[bolger] Re: Teal Opinions?
david ryan <davi-@...> wrote:
> From: Understanding Boat Design, 4th edition, Ted Brewer, Pp. 26
> "...stability varies as the cube of the length, while healing moment
> as the square of the length."
Ted Brewer wrote "healing moment"??!
My old boat had many healing moments, and each one cost me a thousand
dollars. It must have had a heeling moment too, but I never calculated
it.
Carter
original article:http://www.egroups.com/group/bolger/?start=2621
>snip
> Of course just because it's in print does mean it's true. Mr. Brewer
> has some rather unkind words for high-sided sharpies in the same book!
> snip
Well, presumably they're scaling the whole thing up linearly (i.e. all
3 dimensions together). Since I don't remember my hydrostatics, I don't
know exactly what the definitions are, but if you increase the length
and the displacement proportionally, but keep the same cross sections,
beam, etc., then the torque righting the boat at a given angle of heel
should go up with the first power of length. I say that because then
you have a force increased by the first power of the length acting at
the exact same distance proportional to the beam (actually, the
integral of the water pressure on the hull, but it amounts to the same
thing). I would bet that the way Mr. Brewer has it set up (presumably
the usual convention, whatever it is) is correct. I wish I had bought a
copy of PNA (Principles of Naval Architecture) when I could, and then
it would be easy to look this stuff up. Instead I have decades of
designing sheet metal boxes to remember past.
>original article:http://www.egroups.com/group/bolger/?start=2611
> >snip
> > i'm told that stablity increases as a function of the cube of the
> > length. longer means more boat to push into the water, right?
> > YIBB,
> > David Ryan
> > Minister of Information and Culture
> > Crumbling Empire Productions
> > (212) 247-0296
>That doesn't make a whole lot of sense. If your beam remains constant,
>then the stability should only go up to the extent that you have
>increased displacement to go with the length, right? (Assuming similar
>shapes, depth, etc.) If your beam goes up too, it's a different story.
>I must admit I can no longer recall my hydrostatics without more work
>than I'm willing to put into it right now.
David Ryan
(212) 247-0296
>snip
> YIBB,
> David Ryan
> (212) 247-0296
>I wonder if a longer hull of the same beam will be more tender?
>alex
> > I can stand and cast in my teal. Being longer, the surf *should* be
> > more stable.
David Ryan
(212) 247-0296
Alex,
If the shape and the beam of the boats are the same, and if one were
half again longer than the other, then you would get half again more
stability in the longer, i.e., it will take 50% more downward force on
the gunwale to immerse to the same depth. This is because there is
just more boat (more volume) to immerse. And I believe that Surf and
Teal have a similar 4 ft. beam, and double-ended shape - right David?
However, you can not lengthen the boom by half again and the mast by
half again, because the sail area will go up by a factor of 2.2,
creating a very tender boat.
Phil Lea
Russellville, Arkansas
"alex" <alex-@...> wrote:
original article:http://www.egroups.com/group/bolger/?start=2605
> alex
> > more stable.
alex
> more stable.
Ditto. I sailed my teal with my wife and airedale in Lake Washington. Had
a ball until the dog got excited. Quieted her with a beer. She then lay
down, bit the remaining cans and licked the little geysers. Ended up drunk
and jumping overboard for a duck. Great boat for rowing or sailing 2 agile
folks.
Rennie
>From: David Ryan <david@...>
>Reply-To:bolger@egroups.com
>Subject: [bolger] Re: Teal Opinions?
>Date: Fri, 11 Feb 2000 15:59:21 -0500
>>Hi Garth, Yes, I have a punt and it is VERY small. Really only for
>>an adult and in calm conditions, a small child.
>>I Have not seen a Teal, but Bolger says in his book..."one adult OR
>>two smallish children makes an overload in anything but
>>PERFECTLY smooth water."
>>So you better look at it carefully.
