[bolger] Re: re;leeboards on a MICRO
You got it Steve, are you sure they weren't from Missouri?
Stan, S. G.
In a message dated 2/13/2000 5:09:22 PM Eastern Standard Time,
smuller@...writes:
<< this was the only one that I
just couldn't get through to. You have to forgive them, we are in
Missouri where the idea of a cruse is to get into the bass boat with its
100+ HP outboard and go zipping across the lake, so you can get there
before the fish wake up. >>
This reminded me of our sail yesterday - I had Landroval out for her second
sail ( which was better than the first) - another couple was sailing a Pocket
cat 18 and as we came into the dock ( central florida) two guys came in on
their bass boat and the one - (at least one beer too many) - said in a thick
drawl - while looking up at our two sailboats - That's just too damn much
work for me - How can you go out on the lake when it's that much damned work.
I just wanna get me in a boat and step on the gas. Steve Anderson
> > >Chuck,
> Thanks for elloquence and brevity........it is enough to make
> me jealous were it not for more pressing concerns of preserving my
> extremities from imminent frost-bite on this Godforsaken piece of
> real-estate in the middle of the not-yet-thawed St.Lawrence.Mille
> merci!!!!
> Sincerely,
> Peter Lenihan
Peter, you were eloquent, I was only brief
I hate to say this, but the weather here today is: high 70's, blue sky,
gentle breezes...
Chuck, trying not to enjoy the weather too much
Peter, I have printed your email, and delivered it to my neighbor.
I have to admit, I had the biggest, "I told you so" smile on my face
that I could muster.
The same as any other Micro builder, I have gotten a lot of, "why is
it this way?" questions from my friends and this was the only one that I
before the fish wake up. Things like center of gravity just don't get
into the formula.
Thanks, for making me look good, Stan, Snow Goose
"chuck leinweber" <chuc-@...> wrote:
original article:http://www.egroups.com/group/bolger/?start=2625
> Peter:
> If I may be so bold as to try and sum up your eloquent essay: If you
want an
> Micro-like boat with leeboards, find one that has already been
designed, or
> commission the design of one.
> Chuck Leinweber, basking in the warm Texas sunshine
> From: peter lenihan <ellengaest@...>
> To: <bolger@...>
> Sent: Sunday, February 13, 2000 10:11 AM
> Subject: [bolger] re;leeboards on a MICRO
> > Hello,
> > I cannot see exactly why anyone would want to tamper with the
> > proven success of the MICRO keel,as presented on the plans.To
begin,you
> > are pretty much left on your own regarding the designing of YOUR own
> > leeboard not to mention just where,and how you will attach the
board to
> > the hull.Where ever you calculate the board should go,you can be
sure
> > the hull section at that point has NOT been designed/engineered to
> > recieve the stresses of a leeboard,so once again you are left to
your
> > own devices/risks.
> > Consider also the question of ballast.With internal ballast,I
> > imagine that that the center of gravity will be somewhat
raised,hence a
> > more tender(tippier?) boat.Also,you still have to get 450lbs of
lead on
> > that boat,whether it is hung outside or laid inside.In
otherwords,just
> > how much grief does one wish to subject oneselves to?
> > Furthermore,the interior of the MICRO IS roomy but will be
less so
> > once you begin to incorporate internal ballast tanks(if going with
> > water) but what is of considerable importance is this,with internal
> > lead ballast you must find a sure-fire way to SECURE that lead or
else
> > in a knockdown(however slight and quick and it will
happen......)that
> > lead is going to become very much a battering ram,of sorts,and may
> > seriously damage your boat,to your great misfortune.So,once
again,you
> > are left on your own to puzzle out things like,well,how thick should
> > the bottom now be?,how many bolts should I use to secure the
lead?do I
> > have to add more frames?will it be strong enough?etc,etc Instead of
> > proceeding,with confidence,with what should be a very
> > rewarding,fun,activity........boatbuilding!!!
> > One final thought that does manage to rise through the frozen
> > vapours is this,when all hell is breaking loose around you ie;lots
> > big waves,bigger wind and a rapidly approaching lee-shore,that
> > wonderfully long full-lenght keel on the MICRO will be doing its
> > damnest to keep you off of that shore!I have had the
> > nerve-racking,bowel-loosening,nail-biting,toe-curling pleasure of
> > experiencing this phenomenon on a number of occassions and have
> > survivrd intact,along with the boat,to tell the tale!
> > Kindly remember,that all of the above is nothing more then my
own
> > friendly advice designed to ensure that the MICRO does not surrender
> > its lofty status as number 1 small homebuildable boat and that
there is
> > nothing worse then a totally smitten MICRO owner/builder giving
advice!
> > Sincerely,
> > Peter Lenihan,in the grips of another blasted arctic day,on the
still
> > frozen polluted banks of the St.Lawrence river...........
> >Chuck,
merci!!!!
Peter:
If I may be so bold as to try and sum up your eloquent essay: If you want an
Micro-like boat with leeboards, find one that has already been designed, or
To: <bolger@...>
> Hello,
> proven success of the MICRO keel,as presented on the plans.To begin,you
> leeboard not to mention just where,and how you will attach the board to
> the hull.Where ever you calculate the board should go,you can be sure
> recieve the stresses of a leeboard,so once again you are left to your
> own devices/risks.
> imagine that that the center of gravity will be somewhat raised,hence a
> more tender(tippier?) boat.Also,you still have to get 450lbs of lead on
> that boat,whether it is hung outside or laid inside.In otherwords,just
> Furthermore,the interior of the MICRO IS roomy but will be less so
> lead ballast you must find a sure-fire way to SECURE that lead or else
> in a knockdown(however slight and quick and it will happen......)that
> seriously damage your boat,to your great misfortune.So,once again,you
> the bottom now be?,how many bolts should I use to secure the lead?do I
> vapours is this,when all hell is breaking loose around you ie;lots of
> Kindly remember,that all of the above is nothing more then my own
> its lofty status as number 1 small homebuildable boat and that there is
> nothing worse then a totally smitten MICRO owner/builder giving advice!
> Sincerely,
> Peter Lenihan,in the grips of another blasted arctic day,on the still
> Get what you deserve with NextCard Visa! Rates as low as 2.9%
> Intro or 9.9% Fixed APR, online balance transfers, Rewards Points,
> no hidden fees, and much more! Get NextCard today and get the
> credit youdeserve! Apply now! Get your NextCard Visa at:
>http://click.egroups.com/1/929/5/_/3457/_/950458296/
> -- Create a poll/survey for your group!
> --http://www.egroups.com/vote?listname=bolger&m=1
Hello,
own devices/risks.
