Re: Opinions welcome
The only two problems I see at the moment are what to do with the
profile, and the displacement. Motorboats usualy have a ballance of
the entry lines, and a flat section to the rear. This presumably
(MBs aren't my forte) determines the pad the boat plane on. By just
adding a big section in the middle, one will upset that ballance, and
I would want to know that was a good thing before trying it. Ii
would be possible to fair in a section that had some curve and some
flat to it, but that would be significantly more complicated, since
in essence the forward section would be raised, creating structural
and aesthetic dicontinuities.
The other issue on my mind is diplacement, seems like this will add
more diplacement than load. Whether that is true depends on what you
put on board, more people?, but if it is just sleeping quarters, the
boat will probably float a lot higher, relative to the size of the
lower hull. I would just be carefull about that, because presumably
the deadrise is relative to a certain amount of weight, and
particularly if you add a flat mid section, no more motor, or people,
your displacement will go up more than your load, and you may end up
precariously perched on the shoe. Also this displacement fore and
aft will have a significantly different ballance, since 2/3rd of the
boat will now be the flat full dept stuff.
On 26 Dec 2002, at 0:02,teakdeck@...wrote:
usually is an improvement, as jim michalak points out.
I also recall Bolger mentioning (in the discussion of bobcat?), that
"more length would add speed out of proportion to the added cost".
Thats displacement boats, though.
hannes
> Splice in an 8' section? Great idea!I agree - go for it! Lengthening a boat on the same midsection
> Just do it.
hannes
--- Inbolger@yahoogroups.com, "Richard Spelling" <richard@c...>
with PB&F before you do any cutting. From my understanding, the
superstructure on Microtrawler is integral to the overall strength of
the hull. Hawkeye, which is a bigger version without superstructure,
has a much stronger series of of web framing in the hull.
"... because the space under the deck is full of web girders needed
to make her stiff on such a light weight. Bottom and deck form a deep
honeycomb sandwich. The 1/2 inch deck feels as solid as a concrete
slab. The Microtrawler design (Chapter 54) shows what can be done by
utilizing the depth of the keelbox and by planning for cabin rather
than deck from the first concept." BWAM page 79
> Have you considered selling it and using the money to buy/build abigger
> boat?I would tend to agree with this opinion. At the very least, confer
--- Inbolger@yahoogroups.com, "sctree <sctree@d...>" <sctree@d...>
the MT more useable would be a lot less work and expense. Just a
small suggestion would be to make the new addition slightly lower
than the existing giving a trawler effect and maybe adding a stack to
complete the illusion! Technically the bottom has a flat run where
you would cut so splicing in an 8 foot section shouldn't affect the
sheer line at all. I have had the same idea for the MT should I
build one someday. In the meantime my Sneakeasy is great fun!!
Steve Bosquette
> I have a Microtrawler that is slightly modified. There is no aftwanted.
> house, so I have a nice fishing cockpit, and there is a removable
> canvas on pipe tent that completely closes in the cockpit when
> RickI like the idea! It would be nice to build a Champlain but to make
Steve Bosquette
Have you considered selling it and using the money to buy/build a bigger
boat?
boat?
Sent: Thursday, December 26, 2002 12:00 PM
Subject: [bolger] Re: Opinions welcome
> Hi Rick, What you have is a nice little Microtrawler. What you propose
> is to convert it into a half-assed Champlain. It looks to me like you
> will need a new engine too.
> Why don't you build a Champlain?
> Bob
> > canvas on pipe tent that completely closes in the cockpit when wanted.
> > The cockpit is great, and I love the pilothouse. What's missing is
> > something in the middle. My thought this winter is to cut her in half,
> > and splice in an eight foot section.
> > Any comments?
> > I posted a current photo, as she is, and a couple that my kid
> > stretched on the computer. They are in the photo section of this group
> > under "MT Stretch".
> > This link might work;
> >http://photos.groups.yahoo.com/group/bolger/
> > Rick
Bob
Bob
> Any comments?
> under "MT Stretch".
> Rick
Sawing into an existing boat can be a refreshing exercise:
http://mkstocks.tripod.com/boats/martha_jane/deconstruction/
Mike
Mike
>half,
> and splice in an eight foot section.group
> Any comments?
> under "MT Stretch".
> Rick
Just do it.
MM
Just do it.
MM
Rick, go for it. It might not plane as well when extended without a
bigger motor but the room fishing and sleeping without mosquito's is
more than worth the cost.
John
John
>half,
> Any comments?
> under "MT Stretch".
> Rick
Any comments?
under "MT Stretch".
Rick
Any comments?
under "MT Stretch".
Rick
