Re: [bolger] Re: Superbrick model is finished, and ready for download
In a message dated 9/28/02 8:29:53 AM Central Daylight Time,
helio6@...writes:
power or sail, is about 5 kts., with a rolling wake and a bone in its teeth."
Ciao for Niao,
Bill in MN
helio6@...writes:
> But I have a figure in there ofI think you tweeked it a bit much. In BWAOM, Bolger says "Maximum speed,
> only .05, so that I would get about 8 knots hull speed. And so on. I
> tweeked the cfg to get a reasonable sailing performance, which may
> not be accurate.
Ciao for Niao,
Bill in MN
Bruce: Unfortunately, we can't go by the sailing performance as
demonstrated by this Superbrick. Virtual Sailor, like most
simulators, doesn't read the graphics files to make it's performance
decisions... it reads the file you'll find called "boat.cfg". You can
open this in Notepad and look at it.
In the case of the Superbrick boat.cfg, I tweeked it so that it WOULD
sail... but you could plug more "authentic" numbers into the cfg to
see what would happen. For instance, the real Superbrick would have a
real high "cdf", as it is so "blunt". But I have a figure in there of
not be accurate.
On the flip side, don't be discouraged if you put real numbers in
the .cfg and the boat does not sail well. We've compared simulated
boats with accurate boat.cfg's, with the real boat's perfomance...
and in every case, the boat.cfg needed to be adjusted from "real" to
get the sim boat to act properly.
But I do hope someone builds this boat, someday. I'll drive awful far
to check it out! Rich.
not be accurate.
> mind at least, the simulation
> ends the question of whether
> Superbrick 'can sail'!
> My brain is now scheming
> how to build one in my
> backyard, and extract it
> out to the street.
> With only 7'10" clear to get
> from the backyard to the frontyard.
> If I tip the hull up on its
> side, on rollers, I can squeeze
> the boat out.
Be the neighborhood Noah and build it in the front yard. You'll have
the neighbors really scratching their heads.
Steve.
Steve.
> --- "proto957" > wrote:
> > The 3D model of PCB's Superbrick
> > is ready for download
> This is so cool! Works
> on my XP system. In my
> out to the street.
> the boat out.
out to the street.
the boat out.
> The 3D model of PCB's SuperbrickThis is so cool! Works
out to the street.
the boat out.
The requirements list says Win98, but it does work on my XP system.
It takes some patience to learn to use it.
Carter
Carter
--- In bolger@y..., "lulalake_1999" <lulalake_1999@y...> wrote:
> Problem,
> VS doesn't work with XP.
> Shucks!
Problem,
Shucks!
Shucks!
--- In bolger@y..., "proto957" <helio6@h...> wrote:
> The 3D model of PCB's Superbrick is ready for download at my
Virtual
> Sailor add-on site, the Chum Bucket:
>http://www.angelfire.com/space/proto57/
> Be sure to read the included "readme.html" in your browser, after
> download.
> For those unfamiliar with Ilan Papini's sailing simulator, Virtual
> Sailor, check out:http://www.avsim.com/vsYou can download a
free
> demo of Virtual Sailor from there. To install the Superbrick,
first
> install the demo of VS. In the "boats" folder, create a folder
> named "superbrick", and extract the contents of "superbrick.zip"
into
> this folder. When running Virtual Sailor, move your cursor to the
> top, and click on "change", then "boat", then click
on "superbrick"
> to load it.
> Virtual Sailor simulates the entire marine envoirment, and allows
you
> to control all aspects of wind, weather and waves. You can create
or
> download boats, submarines, and scenery. All add-ons are freeware,
> created by users of the sim, and there are hundreds. The
Superbrick,
> and my previous AS-29, are the two Bolger boats available. They
are
> complete with interiors, and you can "wander" around their
interiors,
> and get a feel for what these boats may be like in person. Perhaps
we
> have some 3D CAD modelers in this bunch, who would like to make
some
> more of the Bolger fleet. I'd love to see a Micro myself! And
maybe
> I'll make my honeymoon boat, which we chartered in Florida:
Tashtego,
> a Black Skimmer built by Walter Baron.
> Superbrick and AS-29 have working lights, sails, and props. If you
> click on "a" (to anchor), a Brick dinghy will appear, tethered to
> your stern. Thanks to everyone in this group for all your comments
> and help in getting the necessary resources together to make this
an
> accurate model. Rich SantaColoma.
The 3D model of PCB's Superbrick is ready for download at my Virtual
download.
Sailor, check out:http://www.avsim.com/vsYou can download a free
demo of Virtual Sailor from there. To install the Superbrick, first
named "superbrick", and extract the contents of "superbrick.zip" into
top, and click on "change", then "boat", then click on "superbrick"
to load it.
Virtual Sailor simulates the entire marine envoirment, and allows you
to control all aspects of wind, weather and waves. You can create or
created by users of the sim, and there are hundreds. The Superbrick,
and my previous AS-29, are the two Bolger boats available. They are
complete with interiors, and you can "wander" around their interiors,
and get a feel for what these boats may be like in person. Perhaps we
have some 3D CAD modelers in this bunch, who would like to make some
more of the Bolger fleet. I'd love to see a Micro myself! And maybe
I'll make my honeymoon boat, which we chartered in Florida: Tashtego,
and help in getting the necessary resources together to make this an
download.
to load it.
