Re: [bolger] Re: Plywood for gypsy
You have to watch out for 3/8 AC. Three ply has often has the most
atrocious void filled core with thin outer ply. Pretty good 4 ply shows
up sometimes.
up sometimes.
> Bolger warns to keep the floatation high. Putting it low will make the boat flip -turtle- if its placed too low. Is ACX the same as AC which is recomended in Instant Boats?
> By the way I live in Indiana here are plywood prices in Manard's home supply Sunday ad. All prices are for 4x8 unless noted.
> Luan 5mm $9.95 -this stuff is blonde not red: is it just as good ?
> acx !/4in fir $14, 3/8 $18, 1/2 $23
> 1/4 birch or red oak $14
> also 1/4 ProPly- 5ply baltic birch underlayment 4x5ft $9
> Is 1/4 in acx fir better than 5mm luan?
> CCG
> prthober <prthober@...> wrote:Stan,
> I built a Gypsy last spring and used 1/4 inch ACX throughout. I added
> full decking and covered everything external with 6 oz fiberglass in
> epoxy - obviously there has been no checking on these surfaces. The
> cockpit floor which is coated with epoxy and painted shows no sign of
> checking yet.
> Paul
> --- In bolger@y..., "Stan" <stankellar@h...> wrote:
> > As a newbie here, I have a question that may be old hat, but here
> > goes.
> > I am considering using AC fir ply for a Gypsy, and wonder if
> checking
> > will be a problem if I seal with thinned epoxy or polyester.
> > I have made a Lockwood Triple Pygmy from luan, and had no trouble
> > with checking on the varnished surfaces.
> > I also wonder what a Gypsy is like when swamped. I know it "never
> > happens," but when sailing my current 10 footer, it sometimes is a
> > factor when sailing where large powerboats are rentable.
> > Stan
Hi Chance,
fir (Marine Ply): $41 per sheet, Meranti marine plywood (1088) $53 per
sheet, glass cloth $4.25 per yard (say $15 per "sheet") assume the
same resin either way. Glassed ACX is $3.00 more. But you really ought
to glass the bottom in any case. If you compare ACX to fir marine
plywood you would probably come up with a similar differential. But
think of the labor difference.
Bob Chamberland
Bob Chamberland
--- In bolger@y..., Chance Curtis <sneakeasy2002@y...> wrote:
Is marine plywood just varnished, cheaper than acx glassed ?
> CCG
Bolger like his boats to swamp rather than flip. Either way you get wet. Is marine plywood just varnished, cheaper than acx glassed ?
CCG
prthober <prthober@...> wrote:"Bolger warns to keep the floatation high. Putting it low will make
the boat flip -turtle- if its placed too low."
The times I've capsized my Gypsy it did go right on over, daggerboard
up, but rolls right back very easily.
"Is ACX the same as AC which is recomended in Instant Boats?"
Yup
"Is 1/4 in acx fir better than 5mm luan?"
I think so.
Paul
Do you Yahoo!?
U2 on LAUNCH - Exclusive medley & videos from Greatest Hits CD
CCG
Yup
I think so.
Paul
Do you Yahoo!?
Yup
I think so.
Paul
Yup
I think so.
Paul
The baltic birch ProPly is designed for underlayment and even has
the nail pattern printed on it.
Hmmmm, that might look good - together with a tyvek sail!
The blonde luan was at Lowes Home center. The baltic birch ProPly is designed for underlayment and even as the nail pattern printed on it. Let me know what you think. With so much uncertainty about plywood here, I am temped to go with marine plywood and not fiberglass it. I had a 16 ft Speedliner runabout the was 30 years old and the guy I sold it to still has it in the water. Thoughts please.
CCG
wmrpage@...wrote:In a message dated 11/6/02 10:42:09 PM Central Standard Time,
sneakeasy2002@...writes:
waterproof-glued (didn't test it - it was a cold-molding job so it all got
epoxy saturated anyway) and void-free (seemed to be - we cut the sheets up
into lots of relatively narrow strips without encountering any that I
recall). It was "3-ply" - two very thin face sheets with the grain running
the long way, and one thick core perpendicular to that. This gave it quite
assymetric bending and strength qualities which is not characteristic of
regular plywood. It was also blonde in color, but I have no way of knowing if
the stuff you are looking at is the same or equivalent. If so, I would be
pretty cautious about using it as a direct substitute in a design where
plywood is specified - cautious, but open-minded. I have been planning to use
the same product (if still available) for a bunch of "furniture" I need to
construct this winter for a boat I'm overhauling, BUT...
