Re: [bolger] How do I install a towing eye?
If you have to use a metal attachment, "U" bolts are better, the kind with
the steel backing plate. You get about twice the surface area bearing on the
wood, read twice the force required to pull it though.
McMaster-Carr has decent prices on them, don't buy them at West Marine
though!
Sent: Tuesday, January 21, 2003 9:33 PM
Subject: Re: [bolger] How do I install a towing eye?
> I got lucky because i had an eye bolt from an old swing set that the bolt
and nut both went into the hole. but drill the hole the same size as the
bolt, use an eyebolt with a nut. thread the eyebolt through with goup on it,
then put a fender washer and the nut on the other side. tighten, then wipe
away all goup before it dries, because after it dries it's hard to clean up.
> Aaron
> Do you Yahoo!?
> Yahoo! Mail Plus - Powerful. Affordable. Sign up now
I got lucky because i had an eye bolt from an old swing set that the bolt and nut both went into the hole. but drill the hole the same size as the bolt, use an eyebolt with a nut. thread the eyebolt through with goup on it, then put a fender washer and the nut on the other side. tighten, then wipe away all goup before it dries, because after it dries it's hard to clean up.
Aaron
Do you Yahoo!?
#1...thickened epoxy
Sent: Tuesday, January 21, 2003 2:46 PM
Subject: [bolger] How do I install a towing eye?
I want to install a towing eye on my teal about midway
on the stem. Do I:
1. drill the hole slightly oversize, fill with goop then poke
the eye bolt through.
2. drill the hole slightly undersize, put goop on the eye
bolt and drive it through.
Finish up with a washer and lock nut.
What substance would be an appropriate goop?
hal
Yahoo! Groups Sponsor
Drill two holes through the stem, about 40 - 50 mm apart, 8 to 10 mm
diameter. Trough them, sew a loop of fiberglass rowing strands
impregnated in epoxi resin until the holes are tightly full. Shape the
outer part to a size you prefer. For reinforcement, you may epoxi-glue
a strip of stainless steel to the inner stem, perhaps 300 mm long, so
loads are spread.
Frank - Brazil
I like the "hole for a rope through about three inches of fiberglass
reinforced plywood stem" version of towing eye myself.
The wood being stronger than any rope you can fish through the hole! And, no
worries about sealing it!
Sent: Tuesday, January 21, 2003 3:42 PM
> Something soft if you want to get it out (traditional bedding compound
> would be my choice). This is a very likely rot spot, so good idea to
> seal the end grain inside the hole first - paint, varnish anything will
> do, on a small artist paintbrush, Qtip, whatever you got. No doubt
> you're in a hurry, great spot for a dab of shellac. A goober of red
> lead dribbling out the hole would give you that nice "traditional" look!
> Make it a tight fit and get some goop in there if you can....the idea is
> just to fill the air spaces. A backing block on under that washer would
> be a good idea, for when the USCG idles up to your swamped boat someday
> trying to be helpful, tosses you the towline, then puts 1,000hp in
> "forward". Seriously, that point of attachment always seems to get
> yanked on hard at some point.
> --Fritz
Hal,
I like to drill a 5/8" hole, epoxy in a sleeve of 1/2" cpvc pipe (i.d. of 1/2" o.d. of 5/8")
Then thread 1/2" painter through the hole and tie a figure eight knot in it.
No bow eye or hardware!
Sometimes I do two holes in the sides near the stem, same pipe sleeve lining - makes a bow loop.
Here are pics...
http://www.simplicityboats.com/pvcholeliner.html
Someone else can answer your real question....;-)
david
Sent: Tuesday, January 21, 2003 3:46 PM
on the stem. Do I:
hal
--Fritz
on the stem. Do I:
hal
