[bolger] Re: Which side is best for an outboard?
When you face aft from the cockpit your right arm is most used for pulling
and the port side gives a straight pull for the right arm. Thats what I thought.
Steve Yahn
Steve Yahn
>wow, that is an interesting thought! Almost every outboard auxilliary
>I have seen has been on the port side of the transom. I wonder why.
> Perhaps it is because the handle is on the port side on the
>outboard. Would that allow less intrusion into the cockpit? The gas
>speed controls on the smaller units are on the other side making them
>closer to the cockpit. I guess it is items like this that you need to
>consider. Look at the unit and visualize what if I start turn,
>accellerate, stop, lift, reverse the thing. Where will the gas tank
>fit? When will you use the motor most? going out on starboard tack
>(port side is best to prevent cavitation) or on port tack? (opposite
>would be true)
> I can't think of any other reasons for its location.
>"chuck" <cpcorrei-@...> wrote:
>original article:http://www.egroups.com/group/bolger/?start=2585
>> Hi Everyone,
>> I am finishing up my F.S. The original builder did not build the
>> outboard well and was not planning on using a motor. The push/pull
>> tiller arrangement on the F.S. uses a horizontal extender out to
>> starboard to give the angle needed for the push/pull tiller rudder
>> setup. Since the original builder did not build the motor well to
>port
>> as per plans, the extender was built to port.
>> So now, since I will be sailing on the San Francisco Bay, I want an
>> outboard. Will placing the well on the starboard side oppisite of
>> plans, in the same fashion, affect the boat in any way different than
>> if it were on port?
>> I can't think of a reason it would, just thought I would ask before I
>> cut wood.
>> Chuck C.
>Get what you deserve with NextCard Visa! Rates as low as 2.9%
>Intro or 9.9% Fixed APR, online balance transfers, Rewards Points,
>no hidden fees, and much more! Get NextCard today and get the
>credit you deserve! Apply now! Get your NextCard Visa at:
>http://click.egroups.com/1/930/5/_/3457/_/950397373/
>-- 20 megs of disk space in your group's Document Vault
>--http://www.egroups.com/docvault/bolger/?m=1
Port side is preferred as you then sit on the port side, looking to
starboard and all the boats you have to give way to...
Paul W. Esterle
423.989.3159
S/V Bryn Awel, Columbia 10.7
Bristol, Tenn. USA
Paul W. Esterle
423.989.3159
Bristol, Tenn. USA
To: <bolger@...>
Sent: Saturday, February 12, 2000 6:16 PM
Subject: [bolger] Re: Which side is best for an outboard?
> would be true)
> > Hi Everyone,
> port
> > if it were on port?
> > cut wood.
> > Chuck C.
would be true)
would be true)
> Hi Everyone,port
> if it were on port?
> cut wood.
> Chuck C.
Hi Everyone,
setup. Since the original builder did not build the motor well to port
if it were on port?
cut wood.
Chuck C.
if it were on port?
cut wood.
Chuck C.
