[bolger] Re: potter vs. Micro
Hi Carter
Carter Kennedy ha scritto:
a lot of sail, and I guess it would cost at least twice w.r.t. a Micro.
I've plans for both boats. At the end I went for the Micro also because
the LM won't fit into my garage. Theoretically speaking the Long Micro
should be more seaworthy than the Micro...
Best, Pippo
> I wonder why the Micro is so much more popular than the Long Micro. II tend to agree with you. However, Long Micro has extremely long spars,
> have never seen either one, but it sure seems like even Phil Bolger
> can't put more room in the inside than there is on the outside. It
> looks like the LM has more of everything, including room to stretch
> out, waterline length (speed), and the safety of size when it comes to
> heavy weather.
> Perhaps the added cost and time are out of proportion to the added sizeYes, that's the main point...
> benefits.
Best, Pippo
David, I did the same, and as a result, the cabin and the cockpit seats
are now individual water tight compartments.
Stan, Snow Goose
David Jost wrote;
(snip)
Stan, Snow Goose
David Jost wrote;
(snip)
> When you build a boat yourself, you are getting a custom job. I(snip)
> plan to leave out the air vents in the forward and stern bulkheads on
> MICRO and opt for no-seeum screening over the cabin hatches
I never said tht the Potter was better, just that the Micro isn't alone
as a nanocruiser.
heavy weather.
In other words, if some's good, more's better.
benefits.
Carter Kennedy
"david jost" <djos-@...> wrote:
original article:http://www.egroups.com/group/bolger/?start=2565
as a nanocruiser.
heavy weather.
benefits.
Carter Kennedy
> yes, I agree that the Potter is s-l-o-w. They ride up and over thetwice
> waves like a duck. therefore, it must seem as if they have to go
> as far to cover the same distance. i don't know, it just seems thatin
> way.
> If you were looking for an off the shelf Micro-cruiser, I would
> choose the Precision 16, It has a high aspect cb and pretty good
> performance figures for a 16 footer. Taylor's pretty well respected
> the yacht design area. But, it won't self-steer, and it could beprone
> to capsize if driven carelessly.
> MICRO and opt for no-seeum screening over the cabin hatches (it is
> amazing how those little things can bite, the green head flies are
> another matter). I can then button the boat down in a blow with the
> confidence that it is not going to swamp unless I put a hole in it.
> Hopefully it will float on its lines until help of some sort arrives.
waves like a duck. therefore, it must seem as if they have to go twice
way.
performance figures for a 16 footer. Taylor's pretty well respected in
the yacht design area. But, it won't self-steer, and it could be prone
way.