That 5-ply Baltic Birch underlayment sounds intriguing! The 4X5 size would be
inconvenient for building a boat designed for 4X8 panels, but that wouldn't
be a consideration for my application. I guess I'll hustle my posterior down
to the local Menard's and see if they have any. Thanks for the tip!
Ciao for Niao,
Bill in MN
Do you Yahoo!?
CCG
> also 1/4 ProPly- 5ply baltic birch underlayment 4x5ft $9I used some luan underlayment sometime ago - it was claimed to be
Ciao for Niao,
Bill in MN
Do you Yahoo!?
Ciao for Niao,
Bill in MN
Ciao for Niao,
Bill in MN
ACX will be AC with waterproof (maybe) glue. Luan at $9.95 is probably
underlayment which may or may not be made with waterproof glue. If you
glass both sides of the underlayment it will probably be ok but at the
cost of better material. Luan is a catchall word for a large number of
wood species-really a meaningless term. You have to pay attention to
the glues used and at the Home Depots and such you will never know. If
you are building a throwaway boat then at least use ACX fir plywood.
Fir will check unless glassed. Luan underlayment probably won't check,
it will just fall apart.
Bob Chamberland
Bob Chamberland
> CCG
CCG
checking yet.
As to swamping - if you want to be able to easily self-rescue I would
suggest lots of floatation - mine has about 35% of the hull volumn as
floatation chambers and is easily righted and bailed out, even in
rough water.
Paul
CCG
checking yet.
rough water.
Paul
> goes.
checking
> Stan
Do you Yahoo!?
Stan,
checking yet.
rough water.
Paul
checking yet.
rough water.
Paul
> goes.
checking
> Stan
The book I have on design formulas shows fiberglass with a SM (Stress
Modulus) of 29000 and wood or ferro-cement at 1600. This is the stress per
sq.inch when the material starts to fracture under flexural stress.
Measured on a beam of 1 inch square. The further apart the frames, the more
flex too.
Your right about the plywood fracturing before the fiberglass, and by a
large margin but the case is that with only plywood you'd have about 400 as
the SM with a layer of fiberglass of say 1/32", you might just double that,
but you certainly would be better off than just 1/4 plywood.
Fiberglass is not the big safety factor some think, especially the thicker
the plywood but on 1/4", if would make a big difference.
Again, if the designer doesn't call for it, the stress are figured for just
the plywood so the fiberglass is optional. Mostly for abrasion and
checking.
flex too.
checking.
Sent: Sunday, October 27, 2002 9:57 PM
Subject: [bolger] Re: Plywood for gypsy
> Where does this factor of 19 come from? Numbers I recall would be more
> like half that, or less. And if the fiberglass is not stiff enough,
> all the strength in the world won't prevent the wood from breaking
> before the glass loads up. Can't remember the relative stiffness; and
> a lot depends on what weave and the direction of the load. Remember
> that stiffness and strength are very different things, tho sometimes
> correlated, and that much depends on fiber straightness and
> orientation.
> I think most of the designs we've been discussing don't need glass for
> strength.
> I know from personal experience that glassing the whole hull is a lot
> more work than just taping the seams. And I really don't see how this
> "envelope" has much to do with keeping the seams strong, since they
> are already taped. The only structural failure I've had was in the
> middle of a panel when I threw the boat in the water. A hazard of
> light boats and weak brains. Was glassed with 1 oz cloth and epoxy
> inside and out.
> --- In bolger@y..., "Jeff Blunck" <boatbuilding@g...> wrote:
> snip
> > It looks like fiberglass/epoxy is about 19 times stronger for a
> given
> > thickness of plywood. If that's so, adding a layer of 4 oz
> fiberglass could
> > easily double the strength of the 1/4" panel, at least for side and
> flexural
> > issues. If your going to coat in epoxy anyway, seems appropriate to
> throw
> > on 4 oz. fiberglass at the same time.
> > But, if the design doesn't specifically call for fiberglass, I
> wouldn't
> > think that the designer needed it for the structural strength.
> > Jeff
> > From: "David Ryan" <david@c...>
> > To: <bolger@y...>
> > Sent: Sunday, October 27, 2002 6:33 PM
> > Subject: Re: [bolger] Plywood for gypsy
> > > I think the fiberglass envelope keeps tack&tape/stich&glue boat
> from
> > > exploding along the seems.
> > > I suppose you could just tape both sided of the seams and a leave
> it
> > > at that. But that sounds like nearly as much work as just glassing
> > > sheer to sheer, and doesn't yield the same benefit.
