Re: restoring Bolger Otter
--- In bolger@y..., "bellyfeel2000" <isom@m...> wrote:
bad and epoxy only a little. Not a test I would recommend tho. Poly
is brittle (from experience), whereas epoxy stays more flexible. Look
for radial cracks from stress points. Worse come to worse, try to fix
a spot with poly. If it holds properly, the base is poly, if it comes
off, it is epoxy.
NO!! Let me qualify. Poly is not waterproof, epoxy is. Why repair
with an inferior quality product?
well), but epoxy is great for fixing poly.
Steve
> I recently inherited an Otter from an old freind. It is inrub
> relatively good shape other than some damaged areas on the upper
> rail. I understand that it was built in the early to mid 1970's.Not sure, but if you whack it with a hammer, poly will probably crack
> The hull does not appear to be peeling anywhere, so I am assuming
> epoxy resin was used instead of polyester.
> My questions are:
> 01. How can you determine what kind of resin was used in
> construction? Are there any specific tests?
off, it is epoxy.
>again?
> 02. If polyester resin was used, should I use polyester resin
>repairs
> 03. What kind of prep would be needed to use epoxy resin for
> on top of the old layup (if it is polyester)?Sand it rough (80 grit) and lay it on. Poly won't stick to epoxy(very
Steve
relatively good shape other than some damaged areas on the upper rub
My questions are:
02. If polyester resin was used, should I use polyester resin again?
03. What kind of prep would be needed to use epoxy resin for repairs
Any insight would be appreciated.
My questions are:
