Re: [bolger] Re: 75% Micro owner now!
Wow, one weekend and you've got the keel poured, the hull built and
you're working on deck beams : )
This boat is now in the right hands...It's begging for the Navigator
version.
Years ago I sailed on a friends Folkboat that he converted to chinese
junk rig, lots of fun.
Keep us all posted on your progress, and pics, we need pictures !!!!
Rick
brucehallman wrote:
> --- In bolger@y..., "John Cupp" <caj@k...> wrote:
> > I hope you opt to make the changes
> > for the Navigator...
> Yes, I have decided to go with a
> Navigator. The Navigator plans
> presume that you are modifying
> a standard Micro anyway. [As
> they call for you to take your
> dimensions from measurments from
> the hull.] Plus, I am curious to
> try a Chinese Gaff rig.
> Ironically, Rennie had started
> the hull as a Navigator, and then
> after his dad got sick, he cut it
> down to the standard Micro.
> I spent yesterday working on a bunch of
> tasks, the biggest being removing
> and replacing portions of the keel backbone
> strip, which was crooking by over an inch.
> [I had to fix it, as a crooked keel seemed
> like trouble.]
> I also laminated the curved beam
> that will support the aft end of
> the forward deck. Hope to install that
> beam today. Plus, I plan to remove
> Rennie's transom and replace it with
> the one that I had already built, as
> I liked my motor mount board more than
> his, [and he chose to put the boomkin
> hole on the 'wrong' side, at least
> according to my taste].
> I also schemed up a way to calculate the
> weight of my lead keel. Using a lever
> arm, and my 200 lb body, & moving the
> fulcrum to find the balance point, using
> algebra, it calcs out at only 350 pounds,
> versus the specified 400 lbs. As I
> plan to have two lead/acid batteries
> in the cabin, I am undecided whether to
> add some weight to the keel.
> > This boat was always destined for your
> > use so you should name it with that in mind.
> I am still favoring the name: "PCB's"
like trouble.]
Bruce, I am so glad that you picked that Micro up. It seems almost
like fate as you have the lead for the keel already. I hope you opt
to make the changes for the navigator as sometimes on the bay a
larger cockpit works much better to get in from the weather.
This boat was always destined for your use so you should name it
with that in mind.
John
> I am feeling pretty excited with a new 75% complete Micro in the
> driveway! Pictures to follow.
> All things went smooth picking her up, except the darn thing didn't
> fit in the U-Haul trailer that I rented; (that is until we tipped
> her on her side). U-Haul specs a 6'2" bed to their 6x12 trailer,
> but the hinges for the gate are only about 5'10" clear, with Micro
> being 6'0" wide.
> I ratcheted Micro down with nylon web straps. I think I was a sight
> on the freeway. I estimate the weight of the hull at 350 pounds,
> light enough for three people to lift, and for one person to drag.
> So me, Rennie (the builder) and his 19 year old son, loaded it on
> the trailer. I was able to pull it off and tip it on it's side
> single handed.
> Rennie was a fun guy, and a Bolger nut, this being his 20th boat
> built. His first was a Teal made in his apartment in college.
> The Micro is made of nice 5 ply 1/4" Okume with glass and epoxy on
> the outsides. Much of the framing is oak and has lots of Silicon
> Bronze screws and nails.
> My neighbor, dying of curiosity, (after eyeing me for 15 minutes),
> strolled over and asked "What-cha doing?" I casually
> replied, "Nothin'". <g>
> [& then explained everything]
> I had planned on build the Micro Navigator version, but
> the 'standard' Micro seems so roomy that I am having second
thoughts
> about Navigator. I will post pictures of my new 'Micro' soon
enough.
> It seems rather "Big", and capable. And fun.
being 6'0" wide.
single handed.
the 'standard' Micro seems so roomy that I am having second thoughts
about Navigator. I will post pictures of my new 'Micro' soon enough.