> snip
FIberglass is pretty good in compression, also (unlike kevlar), but,
as with any other material in compression, keeping it straight is even
more important than in tension. It's not straight when it's woven
cloth. Straight fiberglass/epoxy is way too heavy to build up
stiffness and strength by making it thicker without piling on the
weight. That's one reason why cored and fiberglass covered ply are
popular. However, it's not clear to me that e-glass over plywood is
going to be stiffer and stronger (2 different issues) than an equal
weight (a little thicker) of plywood. Thickness is very important to
strength and stiffness in bending. Think about a piece of foam core
board vs. a piece of thick poster board. Think about a spruce 2X2 vs
1/2" steel rod (the spruce will be a bit lighter). Think about a 2X4
on edge and flat.
BTW, e-glass is very strong, it's just not especially stiff. That's
one reason why many of those glass sailplanes are stressed to 18g
instead of a more reasonable number like 6 or 8. The wings would be
noodles otherwise.
As far as checking, some kinds of plywood will, some won't. It's not a
marine/non-marine issue, but depends on what kind of wood. None will
if properly glassed.
on edge and flat.
noodles otherwise.
--- In bolger@y..., "Harry W. James" <welshman@p...> wrote:
> Fiberglass is very strong in tension. That is why it is used in an
epoxy
> matrix to hold the plywood together in stitch and glue. It is this
same
> strength in tension that stabilizes a surface and keeps the epoxy
> coating from breaking that makes sheathing a good thing. You can use
> very light weight fiberglass for sheathing.
> There is a very large weight gain in substituting fiberglass for
> planking if you are going to match stiffness and strength with wood.
At
> least that is what all the books say. That is why custom boats that
are
> concerned with weight use exotic composites or wood. Fiberglas isn't
> strong enough for the weight.
> HJ
> > No matter if you use ACX or marine plywood you will stil have to
fiberglas it for the needed strength --RIGHT OR WRONG ?
> > CCG
snip
Fiberglass is very strong in tension. That is why it is used in an epoxy
matrix to hold the plywood together in stitch and glue. It is this same
planking if you are going to match stiffness and strength with wood. At
least that is what all the books say. That is why custom boats that are
> No matter if you use ACX or marine plywood you will stil have to fiberglas it for the needed strength --RIGHT OR WRONG ?
> CCG
> jeff <boatbuilding@...> wrote:
> Fir or Pine ply will check, always. The key is to use fiberglass. But if
> you store it inside or covered and it gets to dry out between uses, checking
> isn't disasterous. Keep it well painted and protected from the elements and
> it'll probably last as long or longer than you'll need. If kept on a
> mooring, I'd glass it inside and out or go with a good grade of Luan and
> preferably an exotic marine ply like Okume or Meranti, but then it'll cost
> the same as glassing ACX, just less labor.
orientation.
strength.
inside and out.
orientation.
strength.
inside and out.
snip
given
fiberglass could
flexural
throw
wouldn't
> Jeff
> To: <bolger@y...>
from
it
snip
I've been doing some serious studing of hull design requirements. Hey I
figure if I can't build, study how to design it right?
It looks like fiberglass/epoxy is about 19 times stronger for a given
thickness of plywood. If that's so, adding a layer of 4 oz fiberglass could
easily double the strength of the 1/4" panel, at least for side and flexural
issues. If your going to coat in epoxy anyway, seems appropriate to throw
But, if the design doesn't specifically call for fiberglass, I wouldn't
> I think the fiberglass envelope keeps tack&tape/stich&glue boat from
> I suppose you could just tape both sided of the seams and a leave it
> If you really, really don't want to work with glass I think the
> original Instant Boat, ie fit&fasten are far better to do without
> glass. But even on those Payson recommends taping the seams.
> You've got to be about the first person on this list trying to
> substitute better plywood inplace of glass and/or epoxy. The rest of
> us waste WEST system trying to build things out of luan!
> YIBB,
> David
> >How about 1/4 plywood boats in general , like the the Sneakeasy; can
> >you replace plywood and fiberglas cloth and epoxy for with same
> >thickness of just painted marine plywood? Is the added strength of
> >glass needed or is it just used for waterproofing?
> >CCG
> > David Ryan <david@...> wrote:The Gypsy is designed
> >to be sheathed sheer to sheer, stem to stern,
> >in fiberglass.
> >>CCG
But if
checking
cost
> >>Jeff
> >>From: "Stan" <stankellar@...>
> >>Sent: Tuesday, October 22, 2002 2:14 PM
> >>Subject: [bolger] Plywood for gypsy
> >>> goes.
checking
> >>> Stan
> >>> Bolger rules!!!
posts
away
MA,
> >>Yahoo! Groups SponsorADVERTISEMENT
> >>Bolger rules!!!
> >>Do you Yahoo!?
> >>Y! Web Hosting - Let the expert host your web site
> >>Bolger rules!!!
> >C.E.P.
