[bolger] Re: What we really did wrong
On the subject of learning more about boatbuilding as you go along:
I am building my 5th boat, and it occurs to me that after about ten or
twelve more, I will have this down to the point that if I were to build and
sell one of these boats for what it is worth, I would be making about $1.27
per hour not counting materials.
Onward through the fog.
> I reported that we ended up with an unseemly amount of extra side plank
> at the top of our set up and that we should have kept the frames flush
> to the shear. Not quite right. We put the frame bottoms and the side
> plank flat against the floor and didn't see that with the sides at an
> angle the outside edge touches before the inside. This is where the
> bevel should go when the chines go on. It is on the plans which I know
> you need to study until you completely understand each diagram. The
> plans say to position the frames flush with the bottom of the sides but
> it should have been the inside edge. With the 1/4 ply it is hard to see
> this small difference with middle aged eyes. Would have raised our
> frames about 1/16 to 1/8 and given us a seemly surplus all around. We
> will have a gap of about 1/16 to fill on the inside edge of the chine.
> Should be fairly easy with epoxy putty. It is not a mortal mistake but
> it is a pretty good example of not spending enough time with the plans
> and being in a hurry to see a boat shape and ignoring the feeling that
> something is not quite right. I think also that having built a tack and
> tape type instant boat where you ignore these small bevels may have
> installed some default settings that need to be reset.
> Peace,
> Leander
> MyPoints-Free Rewards When You're Online.
> Start with up to 150 Points for joining!
>http://clickhere.egroups.com/click/805
Peace,
Leander
Peace,
Leander