>Last summer I regularly sailed my teal in and around the surf zone in
>12-15 knots with 2 adults. If my boat floated when swamped it would
>have been real fun!
>Also sailed around the lake (warm and shallow) with my prego wife and
>newf in lighter air.
>YIBB,
>David Ryan
>(212) 247-0296
>GET A NEXTCARD VISA, in 30 seconds! Get rates as low as 0.0%
>Intro or 9.9% Fixed APR and no hidden fees. Apply NOW!
>http://click.egroups.com/1/933/5/_/3457/_/950302694/
>-- Easily schedule meetings and events using the group calendar!
>--http://www.egroups.com/cal?listname=bolger&m=1
Hey, yeah! I never meant to skip the plans. Cheap investment from HHP. Plans
PLUS book are the recipe to follow.
jeb
At 12:17 PM 2/11/2000 -0800, you wrote:
>I am working on a Teal now. I have attached the chime logs and am
>beguinning to put the bottom on. So far no problems except for one BIG
>epoxy hockey puck ( Important saftey tip: if you heat resain to remove
>crystals, let it cool before you mix a big batch).
>I highly recomend that you get the plans, as opposed to trying to build
>from the books. The Teal plans have obvious updates, some of which are
>performance -enhancing, and some affect construction. I would have
>figured out the construction-critical ones by now (with some help from
>a moaning chair), but pry never would have run into the performance
>enhancements. Also, you can scale from the plans, if you are going to
>add modifications like floatation.
>DGO.
>Get what you deserve with NextCard Visa! Rates as low as 2.9%
>Intro or 9.9% Fixed APR, online balance transfers, Rewards Points,
>no hidden fees, and much more! Get NextCard today and get the
>credit youdeserve! Apply now! Get your NextCard Visa at:
>http://click.egroups.com/1/929/5/_/3457/_/950300450/
>eGroups.com Home:http://www.egroups.com/group/bolger/
>Blake,
>For what it's worth, H.Payson's favorite of Instant Boats
>was/is? Surf. Surf is a 15'6" long on about the same midsection
>as Teal. This make for Surf's easier ply bending. I do not
>think a double-ended hull is significantly less stable (unless
>your have a motor near the transom) than a hull with a square
>transom, if that's what you meant. However, a 3'7" beam is not
>very stable in my books.
more stable.
David Ryan
(212) 247-0296
Blake,
At any rate, I suggest to buy a plan even if it has been
published in a book. As they say in Texas, it's decorative
and functional... when construction is finished you can frame
it and hang on your favorite wall.
alex
"blake sartin" <bsarti-@...> wrote:
original article:http://www.egroups.com/group/bolger/?start=2542
> Hello group-
> I am a new member, I've been poking around on the internet for the
past few
> weeks looking for the exact boat to build. I've looked at Stevenson,
> Bolger, and Carnell's boats.
> I originally chose the Stevenson 3-in-1, but after receiving the
plans I am
> not that impressed with the design as it seems fussier than it should
be and
> heavier due to all of the topside finishing. It also incorporates a
CB box
> that I am not thrilled about.
> After finding this group I began to consider some of Bolger/Payson's
plans
> and decided on the Elegant Punt, but now I am thinking that maybe
this boat
> is just a bit too small. Therefore, I am considering building the
Teal
> instead, as the costs seem to be about the same. Also, I like the
lines a
> lot more and it will fit well on the roof of my VW Camper at 12'. I
also
> think that the double-pointed shape looks really nice, although I'm a
little
> concerned about stability.
> Has anyone had any real-world experience with either building or
sailing
> this vessel? And could you share your experiences?
> I appreciate the help.
> Blake
> Knoxville, TN
have been real fun!
David Ryan
(212) 247-0296
To: <bolger@egroups.com>
Date sent: Fri, 11 Feb 2000 12:48:20 -0500
Send reply to:bolger@egroups.com
Subject: [bolger] Teal Opinions?
Hi Garth, Yes, I have a punt and it is VERY small. Really only for an adult and in calm conditions, a small child.