> >415 W.46th Street
> >New York, New York 10036
> >http://www.crumblingempire.com
> >Mobile (646) 325-8325
> >Office (212) 247-0296
> >Bolger rules!!!
> >Do you Yahoo!?
> >Bolger rules!!!
> C.E.P.
> 415 W.46th Street
C.E.P.
415 W.46th Street
>How about 1/4 plywood boats in general , like the the Sneakeasy; can--
>CCG
>in fiberglass.
>>CCG
>>Jeff
>>> goes.
>>> I am considering using AC fir ply for a Gypsy, and wonder if checking
>>> Stan
>>> Bolger rules!!!
>>Bolger rules!!!
>>Do you Yahoo!?
>>Bolger rules!!!
>C.E.P.
>415 W.46th Street
>Do you Yahoo!?
C.E.P.
415 W.46th Street
How about 1/4 plywood boats in general , like the the Sneakeasy; can you replace plywood and fiberglas cloth and epoxy for with same thickness of just painted marine plywood? Is the added strength of glass needed or is it just used for waterproofing?
CCG
David Ryan <david@...> wrote:The Gypsy is designed to be sheathed sheer to sheer, stem to stern,
in fiberglass.
C.E.P.
415 W.46th Street
Do you Yahoo!?
CCG
in fiberglass.
>No matter if you use ACX or marine plywood you will stil have to--
>CCG
>Jeff
>> goes.
>> Stan
>> Bolger rules!!!
>Do you Yahoo!?
C.E.P.
415 W.46th Street
Do you Yahoo!?
in fiberglass.
C.E.P.
415 W.46th Street
in fiberglass.
>CCG
>Jeff
>> goes.
>> Stan
>> Bolger rules!!!
>Do you Yahoo!?
C.E.P.
415 W.46th Street
CCG
CCG
> goes.
> Stan
Do you Yahoo!?
A Gypsy is highly swampable. It is narrow with a low freeboard and if you will sail it anywhere outside of a farmpond you will want to
add mucho floatation or you will not be able to self-rescue. Most people seem to deck the front all the way back to the mast as well
as rear section to form airtight chambers (add a hatch to keep things dry). Even with this done waves over 2' start getting scary. My
winter project is to deck 8"-10" along the side (I forget the proper boatbuilder's term for that) with some more floatation
underneath. I may eventually end up decking everything except for a footwell so I can take it out in anything. It great fun when the
wind blows hard but is a bit undercanvassed in light air.
> Stan
I got some 1 oz fiberglass cheap at Defender. Maybe a bit harder to
work with than the heavier stuff, but it works. I think URL is
www.defenderus.com
www.defenderus.com
> Thanks for the generous help!
> I think light cloth, at least on the outside, will be my approach.
> This seems to a be a very hospitable group.
> Thanks
> Stan
> Portland, Maine
>http://members.tripod.com/stanley119/
I built my Surf with 6-mm meranti, fiberglassing the bottom (6 oz)
and sealing all other surfaces with WEST System epoxy. I painted all
but the fore and aft decks, which I bright-finished with Sikkens
Cetol Marine Light varnish. Sitting out this past summer, the boat's
first, the aft deck checked badly... but not the fore deck. The aft
will have to be sanded down and refinished. I'm scratching my head;
all I can think of is that I spread the epoxy too thin on the aft
deck.
Just my (baffling) experience.
John
deck.
John
But if
checking
elements and
Luan and
it'll cost
> Jeff
> From: "Stan" <stankellar@h...>
> To: <bolger@y...>
Best of luck on you boat!
www.dreamwater.net/cosailor
Sent: Wednesday, October 23, 2002 7:38 AM
> Thanks
> Stan
> Portland, Maine
Thanks
Stan
Portland, Maine
Thanks
Stan
Portland, Maine
I will second this! If you use epoxy without glass over fir, you
might as well just paint.
OTOH: Even glass as light as 2oz with epoxy, then covered with
porchpaint will give you a multi season, maintenance free surface.
C.E.P.
415 W.46th Street
>You have to have some fiberglas with the epoxy, it can be lightweight,--
>but just epoxy will check, in my experience.
>HJ
>> goes.
>> Stan
>> Bolger rules!!!
C.E.P.
415 W.46th Street
> goes.
> Stan
Jeff is right using just epoxy will check eventually (west systems,
system three etc) There are very thin fabrics which can stop this in
its tracks. There isnt much more work involved with adding glass etc
and it will stop the checking. You could ude cloths from 2oz on up
but wouldnt need 6 oz cloth. You could even use other materials
other than fiberglass Dynel etc.
Ian
Ian
But if
checking
elements and
Luan and
it'll cost
> Jeff
> goes.
> Stan
goes.
Stan
goes.
Stan
