Re: [bolger] Re: Idaho 31
>> but my final choiseSometimes I think that's one of the harder things about boat
>> stood between the Idaho and the Tennessee.
>> Claus
building. Which one next!
Claus,
Can we have a progress report. I plan to start an Idaho soon and
would be interested in your comments. Have you changed anything or
are you staying close to the plans?
Charles
--- Inbolger@yahoogroups.com, "aquatronclaus <aquatronboat@h...>"
Charles
> I have laminated the ply for the bottom on an Idaho 31. I haveone
> planned to draw all the stations and use the chine log (internal)
> (its 2 pcs. 1x2 laminated final to 2x2) I will install the first
> and use it as battern and then saw. I am first time builder, will Iit
> run into problems with the Rocker in the stem that way? I will
> laminate the second chinelog before attaching the sideplanks. In
> fact its a lovely very simple boat, its not my perfect dreamboat,
> would have been Champlain, Topaz and of course the Wyoming, thethe
> Dakota is also a great design, but my final choise stood between
> Claus
--- Inbolger@yahoogroups.com, "Jeff Blunck" <boatbuilding@g...>
> Just put blocking under the forward section of the bow to getreasonably
> close the rocker profile shown in the plans. This will pre-stressthe
> bottom to the approximate rocker shape allowing you to laminatethe chine
> logs in place and also makes putting the side panels on mucheasier.
>up the
> Even on the Wyoming I found this easy to do after I had laminated
> bottom panel(s). Once the chine logs are on it gets much harderto move. I
> found I had about 1 inch of movement available to fit the sidepanels
> without feeling like I was forcing anything.Thanks Jeff!
> Jeff
>one
> From: <aquatronboat@h...>
> Sent: Sunday, December 22, 2002 12:03 PM
> Subject: [bolger] Idaho 31
> > and use it as battern and then saw. I am first time builder,will I
> > run into problems with the Rocker in the stem that way? I willdreamboat, it
> > Idaho and the Tennessee.horses
> > Claus
> > - no cursing, flaming, trolling, spamming, or flogging dead
> > - stay on topic, stay on thread, punctuate, no 'Ed, thanks,Fred' posts
> > - add your comments at the TOP and SIGN your posts and<snip> away
> > - To order plans: Mr. Philip C. Bolger, P.O. Box 1209,Gloucester, MA,
> 01930, Fax: (978) 282-1349http://docs.yahoo.com/info/terms/
Just put blocking under the forward section of the bow to get reasonably
close the rocker profile shown in the plans. This will pre-stress the
bottom to the approximate rocker shape allowing you to laminate the chine
logs in place and also makes putting the side panels on much easier.
Even on the Wyoming I found this easy to do after I had laminated up the
bottom panel(s). Once the chine logs are on it gets much harder to move. I
found I had about 1 inch of movement available to fit the side panels
> (its 2 pcs. 1x2 laminated final to 2x2) I will install the first one
> fact its a lovely very simple boat, its not my perfect dreamboat, it
> Dakota is also a great design, but my final choise stood between the
> Claus
Claus
Claus
