think it is a
shame since this type of seat can make many row boats all day rowing
boats like our drift boats are.
John
> notice that I had 20 or 30 degrees of grain runout in places! I
guess
> tomorrow I'm going to have to plane them off and replace with
> something else. Had gone to a lot of trouble running around looking
> for some hard wood when a guy from a wood shop cut me some from his
> scrap. Oh well. Ash will be better if I fork over $18 for a piece,
but
> already.
dinghy project were cleaning up nicely with a plane when I started to
notice that I had 20 or 30 degrees of grain runout in places! I guess
scrap. Oh well. Ash will be better if I fork over $18 for a piece, but
already.
