Re: Champlain building jig nessecery?
Hi Claus,
Perhaps you could trade some of your plans for a set of
CHAMPLAIN plans from someone in your postion,ie;plans rich but
boatless :-)
Indeed,a set of plans will answer many of your questions
regarding construction details.I am,however,surprised that no one on
this list who may have a set of CHAMPLAIN plans has not chimed in to
throw some light on your questions. I know that Paul Simard( of this
group) has a set of plans and hopes to build in the spring( I think)!
40 sheets sounds like is should do it for the CHAMPLAIN,unless
you make a lot of errors :-(
Regarding the jig;CHAMPLAIN is smaller then WINDERMERE
therefore will require a smaller jig.Nothing more then about 45 X 2"
X 4" X 8'.Also,I do not know if the box keel on the CHAMPLAIN is used
for storage(hollow) or floatation(filled with foam).On WINDERMERE,it
is used for batteries,lines and anchors etc and is built to tough.
Anyway,do not be discouraged!!! She is a beautiful boat and
will be great fun to use!!!Maybe you could build the BRICK dinghy,
which goes on her roof top, for a warm up practice before
CHAMPLAIN?!?!
Good Luck!
--- Inbolger@yahoogroups.com, "aquatronclaus <aquatronboat@h...>"
<aquatronboat@h...> wrote:
> Many Thanks for your support Peter!
> I had hoped that I could force the plywood in place over the
boxkeel
> similar to the Micro Trawler, maybe it can be done in this way if I
> use 1/4" laminated to the thikness the bottom needs? I am not
> pleased with that very big set up as you have done, maybe it has to
> be that way? I guess I need to order the plans so I can take a
> closer look. I have 15 set of different plans already, so why not
> one set more. I like the way the bottom is constructed on the
> Idaho,Dakota, and the ultimative Sharpie the Wyoming, but the Idaho
> has not the space I like and the Dakota is too big and of course
> they don´t have the beam and the box keel. I have calculated
arround
> 40 sheets of ply, do you think it will do it? I am really looking
> foreward to see more to your Windermere, it seemed to be a grat
> project. Again many thanks for your support.
> > > Claus
--- Inbolger@yahoogroups.com, "Peter Lenihan <ellengaest@b...>"
<ellengaest@b...> wrote:
> Hello Claus,
> There is not very much detailed information on the net about
> beautiful CHAMPLAIN.......only pictures and study plans.The most
> detailed material I have seen,however,is the self published manual
> from Han Van Pelt which might serve as an excellent annex for the
> building plans/instructions.
> I have not seen the CHAMPLAIN plans,thus cannot comment on
just
> how Bolger recommends she be built/assembled.
> If by"small sea passages" you mean protected water or
sheltered
> water,then the answer is yes.If open stretches are what is
intended
> however,then I would say a reserved yes,just so long as you be
> careful about the weather forcast.
> I am the builder of the WINDERMERE and my pictures show a
basic
> building jig.Very,very easy to build and very important for the
> proper assembly of the WINDERMERE bottom and boxkeel.Again,I have
not
> seen the CHAMPLAIN building instructions so cannot comment about
> Bolgers recommendations.
> The hull and sides for WINDERMERE are cut out from a full
size
> pre-assembled panel measuring aproximately 8' X 32'.Onto this
panel
> is traced the profile(outline) of the sides as prescribed by
Bolger.I
> believe it is the same process for the CHAMPLAIN,ie; panel
dimensions
> 8' X 24'.
> I can appreciate your attraction to this beautiful design
since
> it offers so much space,capacity,comfort and economy in a tight
(small)
> package.There is nothing really complicated about the building of
her
> but you must adhere to the plans from the designer.Whether or not
you
> possess the abilities/talents to actually build a CHAMPLAIN is
> difficult to say.If you have successfully built other boats(larger
or
> smaller),then I would hope the CHAMPLAIN falls within your
talents.If
> you have built other structures like houses,cabins etc,the same
> applies,in so much that wood working tools are not strange to you.
> Boat building,especially Beautiful Bolger Boxes,is not
> complicated.It simply is an orderly sequence of small steps,like a
> jig-saw puzzle.You start off with a finite number of parts and end
up
> with one cohessive whole.A process of ellimination,as it were.
> Finally,25 sheets of 1/2" plywood sounds like the begining of
> something beautiful!!
> Sincerely,
> Peter Lenihan,builder of easy jigs/strongbacks and WINDERMERE,from
> along the St.Lawrence............
> , is
> > that boat capable to make small sea passages? The only thing I
see
> > is, that the windermere builder has build a very complicated jig
> set
> > up, is that really nessecery? Is it not possible to built it the
> > Sharpie way, wher the bottom is laid and bend over the sides and
> > then attach the boxkeel on the bottom? Are they other ways to
build
> > that boat, if you don´t like to do the complicated jig setup? Is
> the
> > cabin sides plywood, or lumber like on the Idaho? How many
sheets
> of
> > ply do I need for building this design, I have already 25 sheets
> for
> > the Idaho 31, but I hope to use them for the Champlain instead.
I
> > hope this design not is too complicated for me, I am sure that I
am
> > able to built the Idaho after I have read the plans and
> descriptions
> > over and over again, I don´t hope the Champlain is more
> complicated,
> > just some more works and materials I guess.
I had hoped that I could force the plywood in place over the boxkeel
they don´t have the beam and the box keel. I have calculated arround
> > Claus
Hello Claus,
There is not very much detailed information on the net about the
I have not seen the CHAMPLAIN plans,thus cannot comment on just
If by"small sea passages" you mean protected water or sheltered
water,then the answer is yes.If open stretches are what is intended
I am the builder of the WINDERMERE and my pictures show a basic
proper assembly of the WINDERMERE bottom and boxkeel.Again,I have not
The hull and sides for WINDERMERE are cut out from a full size
pre-assembled panel measuring aproximately 8' X 32'.Onto this panel
is traced the profile(outline) of the sides as prescribed by Bolger.I
believe it is the same process for the CHAMPLAIN,ie; panel dimensions
8' X 24'.
I can appreciate your attraction to this beautiful design since
it offers so much space,capacity,comfort and economy in a tight(small)
package.There is nothing really complicated about the building of her
but you must adhere to the plans from the designer.Whether or not you
difficult to say.If you have successfully built other boats(larger or
smaller),then I would hope the CHAMPLAIN falls within your talents.If
jig-saw puzzle.You start off with a finite number of parts and end up
, is
> that boat capable to make small sea passages? The only thing I see
set
> then attach the boxkeel on the bottom? Are they other ways to build
> cabin sides plywood, or lumber like on the Idaho? How many sheets
for
> the Idaho 31, but I hope to use them for the Champlain instead. I
> hope this design not is too complicated for me, I am sure that I am
descriptions
complicated,
> Claus
I have searched for the boat for me, I now am sure that is has to be
the very lovely Champlain, that boat has a lot of usefull space, is
is, that the windermere builder has build a very complicated jig set
that boat, if you don´t like to do the complicated jig setup? Is the
cabin sides plywood, or lumber like on the Idaho? How many sheets of
ply do I need for building this design, I have already 25 sheets for
able to built the Idaho after I have read the plans and descriptions
over and over again, I don´t hope the Champlain is more complicated,
Claus