Good luck, Don
> Hello group-
> I am a new member, I've been poking around on the internet for the past few
> I originally chose the Stevenson 3-in-1, but after receiving the plans I am
> not that impressed with the design as it seems fussier than it should be and
> heavier due to all of the topside finishing. It also incorporates a CB box
> After finding this group I began to consider some of Bolger/Payson's plans
> and decided on the Elegant Punt, but now I am thinking that maybe this boat
> is just a bit too small. Therefore, I am considering building the Teal
> instead, as the costs seem to be about the same. Also, I like the lines a
> lot more and it will fit well on the roof of my VW Camper at 12'. I also
> think that the double-pointed shape looks really nice, although I'm a little
> Has anyone had any real-world experience with either building or sailing
> Blake
> Knoxville, TN
> GET A NEXTCARD VISA, in 30 seconds! Get rates as low as 2.9%
>http://click.egroups.com/1/932/5/_/3457/_/950292287/
> -- Talk to your group with your own voice!
> --http://www.egroups.com/VoiceChatPage?listName=bolger&m=1
DGO.
I know of no more elegant transformation of two sheets of plywood than Teal. HHP's step by step's (with the help of Karen) in Instant Boats is unbeatable. Stability is excellent for her size. My only hesitation is your desire for more room. Teal is a stretched punt. You'll get more performance from Teal, but not much more room. You'll still want to sail her from low down, center. But for fast, economical reward and satisfaction for your effort Teal would be my vote. Good luck.
jeb
On Fri, 11 Feb 2000, Blake Sartin wrote:
> Hello group-
> Therefore, I am considering building the Teal instead, as the costs
> seem to be about the same. Also, I like the lines a lot more and it
> will fit well on the roof of my VW Camper at 12'. I also think that
> sailing this vessel? And could you share your experiences?
Yes, I've built one, and you can see it (and me) at:
http://www.friend.ly.net/user-homepages/d/dadadata/boat/bolger.html#Boats
It's easy and fun to build. It's very attractive. It's not very large,
although two adults can easily sail in her. She sails well, IMHO.
http://www.ace.net.au/schooner/sites2.htm#start
will take you to two other views of the boat.
It's stable enough, in that we've never come closs to dumping her. But I
sail reasonably conservatively; I am not a racer.
She's cheap, attractive, and easy to build. You can't go wrong, unless
you can only ever build one boat for all purposes for the rest of your
life. If that's the case, think carefully. If it's not the case, Teal is
a great place to begin.
-Chris
Blake:
You should look over Jim Michalak's designs:
http://marina.fortunecity.com/breakwater/274/michalak/designs.htm
Also the Duckworks Boat Index has links to over a thousand boat designs
organized by type then length:
http://www.hilconet.com/~dworksmg/boatindex/index.htm
I hope this helps.
Chuck Leinweber
http://www.duckworksmagazine.com
Sent: Friday, February 11, 2000 11:48 AM
> Hello group-
few
am
box
boat
little
> Blake
> Knoxville, TN
plans
this boat
sailing
I built an Elegant Punt. I felt it was more narrow and high-sided than
I liked in a dinghy. I must admit, however, that by the time I finished
building it I didn't have need of a tender, so I only took it rowing a
couple of times. In The Folding Schooner, Bolger allows that the Teal
is a better boat for the same material and effort.
Hello group-
Blake
Knoxville, TN
Hi,
This doesn't answer your question, but IMHO the best thing you can do is buy
Carnell's boat plans. Even if you don't intend to build it studying the
plans is very informative. The best thing is that Carnell includes what
amounts to a basic boat building course with his plans. There is about 30
pages of information including sources, fiberglass and epoxy information,
tools, etc., presented in a fun and easy to read format. The information
alone was worth the price of the plans.
James Fuller
Sent: Friday, February 11, 2000 10:48 AM
> Hello group-
few
am
box
boat
little
> Blake
> Knoxville, TN
